The Getaway...Crom's build and adventures
Discussion in '2nd Gen. Builds (2005-2015)' started by Crom, Feb 11, 2015.
  1. Nov 1, 2016 at 10:58 AM
    #2761
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    I've always figured Bishop and Mammoth as Nor Cal. :notsure:
  2. Nov 1, 2016 at 1:10 PM
    #2762
    scocar
    scocar Patron of the Farts
    I'd like to claim them too. :thumbsup:
    ChadsPride likes this.
  3. Nov 1, 2016 at 1:42 PM
    #2763
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    LOL apparently you guys haven't seen all the LADWP ownership in the valley
    :lalala:
  4. Nov 1, 2016 at 1:48 PM
    #2764
    scocar
    :quickdraw:...literally
    ChadsPride and ETAV8R[QUOTED] like this.
  5. Nov 1, 2016 at 2:24 PM
    #2765
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    :ballchain:
    Wishin' I was somewhere else!
  6. Nov 1, 2016 at 2:41 PM
    #2766
    Crom
    Nick
    San Diego, CA
    Millions
    @inv3ctiv3 Very nice indeed. Weather should be good... I'm going nucking futs! need to keep it together for a few more weeks before i can get out.
  7. Nov 1, 2016 at 3:17 PM
    #2767
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    yeah, that one should do well seeing as the middle of the range is where most people inflate tires too.
    Tell me about it, I havent gotten to do anything fun for two months now and im losing my mind
  8. Nov 1, 2016 at 3:34 PM
    #2768
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Bahaha, there is that...
    Dalandser and ChadsPride like this.
  9. Nov 1, 2016 at 5:57 PM
    #2769
    OdinBow
    OdinBow Just an idiot out wandering around CO.
    Mitch Cumstein
    Erie, CO
    2011 Timberland Mica T|X Pro
    None, but willing to learn.
    Progress is looking good on your rig!! :thumbsup:
    So I thought I'd provide an brief update: put the 3.5* shims in. Jack shaft and pinion angles are the "same" (within laying on your back under a truck accuracy). I have more vibes now than when they were 1* apart. I'm going to attribute this to axle wrap as most vibrations occur on takeoff. So, the 2.5* shims are going back in. I may entertain going to 2* shims if I can't live with what the 2.5's are providing.
    ChadsPride and Crom[OP] like this.
  10. Nov 1, 2016 at 6:33 PM
    #2770
    Crom
    Nick
    San Diego, CA
    Millions
    Thanks for reporting back! I think I may crawl under tonight with headlamp, and measure. Since adding the bumper, gate, and spare, my take off shudder calmed down quite a bit. I can't feel any other unwanted vibes up to 75.
    What angle finder are you using, and what method to measure pinion? Just curious. Thanks Jason. :)
    ChadsPride and nfs257 like this.
  11. Nov 1, 2016 at 7:25 PM
    #2771
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    I'm having trouble with the rear upper flare nuts that are attached to the frame bracket. I started using the flare nut wrench that you recommended (arrived today) but the nut "feels like" it was starting to round up the corners of the nut head. Not wanting to completely round off the nut, I stopped to take a deep breath, re-assess and re-evaluate and ask for advice.
    I feel like the 10 mm Flare nut wrench seems a little loose around the nut. The 9 mm won't fit at all. It seems like if the wrench was 9.5 mm if would fit perfectly snug and not round off the nut. But I don't think a 9.5 mm wrench exists.
    I believe my immediate next step would be to PB Blast the hell out of the flare nuts for the next few days and then try again.
    Any input from the relatively sane Crom Club before I screw this up?
  12. Nov 1, 2016 at 7:31 PM
    #2772
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    They are a PIA no matter how you do it. Some have went back along that hard line and replaced the whole thing... Others like my self have said screw Flare nut wrenches and used 2 pair of Vise grips. But the way the factory puts them on it too tight and is liable to strip the threads no matter what.
  13. Nov 1, 2016 at 7:31 PM
    #2773
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    9.5mm = 3/8th inch
    ChadsPride, Crom[OP] and nfs257 like this.
  14. Nov 1, 2016 at 7:41 PM
    #2774
    Subway4X4
    Lloyd
    NY/NJ
    SAE Flex Head Flare Nut Wrench set ordered!!!!
    Thanks.
    ChadsPride and Biscuits[QUOTED] like this.
  15. Nov 1, 2016 at 7:42 PM
    #2775
    Biscuits
    I used a flare nut wrench to replace my brake lines, but I did not skimp out on the flare nut wrench set I bought: SK Professional. Otherwise, judging from the difficulty I had even using quality tools I would have had to use two vise wrenches. Even then, using two vise wrenches may ultimately be easier.
    I agree, the effort required to remove the brake lines from the factory is ridiculous.
  16. Nov 1, 2016 at 7:44 PM
    #2776
    Biscuits
    Happy I could help.
    I started buying tools in both metric and SAE sizes whenever possible. Redundant perhaps, but I can't tell you how many times I've swapped between the two for a better fit.
  17. Nov 1, 2016 at 7:47 PM
    #2777
    Subway4X4
    Lloyd
    NY/NJ
    That hardline up along the frame rail seems like a tough thing to replace. First I'll try the PB Blaster route and a 3/8" wrench.
    Damn. I need this truck for a planned wheeling trip this weekend. I installed full leaf Dakars w/AAL this past weekend. If I don't replace the stock length brake lines, I have a feeling it might just get pulled out/stretched out when I dump the wheel into a hole and go full droop.
  18. Nov 1, 2016 at 7:51 PM
    #2778
    OdinBow
    Mitch Cumstein
    Erie, CO
    Ha! I'm using the iHandy Level free app on my phone. It has a plum bob feature you can calibrate to zero. I do a lot of double checks to make sure I get a good sampling of measurements. Not super scientific but it works. At the end of the day it's gonna be what it's gonna be no matter what the measurements are. I got mine close to equal and that's not the right answer for my set up so I'm gonna keep at it. :cool:
  19. Nov 1, 2016 at 7:51 PM
    #2779
    Biscuits
    For what it's worth, I use Kroil at work when I have to break decades-old frozen nuts & bolts. Beats the shit out of PB Blaster in my experience.
    Maintenance and I will keep a stock of a dozen cans at any given time.
    HB Taco, DrFunker, ChadsPride and 2 others like this.
  20. Nov 1, 2016 at 8:12 PM
    #2780
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    You might also try pecking on the wrench with a hammer rather than turning it by hand. PB + flare nut wrench + pecking took my 15 year old lines loose very easily.
