The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Sep 10, 2017 at 8:00 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Agreed. I haven't really done much, but when I did finally get a few things knocked out recently it felt good. It's hard to want to work on something you're planning to replace though.
    I think I missed the most recent story on the blower. Did you end up getting the kinks worked out?
  2. Sep 10, 2017 at 8:00 PM
    Oside7even6ixty
    Oside7even6ixty Well-Known Member
    Right on that's good to know, only thing I'd worry bout would be running out but sounds like that will last a while
  3. Sep 10, 2017 at 8:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Sorta..
    I pulled the URD unit and it worked suddenly. Pings a bit at high elevation and below 2500rpm. But not bad considering i have the 2.1 pulley.
    Gonna do meth/water injection to cope with it as it'll also cool the blower.
    Yeah will last a long time. And like i said. I have two 8oz hot shots for back up.
    PcBuilder14[QUOTED] likes this.
  4. Sep 10, 2017 at 8:15 PM
    Oside7even6ixty
    So your gonna keep the blower on frank? Or still gonna pull it an put on other truck?
  5. Sep 10, 2017 at 8:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    arm and a leg?
    Alternator upgrade..150 bucks.
    Dual batteries..500
    fridge 500
    solar on the RTT..200
  6. Sep 10, 2017 at 8:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Keep it on Frank still. For now. LS swap i think is next motor wise for Frank after this. Just need to make it run a bit smoother. Then i'll move it to Igor:cool:
  7. Sep 10, 2017 at 8:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Could be worse..my locker was 1600 haha
    Quit buying vehicles and just mod the current one :p :luvya:
    Speedytech7 and PcBuilder14 like this.
  8. Sep 10, 2017 at 8:38 PM
    PcBuilder14
    Brent
    Nor Cal
    You and me both!
  9. Sep 10, 2017 at 9:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    don't we all.
  10. Sep 10, 2017 at 11:15 PM
    sawjai526
    sawjai526 Well-Known Member
    vincent
    Bayarea, CA
    15 DCSB OR 6spd
    regear, arb lockers:jellydance::jellydance::jellydance::drool::drool::drool::drool:
    Blackdawg[OP] likes this.
  11. Sep 10, 2017 at 11:16 PM
    sawjai526
    vincent
    Bayarea, CA
    15 DCSB OR 6spd
    clean hose route, tucked out of harms way. protection where potential hazzards!
  12. Sep 10, 2017 at 11:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    that was the idea! I actually ended up slipping the whole thing through fuel hose. Might redo the rear so its totally covered too.
    Re regeared! The rear is still holding up okay even though i set it up. so thats good!
    Front is just a bitch to do. Glad to have a warranty for it now.
    sawjai526[QUOTED] likes this.
  13. Sep 11, 2017 at 7:38 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    WOOT for 5.29's and ARB front! I think you should come to RT since Frank's fixed.:boink:
    jubei likes this.
  14. Sep 11, 2017 at 9:50 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I may or may not be able to. Depends on how my life plays out employment wise the next month or so.
    seanpistol likes this.
  15. Sep 30, 2017 at 11:18 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Monte!
    Question for you regarding your paintball CO2 tank:
    Are you running it sitting vertically or horizontally? (I can't tell from that photo...) I'm getting ready to find a home for mine and it occurred to me that I really don't want to dump liquid CO2 into my ARB.
    Thanks!
  16. Sep 30, 2017 at 7:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It is vertical!
    Had it horizontal for a while. Didn't like the chances of that happening either. So moved it.
    Worked great last week
    jubei[QUOTED] likes this.
  17. Sep 30, 2017 at 8:01 PM
    jubei
    NoCo
    Stuff. Also things.
    Hell yes! Thanks, Monte!
    I was tripping myself out on that. Seems like they'd be horizontal in a PB gun, but whatever. Glad to hear they worked well for you!
  18. Sep 30, 2017 at 9:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You'd think so. But actually they sit at an angle on a pb gun.
    Glad you went that route!
  19. Oct 6, 2017 at 4:21 PM
    jubei
    NoCo
    Stuff. Also things.
    Hey Monte, I'm checking my front locker operation and it's looking like it isn't engaging.
    I have the front end jacked up, 4WD engaged, and getting the expected open diff opposite tire rotation with the locker switch off. But when I turn the switch on with the Ox regulator open, there's no change. I am hearing something from the solenoid that sounds to me like it's working, but I have no idea what the actual locker sounds like when it locks up. Any ideas?
  20. Oct 6, 2017 at 4:23 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Have you checked that your ADD is working?
