The Frustrated Taco Build
Discussion in '2nd Gen. Builds (2005-2015)' started by FrustrationFabTaco, May 26, 2012.
  1. Dec 18, 2013 at 3:48 PM
    #421
    FrustrationFabTaco
    FrustrationFabTaco [OP] Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    me like those
    i remember a few plate ideas from the tidewater thread
    i like bfs out
  2. Dec 18, 2013 at 3:50 PM
    #422
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    This whole conversation is over my head
  3. Dec 18, 2013 at 4:33 PM
    #423
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    I got two of those in amber to mount on the rear bumper for low-vis conditions. I'm impressed with the output, just not totally sure of mounting solutions as rock lights.
  4. Dec 18, 2013 at 5:36 PM
    #424
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    That's about the only issue I can think of. Found this thread as well http://www.pirate4x4.com/forum/general-4x4-discussion/841577-rock-lights-2.html
    Not sure what I'm gonna do, might get the strips like you have
  5. Dec 18, 2013 at 5:48 PM
    #425
    ckeene9
    Chesterfield, VA
    See Build Thread
    I like the strips under the cab but want to switch to the Lifetime or something similar in the wheel wells. The strips get muddy and are a pain to clean in the wheel well. Where the lifetime would only need a quick wipe.
  6. Dec 18, 2013 at 6:07 PM
    #426
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    Had an idea for the lifetime lights. As for the sides of the truck do two of the lights on small angle iron brackets that could just be tack welded above the slider mounts and brackets coming off front and rear bumpers (plate bumpers would work better)
    Edit: just some small tabs with holes to fit the light would be ideal, you could angle them any way you wanted under the truck specifically
  7. Dec 19, 2013 at 4:10 PM
    #427
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    I think I might get two of those lights from southeast overland and get a small bit of 1/16 steel and try out some mounts for them between sliders and such. If they don't work I can always use them for something else.
  8. Dec 20, 2013 at 1:52 PM
    #428
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    wtf it doesn't fit.
  9. Dec 20, 2013 at 1:56 PM
    #429
    AR15xAR10
    I ain't know what to tell you maine
    But, es no gucci :(
  10. Dec 20, 2013 at 2:28 PM
    #430
    ckeene9
    Chesterfield, VA
    See Build Thread
    I had no issues with mine :confused:
  11. Dec 20, 2013 at 2:32 PM
    #431
    AR15xAR10
    Pics?
  12. Dec 20, 2013 at 2:48 PM
    #432
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    Can't now. Already changed the oil. I think the stock is 10mm judging by how far it was off. And the valve was 12mm
    Edit: nope it's 12mm just like the stock plug. I have no idea why it wouldn't go in. I'll save it and try again next oil change
  13. Dec 20, 2013 at 3:11 PM
    #433
    AR15xAR10
    Threads may just be different, don't force it. If you got it from Amazon, have them exchange it or something
  14. Dec 21, 2013 at 8:29 AM
    #434
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    I see what you did there....
  15. Dec 21, 2013 at 9:52 AM
    #435
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    It can be as soon as you give me monies :D
  16. Dec 21, 2013 at 9:53 AM
    #436
    AR15xAR10
    OHHHHHHHH, he said you ain't got no nipples
  17. Dec 21, 2013 at 11:23 AM
    #437
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    I'd like to, believe me
  18. Dec 22, 2013 at 8:49 AM
    #438
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    DB joo broke mah truck
  19. Dec 22, 2013 at 8:53 AM
    #439
    AR15xAR10
    Que es DB? Doche bag?
  20. Dec 22, 2013 at 8:56 AM
    #440
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    Hunter :p
