The Getaway...Crom's build and adventures
Discussion in '2nd Gen. Builds (2005-2015)' started by Crom, Feb 11, 2015.
  1. Dec 20, 2016 at 11:48 AM
    #3041
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    The truck shop. Out here in San Diego.
    Crom[OP] and ChadsPride like this.
  2. Dec 20, 2016 at 11:53 AM
    #3042
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Very interesting, moar pictars Crom? Would like to see the other side
  3. Dec 20, 2016 at 12:20 PM
    #3043
    nfs257
    DFW
    She gone
    Lembowski's old build thread is where this originally came from.
  4. Dec 20, 2016 at 12:28 PM
    #3044
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    @2ndGenJonny
    Design and fabrication by "The Truck Shop" in San Diego, cost was $250. Less than 24 hour turnaround!
    Stronger than the TC gussets, with none of the compromises.
    I'll get more pics of the other side soon. If you go back to page 66 of my build, you can see where we discussed it last year.
    I feel like Jake and Elwood right now, the Blues Brothers, on a mission from God, rebuilding the front end as fast as can be.
    Gotta run across town for an OEM front axle takeoff!
  5. Dec 20, 2016 at 12:34 PM
    #3045
    2ndGenJonny
    Jon
    Gilbert, AZ
    Im a TC guy, but also a vendor. These look good tho.
    Im with you on the front end. All im missing is a tower cross brace, I have all the other gussets.
    ChadsPride likes this.
  6. Dec 20, 2016 at 12:56 PM
    #3046
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Voted, good luck in the popularity contest.
    DrFunker, Crom[OP], XPOTRON and 3 others like this.
  7. Dec 20, 2016 at 3:38 PM
    #3047
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    You had me at
    Done!
  8. Dec 20, 2016 at 3:51 PM
    #3048
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR
    Voted Nick! :thumbsup: Good Luck!!
    Crom[OP], ChadsPride and jubei like this.
  9. Dec 20, 2016 at 9:46 PM
    #3049
    DaVikes
    DaVikes Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    I voted for Nick too. He's been so generous with his time on TW.
    Soul Surfer and Crom[OP] like this.
  10. Dec 20, 2016 at 11:02 PM
    #3050
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    I too voted for you sir.
  11. Dec 21, 2016 at 7:02 AM
    #3051
    Crom
    Nick
    San Diego, CA
    Millions
    Just wanted to say thank you to each of you. :hattip:. :fistbump:
    After today, my truck will have a fully rebuilt front end. In essence, resetting the heavy maintenance clock forward a number of years. In conjunction with all the other work I've done this year, I really feel like I've got a shot.
    :burnrubber:
    Here's what's on deck for today:
    Here is my front end list.
    • Spindle gussets,.
    • Install spindles
    • Clean and grease UCA's
    • Replace torn Moob UBJ boot
    • Install fully rebuilt factory performance LCA's
    • Install Bilstein 6112's coilovers
    • ECGS Diff Bushing
    • Front brake lines, and replace brake line tubing
    • New Toyota Front brake rotors
    • New Toyota Front brake pads
    • New Toyota axle (drivers)
    • New hubs/ Wheel bearing assembly, both sides
    • New inner tie rods
    • New outter tie rods
    • Alignment.
  12. Dec 21, 2016 at 7:12 AM
    #3052
    2ndGenJonny
    Jon
    Gilbert, AZ
    Good call on going with OEM on the brakes. Spending the cash on EBC isnt worth it.
  13. Dec 21, 2016 at 7:57 AM
    #3053
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Doh! I did radio you ahead of time that section was coming!
    Well at least if that was the case you blew it out right before redoing the whole front end anyway :)
    So far I think my alignment tabs and bolts are OK. Drivers rear side cam is a bit out of adjustment now based on witness marks I put on after alignment. On my to do list is to correct that and apply anti-seize at the same time. Need to do a tire rotation so will probably do all that at the same time.
    Have a good day wrenching!
  14. Dec 21, 2016 at 8:01 AM
    #3054
    Soul Surfer
    Jimi
    ‘25 TRD OR
    Welcome! :hattip:
    Crom[QUOTED][OP] and ChadsPride like this.
  15. Dec 21, 2016 at 9:22 AM
    #3055
    Crom
    Nick
    San Diego, CA
    Millions
    Thank you.
    You did fabulous calling them out on the radio. :) It was me.
    It turns out I damaged a second cam. I didn't catch it on dissembly. I'm putting it back together and I found the plate was loose against the bolt, fortunately I already have a replacement in hand from dealer.
    If you're going to go through the trouble of greasing the cams, I strongly recommend the total chaos cam tab gussets. I'm sure we can hook up a mobile welder for you to burn them on. Easy job. It's worth the $80, plus welding cost, IMO.
    I'll help if need be.
    Biscuits, samiam, Soul Surfer and 3 others like this.
  16. Dec 21, 2016 at 10:06 AM
    #3056
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Voted. Nick is my go-to for a lot of the stuff I've done to my truck. And the notion of modding the OEM LCAs for strength (rather than going aftermarket) receives my nomination for Idea of the Year. Alas, there is no thread for that.
  17. Dec 21, 2016 at 10:06 AM
    #3057
    DVexile
    Ken
    Thanks, I'll look into those! I'll probably do the anti-seize when I've got the truck on a lift for tire rotation - anti-seize looks like it takes no time at all. If I do the gussets I'll save those for when I do weld on sliders some day. So many mods, so little time...
    ChadsPride and Crom[QUOTED][OP] like this.
  18. Dec 21, 2016 at 10:10 AM
    #3058
    Crom
    Nick
    San Diego, CA
    Millions
    Thanks Eric! Welcome.
    Member of the year? lol
    Would be nice to win something for all my efforts.
    In the grand scheme of things the contest are kind of silly but the prizes are nice. I looked at it as a shortcut to finish my build, and really it's just a popularity contest, and I've never done one of those and don't expect to win now.
  19. Dec 21, 2016 at 10:12 AM
    #3059
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Double Crom vote might be a bridge too far for me. I still have to live up here. :D
  20. Dec 21, 2016 at 10:17 AM
    #3060
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    You get vote too. Interested in your feedback on the poly LCA bushings after you get them in obviously. With ~160k on my FJ it's probably about time they get replaced.
