The Getaway...Crom's build and adventures
Discussion in '2nd Gen. Builds (2005-2015)' started by Crom, Feb 11, 2015.
  1. Dec 22, 2016 at 6:04 PM
    #3081
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Yup. You need one?
    ChadsPride likes this.
  2. Dec 22, 2016 at 6:20 PM
    #3082
    bski22
    bski22 Shaka Zulu \000/
    Rob
    Toyota
    Was chatting with some guys from out west recently. All were fabricators and I was telling them about my mounting issues with front bumpers. Basically it all came down to the OEM factory front body mount bushings. I'll take a pic in the morning now that my bumper is off. Those things are squished AF. Driver side has 1/4 shim. Sits perfect now.
  3. Dec 22, 2016 at 6:47 PM
    #3083
    ecgreen
    ecgreen overeducated redneck
    Sean
    2015 4x4 4-banger Access
    Love the build!
  4. Dec 22, 2016 at 6:54 PM
    #3084
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Naw. Got one. But wondering why you won't get the "lean" if you don't use yours.
  5. Dec 22, 2016 at 6:58 PM
    #3085
    Crom
    Nick
    San Diego, CA
    Millions
    Bumpers mount to the frame horns. There are 6 bushings that isolate the cab from frame, four cab mounts, and two for core support (radiator). I've replaced them all with poly.
    I'm assuming your referring to the core support ones. My opinion is that the factory core support ones are too weak and small and should be replaced. It is not uncommon for them to tear, rip or outright collapse. They affect fender to bumper clearance which is probably what your issue is.
    My advice is get the energy suspension Universal kit very well worth the $25.
    Please see the links below for pictures and description.
    Energy Suspension performance polyurethane radiator support bushings, Aug 2015
    Energy Suspension Tacoma Body bushing kit, Aug. 2016
  6. Dec 22, 2016 at 7:02 PM
    #3086
    bski22
    Rob
    Toyota
    Wow dude spot on. Just schooled me
  7. Dec 22, 2016 at 7:11 PM
    #3087
    bski22
    Rob
    Toyota
    Ordered. Install next week. Thanks heaps Crom!
    GHOST SHIP, uurx and ChadsPride like this.
  8. Dec 22, 2016 at 8:00 PM
    #3088
    Crom
    Nick
    San Diego, CA
    Millions
    Thank you very much. :)
    Oh my truck leans... It used to real bad when truck wasn't carrying a load. In addition to the gas tank , starting battery, and other stuff that contributed to the standard taco lean, I had ARB twin compressor, auxiliary battery, fire extinguisher, water, etc. All on driver side. ARB fridge, and swing gate with tire on passenger side help balance it out some.
    I guess what it boils down to is function over form for me.
    Welcome.
    Your truck will thank you.
  9. Dec 23, 2016 at 9:06 AM
    #3089
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Outstanding!
    ChadsPride and Crom[QUOTED][OP] like this.
  10. Dec 23, 2016 at 9:20 AM
    #3090
    Crom
    Nick
    San Diego, CA
    Millions
    Thank you Sir!
    :D
    HBMurphy[QUOTED] and ChadsPride like this.
  11. Dec 23, 2016 at 5:43 PM
    #3091
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    Have you ever run across anyone that has taken the actual travel measurements on the Dakar's doing it the "right" way? I've googling around on and off for a couple days and searching on here and I can't find anyone that's actually done it and posted it. You'd think with all the people using them someone would have done it.
    Crom[OP] and ChadsPride like this.
  12. Dec 23, 2016 at 5:59 PM
    #3092
    ecgreen
    Sean
    Whats the "right" way?
    I'd be interested to know the average travel of dakars myself.
    Crom[OP], Sandman614 and ChadsPride like this.
  13. Dec 23, 2016 at 6:12 PM
    #3093
    tetten
    Andy
    Socal
    As I understand to check "true" uptravel you have to disassemble the pack, reinstall just the top leaf and compress it. I could definitely be wrong on that as I have never done it before and haven't run across a written+photographic guide on how to do it.
    2ndGenJonny and ChadsPride like this.
  14. Dec 23, 2016 at 6:16 PM
    #3094
    tetten
    Andy
    Socal
    I believe it establishes the upper limit of your leaf pack movement, so you don't bottom out and damage your shock. Once again, I am not certain of all of this, I have never seen someone write out and photograph the entire process.
  15. Dec 23, 2016 at 6:17 PM
    #3095
    ecgreen
    Sean
    Wonder why they do this? Wouldn't you want to know the up travel with a fully assembled pack, since that is how its used? Sorry, dont know much about this topic.
  16. Dec 23, 2016 at 6:26 PM
    #3096
    tetten
    Andy
    Socal
    I'm not completely certain, but taking measurements on a flat level surface (like in a garage) with a full leaf pack wouldn't account for real world scenarios like driving up a steep incline with the rear articulated, a great deal of weight would shift to the rear and compress the leafs more than on a level surface.
  17. Dec 23, 2016 at 6:26 PM
    #3097
    Crom
    Nick
    San Diego, CA
    Millions
    The right way to cycle leaf suspension is to use main spring only and a block of aluminum or wood under it equal to the height of missing leaves. The reason for this is the main spring governs what is possible. It's the best way to check for clearance issues.
    Also of value is to measure eye to eye with string and take vertical perpendicular measurement from center pin to string.
    No.
    I've never seen anyone do this on TW. It's a lot of work and it's my opinion that most people just want beefier leaf pack to carry loads, or support additional expo weight etc.
  18. Dec 23, 2016 at 6:27 PM
    #3098
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Uptravel is defined by the main leaf. Once it is flat that is where bump should be set. A fully assembled pack will still go flat at the same point it just takes more force to do so. Therefore stripping it down makes it an easy task for checking.
  19. Dec 23, 2016 at 6:29 PM
    #3099
    tetten
    Andy
    Socal
    I have read in a couple places that the Dakars are designed to go negative, is that a thumb rule for all leaf packs?
    I can actually make my Dakars go negative with a full leaf pack with just a floor jack.
  20. Dec 23, 2016 at 6:42 PM
    #3100
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Any pack can go negative. You just lose life expectancy on it doing so since it deforms the metal opposite the initial arch.
    My leaf pack I can't do that. Your Dakars must be pretty soft.
