The FREE Blinker Light Relocation Mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by Blackdawg, Nov 3, 2011.
  1. Apr 24, 2012 at 8:12 PM
    #141
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Well you will still have to use some files to touch it up and make the notches and just a tad bit bigger.
    but it is WAY faster.
  2. Apr 25, 2012 at 9:50 AM
    #142
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    :pout:
  3. Apr 25, 2012 at 10:13 AM
    #143
    Blackdawg
    Monte
    Wyoming/St. Louis
  4. Apr 25, 2012 at 12:09 PM
    #144
    TacoMX
    Jonathan
    Deltona, Florida
    cool steel metallic tacos gotta stick together mang....
    :D
  5. Apr 25, 2012 at 12:47 PM
    #145
    Blackdawg
    Monte
    Wyoming/St. Louis
    :thumbsup: Hells yea :cool:
  6. May 10, 2012 at 8:03 PM
    #146
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    Worked like a champ!! Thanks for this write up. Did my blinker mod on 04! Ordered a new bumper, wanted the clean look of the blinker relocation!
  7. May 10, 2012 at 8:13 PM
    #147
    TacoMX
    Jonathan
    Deltona, Florida
    I was too lazy and just spliced my turn signal wire and the marker like bulb holder together. :eek:
    The stock bulb is too dim. Will need LEDs soon.
  8. May 10, 2012 at 9:05 PM
    #148
    Blackdawg
    Monte
    Wyoming/St. Louis
    Glad you liked it and that it worked well for you!
    don't you need like a resistor to keep it from like..hyper blinking..or..idk..i read you needed a resistor if you spliced them together..
  9. May 10, 2012 at 10:46 PM
    #149
    TacoMX
    Jonathan
    Deltona, Florida
    yeah, they hyper blink but it doesn't bother me.
    I might add a resistor at some point...but meh...turn signals are turn signals no matter how fast they blink.
  10. May 10, 2012 at 11:01 PM
    #150
    Blackdawg
    Monte
    Wyoming/St. Louis
    lol whatever you like man!
  11. May 11, 2012 at 7:06 PM
    #151
    losers101
    losers101 Well-Known Member
    Brandan
    Texas
    2004 Dbl Cab 4x4
    Starting fresh :)
    Just did this on my 96 because Im building my own plate bumper. Works really well, thanks!!!!!!!
  12. May 12, 2012 at 12:08 AM
    #152
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    so on the 04 you just cut the blinker housing off the blinker covers, drilled a 1" hole in the corner marker light, and siliconed the blinker housing from the blinker cover over said 1" hole?
  13. May 12, 2012 at 12:32 AM
    #153
    Blackdawg
    Monte
    Wyoming/St. Louis
    You bet man :thumbsup:
    Glad you like it ill update the OP with your name
    correct sir!
  14. May 12, 2012 at 7:10 AM
    #154
    Bennett707
    Oregon
    Sweet will be doing this mod soon. What'd you use to cut the housing off the old one.
  15. May 12, 2012 at 8:01 AM
    #155
    Blackdawg
    Monte
    Wyoming/St. Louis
    i have never done it as im a 96, and i did a set of 98s for someone. But you just need a hacksaw or dremel. a hacksaw will keep if more flat and strait of a cut tho.
  16. May 13, 2012 at 5:25 PM
    #156
    Bennett707
    Oregon
    in the process of finishing, took some good stage photo's for anyone else 01-04 that may want to look at some. will upload after I am finished. :)
    cutting the housing off the blinker cover
    corner marker light, housing, blinker cover
    drilling a 1" hole in the corner marker light
    hole just a little to small for the bulb to sink in.
    dremel to make the hole a bit wider for the bulbs
    new hole for the bulb
    tapeing the light to the corner marker light so i can glue it in the right spot. I did this to insure that the bulb would fit when plugged in and not hit the sides of my drilled hole, you could match the hole size of the housing, but I liked this better.
    glue
    remove tape and twist the bulb out but leave the housing. be very careful not to rip the sealed glue. i did and had to redo it, and put lots of pressure on the housing during removal. I mean I'm sure if you had patients and just let it dry completely. I also added more glue after this stage. Like previously sad, only did this to ensure that the bulb would go into the 1" hole.
    vulkem as a sealant.
    dryyying.
  17. May 13, 2012 at 7:57 PM
    #157
    Bennett707
    Oregon
    oh & feel free to add me to the members running this mod.
  18. May 13, 2012 at 10:17 PM
    #158
    Blackdawg
    Monte
    Wyoming/St. Louis
    awesome man!!
    great pics!!
  19. May 30, 2012 at 11:46 AM
    #159
    Stubbs95tacoma
    Stubbs95tacoma Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    Just finished doing mine! Add me to the list :D
  20. May 30, 2012 at 11:47 PM
    #160
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sweet! Done :cool:
