The FREE Blinker Light Relocation Mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by Blackdawg, Nov 3, 2011.
  1. Nov 3, 2011 at 11:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    So after i bought my Elite bumper i had to redo my blinkers to move them to the corner lights. Now while there are several ways to just rewire the marker lights to become your blinkers..for some reason i didn't feel like doing that. So i came up with this instead. by drilling out a hole with notches in it, i could just plug in the original blinker bulb into the market light housing WITH the marker bulb in it at the same time. No wiring required. Granted it does take a long time to do, but it works. And if you don't feel like wiring stuff, this is the way to go.
    So first you have to take out the corner light housing and marker light. Then thread up the blinker bulb light up to the corner.
    Now you HAVE to disconect at least one of the blinker bulbs to get the mount. This is your template to cut and notch out your new hole. Don't just guess. You want as tight a seal as possible, so you need this and yes, it is a classic Toyota connector so...its a major PITA to get apart
    So now you have your corner light. Some of these pics are of my new clear corners and some of my OEM ones. The shiny ones are the newer ones and have the white tab over the marker light hole. Please disregard the tab. Its just for shipping purposes, you do not want to cover the marker light hole as you will be putting the marker light back in.
    drill a small hole below the marker light. You can use a 1'' bit if you'd like too. I would not recommend going any larger tho as you can fine touch up the hole with a file instead of overshooting and having too large of a hole. Or just start small and file it out larger. I did both ways. Filing out takes much more time(obviously) but works. So if you don't have a 1'' bit, no worries.
    Small drilled hole
    Large drilled hole
    either way after you have drilled get a round file and go to town. You want the light mount to fit nice a snug with as little space between the housing and mount as possible. Once i start going in, it'll catch on the tabs. You then have to notch out for the tabs. do this with a file as well or dremel. Its just plastic. Whatever way you want to cut it all out will work..just don't cut to much..Here is one of mine..not a prettier one..
    Then the mount should sit nice a tight
    Then used compressed air to clean out the housing, you prolly won't be able to get it all out, but get as much as possible.
    Now just reassemble! I will get videos up soon of how it looks at night. Its actually VERY bright. works great really.
    Also if you still have your half amber housings, you will NOT have to change out bulbs! The blinker bulb sits so close to the amber side that it'll be plenty amber. here is a pic of the BLINKER light on not the marker light(tho it is on as well).
    If you are going to be running clear corners..you had better get some amber bulbs.
    Videos of it in action coming soon!
    For 98-00(I have been told this works great!)
    2012-02-17_17-19-58_462_7e1e7c7b61184a3d5d28f2017426a6eaa5ec8bf6.jpg2012-02-17_17-20-10_438_ae628e0d5b887e00828bbc4480ac8711da5fb341.jpg2012-02-17_17-20-18_570_ecd7fdc09a6f261cb257e76dc3d6fbf97de46fdf.jpg
    For 01-04s(should also work with 98-00)
    http://s637.photobucket.com/albums/uu94/GMCBlackdog/?action=view&current=2011-11-04_23-48-53_839.mp4 <this link will take you to the video if it doesn't play.
    List of Confirmed members running it
    Blackdawg
    igarrpan
    Cr250jumper
    Jonyd182
    SupraT
    4WD
    Banjohauler
    Taco me elmo
    Taco.VR4
    ponethousand
    Ipreferwater
    Stubbs95tacoma
  2. Nov 4, 2011 at 5:20 AM
    Sign Guy
    Sign Guy Well-Known Member
    Brian
    Everett, WA
    DrugRunner V6, 2wd
    Nice Rims, Big Tires, Carryboy Shell, Added Rosta Cruise Control & Ultraguage, 5100 Bilsteins All around
    Way ta go! Awesome job and a great write up.
  3. Nov 4, 2011 at 7:34 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    thanks man. Works great too.
  4. Nov 4, 2011 at 11:07 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Heres a vid!
  5. Nov 4, 2011 at 11:38 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    awesome. This is what I am going to do when I get o/r bumpers.
    Nice work.
    sovereign likes this.
  6. Nov 4, 2011 at 11:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thanks man. Yea i like it a lot actually. Think it works better actually. The blinker is so bright now lol
  7. Nov 4, 2011 at 11:45 PM
    TacoMX
    Jonathan
    Deltona, Florida
    Yeah, I hate where the blinkers are on our trucks, doesn't look right in the valence. And higher=more visible. And I love the way your truck has turned out. The Elite bumper looks mean...I am just too poor for it...lol...Gotta love the 95-97 front ends too :headbang:
  8. Nov 4, 2011 at 11:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    exactly. Plus this throws light forwards and side ways really well.
  9. Nov 4, 2011 at 11:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thanks man! :D
    I do love it was well. Have many more plans for it as well if i had the funds..so i know how you feel. And truth be told..we have the best front ends :p lol
  10. Nov 5, 2011 at 12:26 AM
    TacoMX
    Jonathan
    Deltona, Florida
    and cool steel/lavender steel metallic FTMFW!!!
  11. Nov 5, 2011 at 12:59 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :thumbsup: :cool:
  12. Nov 5, 2011 at 4:32 PM
    rayny1014
    rayny1014 Well-Known Member
    new york
    04 trd xtra cab 4x4
    i did this mod on my 04 today , works great.
  13. Nov 5, 2011 at 4:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Great to hear! Im glad it worked. Also impressed at how fast someone tried it already..haha
  14. Nov 5, 2011 at 4:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No, you are litereally taking the bulb that twists out of the blinker housing and puting it in your corner light. So the lights would not do anything.
    BUT what you could do is put some afftermarket lights in place of the blinkers and wire them for fog lights.
  15. Nov 5, 2011 at 4:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    well if you get new lights then yes you could wire them to turn on with the brights. Id just wire in a seperate switch tho as it'll give you more control of when they are on and such.
  16. Nov 5, 2011 at 5:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ohhh im sure you could make that happen as well lol
  17. Nov 5, 2011 at 6:40 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Cool stuff but for me it's a 15 minute job to re-wire it and re-sleeve the plastic protector on.
  18. Nov 5, 2011 at 6:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    true, but there is no way your throwing the same kinda light as i am :p
  19. Nov 5, 2011 at 6:44 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    LED's nignog.
  20. Nov 5, 2011 at 6:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    well thats adding even more wiring then as you should add a resistor so it doesn't flash stupid fast.
    And even then..id be willing to be that its not much brighter. But either way, doesn't matter this is just another option. You like wiring, go for it. I didn't want to at the time. so i didn't.
