The Getaway...Crom's build and adventures
Discussion in '2nd Gen. Builds (2005-2015)' started by Crom, Feb 11, 2015.
  1. Mar 1, 2017 at 11:47 AM
    #3661
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    Bruteforce fab.
  2. Mar 1, 2017 at 11:48 AM
    #3662
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Check the first page of his build, it's all incredibly organized with hotlinks.
  3. Mar 1, 2017 at 4:08 PM
    #3663
    drf96097
    drf96097 Member
    Daniel
    There's a guy on here who did that with his rear bumper. The license plate had a hidden storage compartment behind it using all the space where the tire used to be.
    Crom[QUOTED][OP] and ChadsPride like this.
  4. Mar 3, 2017 at 11:22 AM
    #3664
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    so, how did you go about the P/S flush, I'm definetly due for that service, pretty sure the fluid is nice coal black color
    Drainbung and ChadsPride like this.
  5. Mar 3, 2017 at 11:43 AM
    #3665
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Don't know what Nick did specifically, but it is an easy job that requires no special tools beyond a turkey baster. Few write ups around, this one with some pictures:
    https://www.tacomaworld.com/threads/power-steering-fluid-flush.396536/
    This one nice and concise:
    https://www.tacomaworld.com/threads...ng-fluid-recommendations.161749/#post-3300191
  6. Mar 3, 2017 at 11:54 AM
    #3666
    Gaunt596
    Matthew
    Central Maryland
    ChadsPride likes this.
  7. Mar 7, 2017 at 10:47 AM
    #3667
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    This is such a great idea. I have a plan to try this, I'd like to mount my fridge slide directly to small sections of track mounted like what you've done using one of their threaded stud attachments (that is if I can get the slide to line up with the track just so...) Do you have any pointers on how to line up the cuts in the bed mat with the tracks?
    xsf18cdf and ChadsPride like this.
  8. Mar 7, 2017 at 6:02 PM
    #3668
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
    Any write up on what you did to seal up your shell? My old leer is leaking i think in similar areas :/
  9. Mar 12, 2017 at 12:21 AM
    #3669
    Zebinator
    Zebinator Well-Known Member
    Norcal
    06 Tacoma TRD Offroad
    I want to make something like this, but i think it's seriously beyond my skill level!
  10. Mar 12, 2017 at 12:37 AM
    #3670
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    4WDTrout and ChadsPride like this.
  11. Mar 12, 2017 at 12:38 AM
    #3671
    Zebinator
    Norcal
    Mr. Crom,
    First - this is an amazing thread. I've been back a bunch and have many posts flagged for when i get around to more suspension changes, compressor install, etc etc! Thank you for all your hard work! I do have a quick question. I am also trying to shoe-horn a 255/85-16 in the stock location. I've hacked off the tailpipe mount, and have whacked the tabs back up and am about to move the elevator, but when i test fit the tire up there, it looks like it is still going to get hit by the filler plug on the diff. How much clearance did you end up with? And, is that the stock hitch attachment? Did this get better/worse with your new rear bumper?
    Ok - that was three questions. Cheers!
    ChadsPride and Drainbung like this.
  12. Mar 14, 2017 at 5:49 AM
    #3672
    Adventurous
    Adventurous Well-Known Member
    Colorado
    15 DCLB SR5
    I have a ratchet strap around the trailer hitch and pulled the tire back as far as it can go before using the elevator to pull it up. I've never noticed any rubbing under compression with the plus side being I now have a ratchet strap with me at all times in case I ever need it.
  13. Mar 14, 2017 at 7:21 AM
    #3673
    Zebinator
    Norcal
    Yes - i will be using a ratchet strap. Good idea!
  14. Mar 16, 2017 at 3:41 PM
    #3674
    SoJersey
    SoJersey South Jersey Defense
    Brandon
    08302
    '12 DC Offroad
    Pelfrey Armor Baja Designs Lights 6112/Camburg/Dakar Suspension Method Wheels / BFG KO2 ARE Z-Series More coming soon...
    Those Whiteline bushings, do they come with new outer sleeves? I'm in need of doing the LCA bushings, cams, and bolts and I want to make sure I have everything needed.
  15. Mar 16, 2017 at 3:45 PM
    #3675
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Yes they do.
  16. Mar 16, 2017 at 3:50 PM
    #3676
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    Ok thank you. So I'll have to torch, cut, or press out the old and pop these in. Perfect.
  17. Mar 16, 2017 at 3:52 PM
    #3677
    GHOST SHIP
    GHOST
    I'd say try the press out method first using your bottle jack. Heating the outer sleeve slowly and evenly should expand it enough for them to literally and audibly pop right out. If that fails, go ape!
    bjs045 and ChadsPride like this.
  18. Mar 16, 2017 at 4:24 PM
    #3678
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    Sounds good. I'll give that a shot! I have one seized and have to replace both front cam tabs that are flattened. So I'm going to do all 4 bushings and all 8 tabs while I'm there.
    Thanks for the help sir.
  19. Mar 19, 2017 at 10:05 AM
    #3679
    SoJersey
    Brandon
    08302
    '12 DC Offroad
  20. Mar 21, 2017 at 6:30 AM
    #3680
    bski22
    bski22 Shaka Zulu \000/
    Rob
    Toyota
    Crom.. what did you torque your leaf springs down to? 89ftlbs as spec'd? The reason is I'm getting some nice barn door creaking from these as the poly rubs on the mounting bracket. Wondering if lowering the torque will free up some tension.
