The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Apr 29, 2017 at 4:59 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yeah..plus looks like im fucked either way. Even the 04410 one has the wrong clips. So i'm boned either way..
    Still be curious as to what is in @kigmob truck now..
  2. Apr 29, 2017 at 5:57 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Does the 04410 run into 98. That's what im coming up with when I search it. But I would have to double check PN numbers with what I found to make sure and those guys with the parts are closed. There is a vin number that can be cross refferenced with toyota.
  3. Apr 29, 2017 at 6:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No. The 04410 goes from 06/1997-10/1997
    Though it still comes up as a 97-98 one.
  4. Apr 29, 2017 at 6:47 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Looks like that 04412 is a 98 also
  5. Apr 29, 2017 at 8:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yep.
    And i think im screwed even if i got the 04410 because it has the 98 plugs not the 96/97 ones. So unless i rewire my whole truck to different pins..not worth it..
  6. Apr 29, 2017 at 9:03 PM
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    Hopefully @kigmob can verify his ecu number and I'm happy to check my local yard. Didn't make it this week but will next.
  7. Apr 29, 2017 at 10:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah be interesting to see.
    Other wise i guess i'll try knock sensors and O2 sensors...but im not throwing any codes. :notsure:
  8. Apr 29, 2017 at 11:09 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Or have Toyota flash the ecu for you. But who knows how much that will cost. Good luck man hopefully everything works out.
  9. Apr 29, 2017 at 11:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I don't think that is an option really for 1st gen ECUs..
    At this rate..i just wanna buy the MS3 Standalone..put together a turbo kit..leave the blower on there..
    Twin charge the bastard.
    Fuck it. haha
    SilverGhost[QUOTED] likes this.
  10. Apr 30, 2017 at 7:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well..
    This guy had what sounds like my issue: https://www.tacomaworld.com/threads/epic-ecu-question-please-read.330443/#post-9358421
    However, he just PMed me and he swapped in the 89661-04310 ECU and it woke up his truck.
    Which is Frank's OEM ECU...
    :annoyed:
    this shit is stupid..
    I think the best course of action is to rip the 7th injector kit out to see if a wire is crossed up somewhere. Even though i've checked it multiple times. Can't hurt and its free.
  11. Apr 30, 2017 at 7:28 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
  12. Apr 30, 2017 at 8:35 PM
    Bennett707
    Oregon
    x2
    frank isn't on the road enough to use it anyhow
  13. Apr 30, 2017 at 8:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ill check the wiring and pull the URD piggy back. If it doesn't improve..It'll be Igors.
    or i'll sell it. Idk.
  14. May 1, 2017 at 1:42 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    That sucks, Monte. Frank would be so much more beastly than he already is with that SC.
    Blackdawg[QUOTED][OP] likes this.
  15. May 1, 2017 at 1:45 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Beastly? I think you spelled broken wrong.
    :luvya:
  16. May 1, 2017 at 2:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah I kinda wish I just had turboed him. I didn't need more low down power that a SC is know for really due to the gearing. I wanted more go up top..
    But the cost drove me away..but now. pff..would have been better off..sheesh.
    Ha...
    yeah pretty much :anonymous:
    Robmonster117 and jubei[QUOTED] like this.
  17. May 1, 2017 at 3:30 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Pshhhh, boost is over rated anyways.....
    oh wait....
    nevermind.
    j0shu4 and Blackdawg[QUOTED][OP] like this.
  18. May 17, 2017 at 4:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Okay!
    Ripped out the urd 7th injector controller. Put my original ECU in.
    Bam. Runs good! Pulls hard to redline.
    Though not as good as it should. I can feel the timing doing weird things. And it pings a bit.
    So....wtf is going on with the urd unit is the question!
  19. May 17, 2017 at 4:08 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Bueno, now your issue is just fuel and timing as it should be haha. Is the URD unit remappable? And is there a possibility some wiring for it was not quite right?
    Blackdawg[OP] likes this.
  20. May 17, 2017 at 4:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I've check the wiring so many times haha I thought that is what was wrong. It's not.
    Yes the urd unit is fully tunable.
    Looks like I need to buy gauges and get the laptop out.
    Need to find a base tune map though
