The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Jul 22, 2018 at 9:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I fuckin with you all. I didn't just blow 3 grand on a 2jz haha Dan got it. haha
    jubei and what road like this.
  2. Jul 22, 2018 at 10:07 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    Damn it I was excited cause I thought I made Frank cooler by showing you that
  3. Jul 22, 2018 at 10:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I mean...ive thought about doing that for the last 2-4 years. But think an LS will work better in Frank.
  4. Jul 22, 2018 at 10:12 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    If I find a good deal I'll let you know
    Blackdawg[QUOTED][OP] likes this.
  5. Jul 23, 2018 at 4:39 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I super hate you.
  6. Jul 23, 2018 at 5:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Good <3
    :luvya:
  7. Aug 8, 2018 at 8:48 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Hey Monte quick question. I understand that the big 3 is mostly made out of 0 gauge but I don’t want to buy it at this time. I want to use the 2 gauge I have. Would the 2 gauge hold me by until I get the 0. Reason I’m asking is because I’m installing a x-a90v alpine amp. I want to beef up the wiring better then what I have now.
  8. Aug 8, 2018 at 1:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    the gauge is really important for your amp draw and how long the cable is.
    Since that is almost a 1000w amp. Its safe to say your fine to use that cable easily. If you're planning on running other things off that cable then you might want to do some math.
  9. Aug 8, 2018 at 1:16 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Just the amp. Thanks. I’m also going to make the alternator to pos and both grounds out of the 2 gauge wire.
  10. Aug 8, 2018 at 1:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    2ga will be more than enough for that job as well. No need to get 0 gauge. Most due 4ga for that anyways.
    SilverGhost[QUOTED] likes this.
  11. Aug 8, 2018 at 2:30 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    To reinforce what Monte said, and for others thinking along similar lines, use this formula to find how many amps you have to carry on the wire. Then the chart will tell you the maximun number of feet (length) the wire can safely be at that amp load. Amps=Watts/volts
    In this case, we want to convert 1000 watts to the amp load using a 12 volt environment. So the math would be 1000/12= 83.333. So If I use 4 gauge wire, how many feet of wire can I safely use for my 83 amp load? The answer is 22 feet max. The chart also shows that 2 gauge has way more capacity that I require at the moment unless my cable run is a lot more than 22 feet.
  12. Aug 21, 2018 at 9:47 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Me too. Much as I enjoy Igor. I hate driving him on the dirt since Frankenstein just flies over stuff. Be a while though sadly. Need a place to perform surgery and I don't have that right now.
  13. Aug 21, 2018 at 10:44 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sure but with the amount of work I want to do, it would be an all winter make over more or less. I have a garage but it is super small. I don't think Frank would fit through the door.
    what road likes this.
  14. Aug 21, 2018 at 10:50 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Its a stretch to get Igor in there haha
    If I hadn't moved and still had the shop, Id be knee deep in parts and welding.
    Oh well. Im sure I'll be moving again next year hopefully more permanent. Hoping for a raise with a new contract so that'll help.
    HomerTaco and Dalandser like this.
  15. Aug 21, 2018 at 10:55 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    6 or 7 times in the last 18 months. Sucks.
    getting good at it though..lol
    Yeah no doubt. I miss it.
    m3bassman[QUOTED] likes this.
  16. Sep 7, 2018 at 2:29 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    :gossip: Colorado
  17. Sep 7, 2018 at 2:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    What about Colorado?
  18. Sep 7, 2018 at 3:59 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    You mentioned about moving so I just suggesting for you to move to colorado. But I know that's a big no. :D
  19. Sep 7, 2018 at 4:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh ha
    Yeah if I couldn't work where I do Colorado or Boise or Seattle would likely be my top choices.
    But hoping I don't have e to move far again for a while.
  20. Sep 7, 2018 at 6:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Also no where near as cool of studios..or music scene. Kind of a requirement for me haha
