The gauge cluster lights don't work !! HELP
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hektor, Jun 1, 2012.
  1. Jun 1, 2012 at 9:55 PM
    Hektor
    Hektor [OP] Well-Known Member
    Texas
    04 Tacoma 4x4 TRD DC v6
    Any ideas guys?? The gauge cluster light wont work!! Everything else works fine my ac lights. radio and shifter lights work!!! Its just the cluster, Fuel and temp that wont illuminate any ideas?
  2. Jun 1, 2012 at 9:58 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    1st gen run on 194 bulbs (all plug and play) it probably burned out
  3. Jun 1, 2012 at 10:00 PM
    Hektor
    Texas
    The illumination lights. The turning signals work .
  4. Jun 1, 2012 at 10:01 PM
    Hektor
    Texas
    How hard is it to replace them? Would be better to take it to te dealership?
  5. Jun 1, 2012 at 10:14 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    Don't you dare take it to the dealership lol...take the dash apart and remove he cluster...on the back I will see the small twistable prongs that hold the bulbs (4 I think it is) and swap the bulbs :thumbsup:
    ^^^this, have u checked the dimmer switch? I've had some people complain that their cluster doesnt work after a swap and their dimmer switch was all the way down :facepalm:
  6. Jun 1, 2012 at 10:16 PM
    Hektor
    Texas
    Yes i checked the dimmer. Also Im gonna check the gauge fuse.
  7. Jun 1, 2012 at 10:18 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    If its only one section of the gauges then its not the fuse, unless the whole dash is out then ya it can be
  8. Jun 1, 2012 at 10:29 PM
    Hektor
    Texas
    It is the whole dash !!!! Fuse is fine tho. Hoe hard is to take the dash apart??
  9. Jun 1, 2012 at 10:44 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    The 2nd gens are pretty easy, I heard the 1st gens are about the same
  10. Jun 1, 2012 at 11:01 PM
    1C271
    1C271 Well-Known Member
    Tennessee
    2007 4x4 TRD Off Road
    1. DISCONNECT CABLE FROM NEGATIVE BATTERY TERMINAL
    2. REMOVE FRONT FLOOR FOOTREST
    3. REMOVE FRONT DOOR SCUFF PLATE LH (for Regular Cab)
    4. REMOVE FRONT DOOR SCUFF PLATE LH (for Access Cab)
    5. REMOVE FRONT DOOR SCUFF PLATE LH (for Double Cab)
    6. REMOVE COWL SIDE TRIM BOARD LH (for Regular Cab)
    7. REMOVE COWL SIDE TRIM BOARD LH (for Access Cab)
    8. REMOVE COWL SIDE TRIM BOARD LH (for Double Cab)
    9. REMOVE INSTRUMENT PANEL UNDER TRAY (for Pedal Type Parking Brake)
    10. REMOVE INSTRUMENT PANEL HOLE COVER (for Lever Type Parking Brake)
    11. SEPARATE HOOD LOCK CONTROL LEVER SUB-ASSEMBLY
    12. REMOVE LOWER NO. 1 INSTRUMENT PANEL FINISH PANEL
    13. REMOVE INSTRUMENT CLUSTER FINISH PANEL SUB-ASSEMBLY
  11. Jun 1, 2012 at 11:02 PM
    1C271
    Tennessee
    oops nevermind that is for a 2nd gen sorry don't have the first gen info
  12. Jun 1, 2012 at 11:24 PM
    Hektor
    Texas
    Dny worry thanks for trying to help. Does anyone has a how to remove the cluster on first gen??
  13. Jun 1, 2012 at 11:37 PM
    Hektor
    Texas
    yes but its not working. Does look hard to removed it?
  14. Jun 1, 2012 at 11:41 PM
    Hektor
    Texas
  15. Jun 2, 2012 at 7:23 AM
    Madjik_Man
    Colorado Front Range
    He did say his climate control and radio lights are working fine. Don't know if the 01-04 is different than the 98-00 but on my 98 the dimmer controls all dash lights (gauges, climate, radio).
    Not hard at all.
  16. Jun 3, 2012 at 5:19 PM
    krlang
    krlang NewEnglander
    Commonwealth of Massachusetts
    03 2WD 2.4L Tacoma Reg Cab
    Chrome Bumpers F&R, Grille & Corner Lights, Wheel Skins, Red/Clear LED taillights, Remote start, PDL, Cruise, K&N, All Kenwood, DNX-5120 6.1" NAV/TRAFFIC/DTV/DVD/XM/BLUETOOTH/USB/IPOD/SUB/rear cam, Tint, Air Band radio, Class 3 Hitch with 4/7 pin harness, Transmission Cooler, Red Top Battery, "Deck Plate" mod.
    If all the dash lights go out, why wouldnt you check the tail light fuse? Every car on the planet, the tail light fuse runs the dash lights, it is to let you know the tail lights dont work.
  17. Jun 7, 2012 at 6:35 PM
    Hektor
    Texas
    Thanks for all the reply's the problem was the bulb were burn. I had to exchange them. Now its fine.
