The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Feb 23, 2017 at 8:52 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Yeah $1,500 to able to mate the stock trans doesn't sound like a bargain to me. I'd go for the 6-speed anyway, I think it's the t56? Kinda crazy how affordable the cx products are. The 5vz turbo kit was pretty clean quality although I'm no machinist. $1,000 for motor/trans mounts and headers? Yes please.
    When you add it up in your head it's only like... $5,000 right? Sign me up!
  2. Feb 23, 2017 at 9:02 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yea price wise not too bad. Will have to try it now.
    The T56 would be awesome..but its a 2wd tranny. Which means to keep 4wd you'd have to run a divorced Tcase setup..and that pretty much means a bad ass Atlas..so..you know another 2-3k for just your tcase.
    I think the NV4500 and Dana 20 is the "cheapest" and strongest option really for 4wd. unless your not going for 4wd.
    I'd have no problem running the headers and motor mounts. I'd upgrade the stock perches with the..DMZ..or DTF..can't remember who makes them @JuansTaco can chime in there.
    Find an L33 LS1 for under 800 bucks. Add a cam and port the heads and new lifts. Tune it. Run it at around 400hp. Then maybe think up a way to fit a turbo later.
    Looking at turbo LS motor and guys just build their own headers from the stock ones with the turbo mounted in front of the motor. If you moved the radiator to the bed, be easy to do that.
  3. Feb 23, 2017 at 10:10 AM
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    I have the famous fav perches. And bonzen motor mounts
    Blackdawg[OP] likes this.
  4. Feb 23, 2017 at 12:15 PM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
  5. Feb 24, 2017 at 7:50 AM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    @Blackdawg So how close are you to actually pulling the trigger? And I assume it's going into Frank?
  6. Feb 24, 2017 at 7:52 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Definitely Frank. haha i guess if it went smoothly i'll consider my other rig..but not likely.
    Pretty close. I did notice the headers from CXracing look like they won't clear a Front Diff. I emailed them. Even so, it proves you can make headers that do clear. Granted, i don't have 6k just laying around to do this, so it will be a process if i really decide to jump in.
    Dalandser likes this.
  7. Mar 7, 2017 at 5:49 AM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Is there a particular reason you haven't done the shock relocation? Lets you fit a longer shock but it moves the top of the shock inward? Like this? / \
  8. Mar 7, 2017 at 7:35 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    money. lol
    And i won't be angling mine.
    I plan on trussing and rebuilding my T100 rear axle, boxing the frame, then adding hoops in the wheel wells to run my shocks outboard. I'm not trying to make a smaller shock fit so no need to angle mine and id rather have the dampening work better that way.
    :rofl:
    about right..
  9. Mar 7, 2017 at 7:41 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    :popcorn: for your rear setup.
    jubei likes this.
  10. Mar 7, 2017 at 7:44 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    me too! :popcorn:
    Been meaning to do it for the last two years..:oops:
    oh..and rear hydro bumps of course.
    Still have to add coil bucket gussets, cam tabs gussets, spindle gussets and my coil bucket brace, though idk if i can now with the Blower on there.
  11. Mar 7, 2017 at 7:49 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    What type of work would be needed to run a T100 axle assuming it had the right gears and such? Just move the perches?
  12. Mar 7, 2017 at 8:00 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    T100/Tundra axles use the same diff as tacomas provided you don't have an E locker. The 8.4'' diff is the same. So i just have to swap over my 5.29/arb locked diff.
    Yes you have to reweld on leaf perches as the OEM ones are wider than our trucks.
    The axle is 6'' wider total, 3'' per side. Matches up with front LT very well.
  13. Mar 7, 2017 at 8:09 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Is T100 same width as the Tundy's? IIRC there was a minor difference in width I think.
  14. Mar 7, 2017 at 8:11 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I think they are the same actually. Though id have to measure. If there is a difference i think its like .5 or .25''
  15. Mar 7, 2017 at 8:15 AM
    JKO1998
    Utah
    I still have my stock gears whatever those are and I also have a locker.
    There's a T100 axle available in my area for like 500$ but I'm not really worried about it as I have a lot of other stuff that needs done before that.
  16. Mar 7, 2017 at 8:16 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    your diff won't swap over. The T100 axle can have different gears too.
    But id focus on a lot of other things before doing that.
  17. Mar 7, 2017 at 8:18 AM
    JKO1998
    Utah
    Yeah for sure I was just curious, it has 4:30 or something, I haven't really looked at it.
  18. Mar 7, 2017 at 8:23 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    you have 4.10s. So right there you'll have to spend money to either try and find a 4.30 front or redo both diffs to something that matches. Plus, 500 bucks is pretty steep.
  19. Mar 7, 2017 at 8:29 AM
    JKO1998
    Utah
    Ahh thanks for the info
  20. Mar 7, 2017 at 3:29 PM
    GreeGunc
    Jacob
    North GA
    Ah, thanks.
