The Getaway...Crom's build and adventures
Discussion in '2nd Gen. Builds (2005-2015)' started by Crom, Feb 11, 2015.
  1. Oct 31, 2016 at 12:27 PM
    #2741
    scocar
    scocar hypotenoper
    Nice. I have a portable Viar that I like. At least the compressor. The hose/chuck sucked ass. Tossed it right away after garage testing. Swapped in Flexzilla hose and a Milton 503 HD inflator with locking chuck and gauge. The Flexzilla is sooo much better. However, the Milton, despite how HD and stout it is, I find the chuck awkward to use, and the gauge simply does not seem to register accurate air pressure when compared to my separate digital gauge By about 10 psi.
    So I've been staring at ARBs and wondering if they are more accurate on pressure reads. A portable is time consuming enough. To be dicking around with pressure measurements is unacceptable.
    How have you found the ARB gauge performs?
    Crom[QUOTED][OP] and ChadsPride like this.
  2. Oct 31, 2016 at 12:55 PM
    #2742
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I'm with you 100% First order of any air gauge business, is it has to be accurate in the desired range. I can't vouch for anybody else, but my ARB air gauge is spot on. To be fair though, I've only ever used it to 40 PSI , so can't comment beyond that. I like the dial gauge as well, easy to read.
    Too bad about the Milton. I really like their brass fittings. I think it was @DoorDing who got me to look into those, and the flexzilla air hose which I like, very easy to coil and store, yet very strong and durable.
    Overall the ARB is good, I'd still recommend it in it's stock form. Easy to store away too.
    My only issues were I wanted a stronger stouter lock on chuck, and more length. My mods more than doubled the cost of the chuck. That's okay though, because I now have exactly what I want, and no compromises. :D
    scocar[QUOTED] and ChadsPride like this.
  3. Oct 31, 2016 at 12:55 PM
    #2743
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    This looks like a nice upgrade. I need links......
    ChadsPride and Crom[QUOTED][OP] like this.
  4. Oct 31, 2016 at 1:09 PM
    #2744
    Crom
    Nick
    San Diego, CA
    Millions
    @scocar
    Another option for air chuck would be the one Ken is using @DVexile over here Supposedly very good from reviews.
    ChadsPride and scocar like this.
  5. Oct 31, 2016 at 1:22 PM
    #2745
    scocar
    scocar hypotenoper
    Good to know. Yeah, Door Ding turned me onto the Milton, too. It was a real disappointment. I just need the damn thing to be accurate up to about 32 LOL or maybe a bit more for full loads when towing at higher speed. I already dicked around with multiple NPT fittings to rig the flexzilla and Milton to the Viar, and I have no issues doing it again for the intended result. Just found a pic of mine.
    The Milton is also bulky and heavy, so the more compact ARB form factor would be a bonus for fitting the entire kit into the Plano shooter's box I'm going to use. I have two: one for towing/hitch gear, and the other for OBA. The portable Viar on its skid plate fits perfectly inside. I'll just need to use a hole saw or Dremel to cut a hole out of the lower of the two stacking trays tray to accommodate the top of the Viar cylinder.
    This is the same box in my 2001, just to give you a sense of scale. The two horizontal black bands are the two stacking trays.
    Soul Surfer and ChadsPride like this.
  6. Oct 31, 2016 at 1:28 PM
    #2746
    scocar
    scocar hypotenoper
    That appears to be worth looking into, also. Thanks.
  7. Oct 31, 2016 at 2:47 PM
    #2747
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    For reference, coming from the engineer that designed the Compressor/Cascade Storage system for breathing air in the scuba shop that i worked for, Dial gauges are most accurate right in the middle of their range, so you want to match the gauge so that the range you normally use is right in the middle of the gauges range.
    scocar, ChadsPride and Crom[OP] like this.
  8. Oct 31, 2016 at 2:53 PM
    #2748
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    In case you need it in the future, I got an adapter for 1/8" BSP to 1/4" NPT at Marshall's in Mira Mesa. Thanks for the link to the barb! I might go that route, too. So annoying to have that different threading to deal with.
  9. Oct 31, 2016 at 3:29 PM
    #2749
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    dam so clean! Thats a brute force right?
    When we gunna wheel man?
    ChadsPride likes this.
  10. Oct 31, 2016 at 3:47 PM
    #2750
    Pirhett
    Rhett
    San Diego
    Stock...
    sexy bed cage!!!!!
  11. Oct 31, 2016 at 4:08 PM
    #2751
    scocar
    scocar hypotenoper
    That Powertank goes from 0-60, and I'll hang out in the 15-40 range.
    I like the checkerboard register marks in1 psi increments. And it appears to get largely good reviews.
    Pirhett, Crom[OP] and ChadsPride like this.
  12. Oct 31, 2016 at 5:25 PM
    #2752
    odomandr
    Andy
    Fort Collins, CO
    Nick is there somewhere local that carried the flexzilla custom length and fittings or how did you source that?
  13. Nov 1, 2016 at 8:53 AM
    #2753
    Crom
    Nick
    San Diego, CA
    Millions
    Welcome.
    Good to know! Thanks.
    Marshall's Industrial Hardware - “Marshall's Industrial Hardware has EVERY type of speciality nut, bolt, washer, screw, or what you thought was only a custom made fastener.”
    Very good! Thanks, did not now about them, I'll remember that if I'm in a bind and need something fast.
    I ordered two fittings for the mod, the second one worked: Google search: 8mm OD Hose Barb 9.5mm 1/8BSP Brass Coupler
    It's a metric fitting and should work with any 1/4" airline. I used a size 4 stainless hose clamp to bind it together.
    I didn't have any 1/4" air hose in stock, so I ordered 25' new, then cut to desired length for air chuck, then repaired the longer section of hose by adding 1/4" MNPT to 1/4" hose barb.
    Yes. Thanks.
    Wish I had time.
    First shift, Work
    Second shift, Family
    Third Shift, Sleep / truck work
    It's only getting more difficult for me with my kids schedules, both of them are now enrolled in Fall Saturday activities.
    :ballchain:
  14. Nov 1, 2016 at 8:57 AM
    #2754
    scocar
    scocar hypotenoper
    The nice thing about Flexzilla is it is totally customizable and field repairable with common hand tools, FTMFW.
  15. Nov 1, 2016 at 9:18 AM
    #2755
    scocar
    scocar hypotenoper
    Soooooo.
    I just had an idea.
    I know I know, don't everyone freak out.
    How about a California regional hardware and supply thread. List our favorite local stores for hard-to-find or other bits and pieces awesomeness not offered by the big boxes. Not only for general garage use, but for those of us who find ourselves way out of our neck of the woods and needing a solution to save a trip.
    Google and Yelp are sorta OK, but not much better than box stores, and they won't really provide some of that nitty gritty Tacoma wonkiness that we all need and thrive on...
  16. Nov 1, 2016 at 9:21 AM
    #2756
    scocar
    scocar hypotenoper
    Just realized that there are two separate regional forums for California, North and South. I guess we could do one in each. But then who gets Bishop and Mammoth? Hmmm.
    ETAV8R and ChadsPride like this.
  17. Nov 1, 2016 at 9:49 AM
    #2757
    HeavyThumbs
    HeavyThumbs Well-Known Member
    Phoenix, AZ
    2015 MGM TRD 4x4 OR AC
    Snugtop shell, group buy addiction
    This would help me out if it was easy to find. I'm in AZ, but spend a good amount of time roaming around CA.
  18. Nov 1, 2016 at 10:03 AM
    #2758
    Bman4X5
    Bman4X5 There is no substitute for square inches.
    Bruce
    Upland CA
    '15 AC/OR
    Bilstein, Dakar/Icon, Prinsu, CBI, Pelfreybilt, Tepui
    So Cal Bolt and Supply in Upland has literally every fastener you could possibly need.
    Biscuits, ETAV8R, Drainbung and 2 others like this.
  19. Nov 1, 2016 at 10:29 AM
    #2759
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    I use DMP. They're in Chattsworth and specialize in automotive and race applications. Lots of odds and ends too for other truck related projects (wiring, heating/cooling, hydraulic fluid transfer, brakes etc...)
    http://www.dmpfasteners.com/index.php?id=1
  20. Nov 1, 2016 at 10:32 AM
    #2760
    Crom
    Nick
    San Diego, CA
    Millions
    I like the sound of these stores! lol
