The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Aug 9, 2017 at 12:44 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It seems like you could relocate the spring hanger and run longer leafs that you could swap over to igor when the time comes. Why not do that?
  2. Aug 9, 2017 at 4:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Not a terrible idea. But a lot of work..small payout. But long term would be nice. Just gonna buy two new AAL for now as I don't know how life will be in three months.
  3. Aug 9, 2017 at 10:02 PM
    Dlc
    Dlc Member
    1995 tacoma v6
    What size u bolts did you use ??
  4. Aug 9, 2017 at 10:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    uhh..not sure. 1/2'' i think..
    If you're looking for some Wheelers sells them. I just go to the parts store though and get new ones when ever i tear the leafs off. The bolts are never straight.
  5. Aug 10, 2017 at 1:36 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    That's what happens when you take your truck out of the garage...
  6. Aug 10, 2017 at 3:00 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Who does? :notsure:
    jubei likes this.
  7. Aug 10, 2017 at 4:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Something you'd know very little about :luvya:
    Well..at least most would assume decent job security and a place to call home.
    I won't have any of that haha
    StAndrew[QUOTED] likes this.
  8. Aug 10, 2017 at 4:39 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    I thought you were moving to LA or something?
  9. Aug 10, 2017 at 4:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Correct
    But I have no job lined up or even house haha yet
  10. Aug 10, 2017 at 6:01 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I hope you at least know somebody in LA.
  11. Aug 10, 2017 at 6:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah several. Not worried. But still...no idea what life will be like in 3 months haha
  12. Aug 22, 2017 at 7:28 AM
    Dlc
    Dlc Member
    1995 tacoma v6
    What's size eye mount did the shock have ??
  13. Aug 22, 2017 at 7:32 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    i think its 5/8s for the OEM mounts. Not 1/2''
  14. Aug 22, 2017 at 7:43 AM
    Dlc
    Dlc Member
    1995 tacoma v6
    Did they slide in perfect or did you have to modifie the truck ??
  15. Aug 22, 2017 at 2:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Went right in no problems.
  16. Aug 22, 2017 at 2:19 PM
    Dlc
    Dlc Member
    1995 tacoma v6
    I went and measure my eye mounts and it had a diameter of 3/4" I assumed your truck was the same since its only a year older. I don't know mush about shocks but I don't want to order I part thay I cant return without being sure it will fit. Should I say "Fuck it" and order the shock with the 5/8 eye mount ??
  17. Aug 22, 2017 at 9:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    you sure its 3/4" That seems very large..
    I now there is a spec for it somewhere though. Lemme look. Hold on.
  18. Aug 22, 2017 at 10:59 PM
    Dlc
    Dlc Member
    1995 tacoma v6
    Ok thanks
  19. Aug 22, 2017 at 11:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haha of course. It's 18mm. So..close to 3/4". Should be able to find the bushings online easy.
  20. Aug 23, 2017 at 12:02 AM
    Dlc
    Dlc Member
    1995 tacoma v6
    Ok ill keep looking thanks for the help
    Blackdawg[QUOTED][OP] likes this.
