The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Jun 6, 2024 at 7:36 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah I easily went through a few cutoffs and flappers even after using a plasma to remove most of it
  2. Jun 6, 2024 at 11:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Not here. Toyota parts are few and far between in MT/Wy.
    Eh I don't mind labor usually. Although time is everything these days. But probably the cheapest way to get rear discs. Not that that is a priority for me.
  3. Jun 7, 2024 at 12:16 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yep there’s something to be said for an as near to drop in replacement as possible when it comes to reusing as much of your existing hydraulic braking system, e brake, and lack of time sink on a project that is sandwiched in with a lot of other ones.
  4. Jun 7, 2024 at 12:32 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    plus I can keep my 5.29 locked diff
  5. Jun 7, 2024 at 7:08 AM
    CoWj
    CoWj Lost and Found at the same time.
    Wyatt
    Northern CO
    Burt: 1998 2.7 Regular 5 speed 4x4
    Bilstein 5100, ARB Bumper, Warn VR EVO 8, 34x10.50 Toyo 4.88s ARB Locker
    Blackdawg[QUOTED][OP] likes this.
  6. Jun 7, 2024 at 7:35 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Does the Sequoia axle use the mini truck and not an 8.4 diff? If so and you're concerned about breaking the T100 axle, just go with a 9" van axle and semi float shafts from dutchman with a rear disk kit from RS or solid axle industries that uses an e brake.
    Spending time cutting and welding on a housing truss for the T100 vs. a Sequoia axle would be better. The 9" RS truss worked for a couple guys including Silver Ghost I believe and I gave this one to Anthony to put on his Tundra axle which while he had to add and remove some here and there, he installed it on the truck so on a bench it should be pretty cake
    https://www.tacomaworld.com/threads/anthonys-99-tacoma.175933/page-26#post-23551877
  7. Jun 7, 2024 at 9:27 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thats true. It's about 8 hours to denver and i've done crazier things for parts before.
    No it uses the same 8.4 as my tacoma. So be a direct swap in. Which is nice.
    Going to a full 9'' would be awesome if I could find that right axle. I think to fit the WMS its a very specific van I'd have to find. I don't even remember what it was. But if I ever say Fuck it and go links I'd probably do that route. But Linking Frank is a ways off at this rate ha
