The GASSHOLE™ Fuel Cap holder- FREE Shipping
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Feb 16, 2018.
  1. May 19, 2018 at 10:05 PM
    #1761
    Tacomagnetic
    Tacomagnetic Well-Known Member
    Edmonton, AB
    '18 Off Road MGM
    Same price? Ready to PP
  2. May 20, 2018 at 8:24 PM
    #1762
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    Don’t take this too seriously, but, your gonna be on your death bed and I’m gonna say the same exact thing...:rofl:
    Soon, @mesojdm , soon...
    Killing me, I want my SB 2nd gen:angrygirl:
    sonofarobin likes this.
  3. May 20, 2018 at 9:04 PM
    #1763
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Not going to happen man. @mesojdm will be printing body parts to live forever. However, it will cause a delay in the production of Meso mods.
    VirusCage likes this.
  4. May 20, 2018 at 9:47 PM
    #1764
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    @mesojdm
    So, I modded a mod this weekend...
    Here are the steps I went through.
    1) I spray painted primer on both sides, two coats on each side. I only waited 10 minutes before each coat, but I let both sides to fully dry overnight.
    2) Back to work on it the next day, I used 1000 grit sandpaper to smooth out the primer.
    3) Starting with the back side up first, I spray painted the the blue metallic paint, three light coats. Gave it 4 hours to dry.
    4) Flipping the GassHole over, i.e. the front side up now, I again spray painted three light coats of blue metallic paint on it. I made sure to spray a bit straight down to make sure I got inside the lettering. I let this dry overnight. This is why you need to start on the back, so that whatever you're propping up the Gasshole with will leave indentations ( if any ) on the back instead of the front.
    5) Next day, again starting with the back side up first, I spray painted the crystal clear coating, three light coats. Gave it 4 hours to dry.
    6) Flipping the GassHole over, i.e. the front side up now, I again spray painted two decent coats of crystal clear coating on it. I again made sure to spray a bit straight down to make sure I got inside the lettering. I let this dry overnight. This is why you need to start on the back, so that whatever you're propping up the Gasshole with will leave indentations ( if any ) on the back instead of the front.
    7) Let this fully dry overnight.
    And Viola! You're done.
    Yes, I know there will be a concern about whether or not the gas cap will fit inside the hole now that it has primer, paint, and clear coat on it, but I won't know that answer until I get my Taco from the factory. I'm sure over time the gas cap will wear it down in it's own way or I can help it a bit by sanding it down some if it's just crazy tight. We'll just have to wait and see.
    Another thought I had was painting the lettering a different color, as a few other's have thought about, but honestly, I thought it looked pretty good the way it was and chose not to add a second color. Maybe some enterprising fella can use model paint and brush, but it'll be a rather tedious process.
    Here are some photos from the project and the finished product. As previously stated, I just need a 37k accessory to complete my Gasshole.
    Products:
    A) Rust-Oleum Automotive Primer ( to help with metallic paint adhesion to the plastic )
    B) Rust-Oleum Cobalt Blue Metallic Paint ( others say its a good enough match to the Blazing Blue Pearl ).
    C) Rust-Oleum 2x Ultra Cover Gloss Clear
    As an Eagle Scout, I always need to be prepared for the waiting. TW.com on the SmartPhone, some PBR and I'm good to go.
    Primed, un-sanded.
    Blue paint done.
    Clear coat applied, dried and here's the final product.
  5. May 20, 2018 at 9:51 PM
    #1765
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    My daughter calls TacomaWorld "Old Man Twitter" because I spend too much time here and with my truck. LOL
    RobP62, LTacoman, buntcake and 4 others like this.
  6. May 20, 2018 at 10:04 PM
    #1766
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    CONGRATULATIONS! You have the shiniest Gasshole:)
    Nice write up. I've painted some other 3d printed stuff and I usually do; high build filler primer-->600grit wet-->2nd coat primer-->1k wet. Then color it.
  7. May 20, 2018 at 10:05 PM
    #1767
    Jorgy1
    Jorgy1 Well-Known Member
    2019 MGM Tundra CrewMax 4x4
    Meso, I’ve been with this since the start, first to purchase to test on a 2nd gen.......I gotta know.... Is the 2nd gen version going to fit the locking Stant cap I have?
  8. May 20, 2018 at 10:11 PM
    #1768
    MESO
    State of Jefferson
    All 3 Versions I have made have the same I.D hole. This fits the OEM cap 100%. But I cannot confirm fitment on Stant aftermarket locking gas caps. I think it will be determined by; if the cap had threading all the way to the tip. (which won't really work in the Gasshole because it's a press fit). Although, I have been told some do and some do not have it
    Jorgy1[QUOTED] likes this.
  9. May 21, 2018 at 2:31 PM
    #1769
    A Salt Weapon
    A Salt Weapon Well-Known Member
    T
    Southeast Alaska
    2017 Blue DCSB TRD OR
    Just ordered one.
    Wish I’d have seen this sooner.
  10. May 21, 2018 at 2:41 PM
    #1770
    MESO
    State of Jefferson
    That's an awesome gif.
    2nd Gens rejoice!
    At least Toyota did something right on the 3rd gens and consolidated the same fuel door for both bed sizes.
    Can't say the same about the 2nd's
    SB Left, LB right.
    RobP62, Bravisimo, Norton and 4 others like this.
  11. May 21, 2018 at 2:47 PM
    #1771
    FishnTx
    South East Texas
    ‘17 OR
    i had to use a baby set of vice grips to get mine off after stripping it went to the dealer and got two screw one back up
    JEE likes this.
  12. May 21, 2018 at 2:50 PM
    #1772
    MGMTaco23
    MGMTaco23 Well-Known Member
    M$V
    2010 TRD Sport
    -2.5” King Coilovers -Total Choas UCA -2.5 King shocks in the rear -Icon AAL 1.5” Falken Wildpeak AT 285/75/16 16” Raceline Wheels
    When will these be available @mesojdm ?!?
    Norton and sonofarobin like this.
  13. May 21, 2018 at 3:50 PM
    #1773
    GoddardPool
    GoddardPool Toyota Hoarder
    Jose
    Texas
    2016 "Serenity" DCLB/ 1999 "Lykke White" SCSB/ 1999 4Runner "Quorra"/ 1999 Toyota Maserati 1.8L
    I had been eyeing one of these glory holes for a few weeks, then I managed to win one during our Texas Toyota Coalition raffle this past Sunday. Thank You!
  14. May 21, 2018 at 3:51 PM
    #1774
    MESO
    State of Jefferson
    awesome!
    Hopefully this week
    sonofarobin, Soul Surfer and nazlax10 like this.
  15. May 21, 2018 at 4:07 PM
    #1775
    Sh2
    Sh2 Well-Known Member
    2016 Tacoma SR5 Double Cab
    Ovtune 2.0, Prinsu, 4xinnovations sliders, Southern Style Offroad Slimline with Warn VR Evo 10s
    I like it, "Old Man Twitter." It's fitting, though I do not tweet, I do Tacomaworld. It's visited early and often, even late.
    :headbang:
  16. May 21, 2018 at 4:09 PM
    #1776
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Do they make one for 2nd Gens?
  17. May 21, 2018 at 4:35 PM
    #1777
    MESO
    State of Jefferson
  18. May 21, 2018 at 4:39 PM
    #1778
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    Yes, for both the short and long beds.
    Should be available this week.
  19. May 21, 2018 at 5:45 PM
    #1779
    ccotner112
    ccotner112 Well-Known Member
    Saint Louis Missouri
    2018 Tacoma TRD Sport
    17' TRD rims/BFG Ko2, OEM Roof Rack, TRD Pro Grill, Locker down console , Snugtop Rebel, lots MESO mods
    happy customer :yay:
  20. May 21, 2018 at 5:47 PM
    #1780
    JEE
    JEE Well-Known Member
    2016 Tacoma SR Access 4x4 2.7L 5-speed
    Intermittent wipers, cruise control, receiver hitch.
    That's probably what I'm going to have to do... besides just giving up. :p
