The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Jun 10, 2020 at 3:59 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You didn't just hard wire the welder? I thought that's why you ran all the cable
  2. Jun 10, 2020 at 4:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    well I have to wire the connectors. it's basically a 55' extension cable.
  3. Jun 10, 2020 at 11:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    well I have a bad ITRE and a torn rack boot..which is probably why the ITRE is bad. So gotta fix that.
    Im considering just plating the coil bucket instead of doing the coilbucket gussets.
  4. Jun 10, 2020 at 11:27 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Having done the gussets on Mike's truck @Digiratus, I wouldn't do them on mine. They are a bigger pain than they are worth (make all kinds of access harder), and don't do much for the most vulnerable area (the top).
    jubei likes this.
  5. Jun 11, 2020 at 12:45 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah I think if I got this guy:
    Then just plate the sides and tie into it it would do a better job honestly. I don't quite get the point of doing a double shear on the UCA unless it's a Heimed setup.
    Figure that then adding a cross bar hopefully with the DD kit I have and i'll be good. Probably honestly just the cross brace and plating the sides would be good but idk when I'll have the tube bender up and working. Have to wait for more space for that thing.
  6. Jun 11, 2020 at 8:32 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    The TC gussets definitely add stiffness to the coil bucket but probably wont help with the metal fatigue issues we have seen with the top of the bucket if that is what you are most worried about.
    The real value of the eimkieth top plate will be to support the 3 mounting points for the CO on top of the coil bucket, to keep them from tearing. It by itself will do nothing for the top edges of the bucket, and may actually transfer some of the stress to the top edges. Plating down the sides and back, tied into that top plate, IMO, would help a lot to prevent what happened to the redhead.
  7. Jun 12, 2020 at 12:27 PM
    Speedytech7
    The vertical bolt is annoying but not horrible. The awful part is undoing the lines with the 1/2" of space you have
    jubei and Bandido like this.
  8. Jun 12, 2020 at 12:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It's a pain to pull but not horid. The hydralic lines can be very hard though and possibly the flex joint too.
  9. Jun 12, 2020 at 12:59 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Getting the spline out of the rag joint can be a bitch and a half. We tried like three different methods of beating on it with Mike’s truck. If you’re going to do it soon, I’d suggest start hitting it with penetrating oil now.
    jubei likes this.
  10. Jun 12, 2020 at 1:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah as Dan said that thing can be so hard to separate.
    You've already done the bolts with the LCA replacements so your good there.
  11. Jun 12, 2020 at 1:53 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    I have no experience with aftermarket racks, but it seems like others that have tried rack doctors and those have not had good luck.
  12. Jun 12, 2020 at 1:54 PM
    Phessor
    Phessor Well-Known Member
    My Rock Auto rack has lasted three years with no problems.
  13. Jun 12, 2020 at 2:01 PM
    Speedytech7
    I'm going to pick up a whole front of a 4 runner today including rack and spindles just because I don't wanna deal with reman crap
    m3bassman likes this.
  14. Jun 12, 2020 at 2:11 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    I’m sure you can get all the seals, I’ve done the rack guide before so I know that’s available. Not sure about the shaft itself, if that has wear on it for some reason. Sounds like if yours is just leaking it might only need new seals.
  15. Jun 12, 2020 at 2:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hope it works out. Haven't read hardly anything good about reman racks. It's too bad you can't get an OEM one sans ITRE because those damn things are half the cost haha
    Add a cooler for it as well will help a ton. I have one I've been meaning to add.
  16. Jun 12, 2020 at 2:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    MM I don't think so on the low pressure side.
    Speedytech7 and jubei like this.
  17. Jun 12, 2020 at 3:02 PM
    Speedytech7
    Sequoia axle is getting dragged out of storage right now. We will see how good a $260 axle is haha
    Digiratus likes this.
  18. Jun 12, 2020 at 3:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    can't be worse than what you have now haha
  19. Jun 12, 2020 at 4:25 PM
    Speedytech7
    Fucking legendary haul here. Anyone need some OEM CVs (yes I checked em)? Or an OEM rack haha. I'm keeping the spindles for gusseting tho.
  20. Jun 12, 2020 at 4:30 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Those look like 4R CVs with the narrower center shaft?
