The GASSHOLE™ Fuel Cap holder- FREE Shipping
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Feb 16, 2018.
  1. Jan 5, 2019 at 12:17 PM
    #2401
    Sgt.Tee
    Sgt.Tee Well-Known Member
    Pete
    NE Pa
    2019 MGM SR Tacoma 4&4
    Hey good for you, you found a niche and I hope Toyota finds out and makes you the big bucks, it is a sort after item for sure, I only checked this thread a dozen times today hoping you will have them for sale. I would put in for a patten also
  2. Jan 5, 2019 at 12:21 PM
    #2402
    pr0b
    pr0b Well-Known Member
    San Jose
    '16 DBCLB Off Road Magnetic Gray
    CustomCarGrillz Grill OME lift kit Demelo Off-Road sliders De-badged 305/65/17 BFG KO2 Prinsu Cab Rack SCS Ray 10s SDHQ Behind the grill LED bar mount Baja Designs 30" LED Bar Rigiid Industried 30" LED Bar Magnaflow exhaust MESO map and dome lights Expedition Essentials TPAM VLED switchback front turn signals
    It’s finally warmed up outside so I wanted to install mine. Anyone else unable to remove the Phillips screw? Trying to figure out how to remove the fuel door.
  3. Jan 5, 2019 at 12:24 PM
    #2403
    Sgt.Tee
    Pete
    NE Pa
    Why do you want to remove the fuel door?
  4. Jan 5, 2019 at 12:53 PM
    #2404
    pr0b
    San Jose
    I’ve tried two Phillips bits, I’ve had someone apply pressure to the fuel door and I don’t want to strip the screw. Pliers won’t fit. The only thing I can think of is getting to the back of the screw from the side that’s attached to the body.
  5. Jan 5, 2019 at 1:05 PM
    #2405
    Onemorodeo
    Onemorodeo Well-Known Member
    OC SoCal
    ‘18 dclb TRD Sport 4wd Cement
    Just installed mine yesterday, the Phillips screw came out without an issue. Took less than a minute for the install. I can't imagine needing to remove the fuel door.
    CusterFan likes this.
  6. Jan 5, 2019 at 1:07 PM
    #2406
    epack236
    epack236 Well-Known Member
    2018 BBP TRD OR
    You don't need to remove the door, just the one phillips screw. Make sure you're using the right sized bit. I want to say #3, but could be wrong. It was pretty tight on mine but I braced the back of the door with my hand and put some force into it.
  7. Jan 5, 2019 at 1:12 PM
    #2407
    pr0b
    San Jose
    Yup @Onemorodeo. Tried it all. The sucker won’t move.
  8. Jan 5, 2019 at 1:14 PM
    #2408
    epack236
    2018 BBP TRD OR
    There's only one more option:
    .......maybe try some penetrating oil though
    pr0b[QUOTED] likes this.
  9. Jan 5, 2019 at 1:26 PM
    #2409
    Sgt.Tee
    Pete
    NE Pa
    Yes penetrating oil and then place your Phillips bit on the screws and give it a few taps with a small hammer, it will move the oil faster
  10. Jan 5, 2019 at 2:55 PM
    #2410
    airmac_11
    airmac_11 Well-Known Member
    2019 Cement DCSB Premium/ Tech TRD 4x4 Sport
    Well personally I wish nothing but the best for you. I think you offer quality products that people want. I am amazed at what you decide to tackle in terms of the products you offer- That is talent seeing something out of nothing when looking at a product.
  11. Jan 5, 2019 at 4:06 PM
    #2411
    aiya
    aiya Well-Known Member
    NYC
    2019 White TRD Sport DCSB
    How odd that some screws are in so tight. Mine came off with very moderate pressure. After reading the horror stories, I was prepared for a fight and a stripped screw. Instead it started turning immediately and easily.
  12. Jan 5, 2019 at 7:26 PM
    #2412
    Rewilliams
    Rewilliams Well-Known Member
    Robert
    2017 Tacoma
    I used an impact drill and it came right out.
  13. Jan 5, 2019 at 7:29 PM
    #2413
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    This.
    If you have a pesky bolt(no rhyme or reason for any particular model or year) some are easy... while others can be super tight.
    Step 1: spray with penetrating oil and let it soak in
    Step 2: get an impact driver with a #2 Phillips bit
    Step 3: hold the gas door firmly with 1 hand, while using the impact driver(and adequate pressure) with the other hand and remove the bolt.
  14. Jan 5, 2019 at 7:30 PM
    #2414
    Rewilliams
    Robert
    2017 Tacoma
  15. Jan 6, 2019 at 4:46 AM
    #2415
    chriscamilo
    chriscamilo Well-Known Member
    2018 Tacoma DCSB Sport
    I added this to my '18 shortly after I got it. I think the longer the screw goes without removing it, the more trouble you'll have with it.
  16. Jan 6, 2019 at 10:44 AM
    #2416
    Wtsmith
    Wtsmith Well-Known Member
    Wilfred Todd
    2019 Tacoma TRD
    Please restock 3rd gen Gas Hole. :)
    vsyntax, mattwel and SilverBulletII like this.
  17. Jan 7, 2019 at 2:51 PM
    #2417
    mattwel
    mattwel Member
    Colorado
    2017 TRD OR
    Any idea when these might be back in stock?
    ColsonIRL likes this.
  18. Jan 8, 2019 at 3:28 PM
    #2418
    Russty__
    Russty__ Well-Known Member
    Russ
    Maryland
    Sold-‘16 DCSB Taco Sold-‘21 Power Wagon Now-‘20 Gx460
    This.
  19. Jan 11, 2019 at 5:07 PM
    #2419
    ArchitectJVM
    ArchitectJVM Well-Known Member
    I would like to place an order for one today, are these already available in stock?
  20. Jan 12, 2019 at 1:52 AM
    #2420
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    vsyntax likes this.
