The Getaway...Crom's build and adventures
Discussion in '2nd Gen. Builds (2005-2015)' started by Crom, Feb 11, 2015.
  1. Jul 9, 2018 at 1:44 PM
    #4141
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    @samiam lol which one, water or power? :D
  2. Jul 9, 2018 at 1:47 PM
    #4142
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    I'm going solar to power a fridge. I've been checking out your setup over the past week.
    Crom[QUOTED][OP] likes this.
  3. Jul 9, 2018 at 2:00 PM
    #4143
    Crom
    Nick
    San Diego, CA
    Millions
    :thumbsup:
  4. Jul 9, 2018 at 2:03 PM
    #4144
    samiam
    Sam
    Stinky Vegas
    But I haven't told the wife yet so we'll see how long it takes her to notice.
  5. Jul 9, 2018 at 3:50 PM
    #4145
    scocar
    scocar hypotenoper
    Ideally, the entire truck will last much longer if you keep it out of the sun in a cool, dry place, too.
  6. Jul 9, 2018 at 4:34 PM
    #4146
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Crom[OP] and INBONESTRYKER like this.
  7. Jul 9, 2018 at 7:58 PM
    #4147
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Pfft. Amateurs.
    http://carcapsule.com/
    Crom[OP] and Drainbung like this.
  8. Jul 9, 2018 at 8:38 PM
    #4148
    GHOST SHIP
    GHOST
    A tomb is a tomb.
    Crom[OP], Drainbung and DoorDing like this.
  9. Jul 9, 2018 at 10:48 PM
    #4149
    Crom
    Nick
    San Diego, CA
    Millions
    Yeah I keep thinking of getting a car cover for the truck. Wish I had covered parking, but too much shit in the garage at the moment. Need a few weekends, or one long one to throw away, or donate everything in the way. :rofl:
  10. Jul 19, 2018 at 2:31 PM
    #4150
    Crom
    Nick
    San Diego, CA
    Millions
    My CTEK MUS 4.3 battery charger in recondition mode took about 28 hours to bring the aux battery back! It worked, I was so happy. Even though it was only two years old I decided to replace with new, only $74 plus tax, no core charge, and I kept the old battery for projects around the house. :)
    I repaired my solar panel and reinstalled array on roof rack. I installed battery and completed all electrical work.
    Water tank went back into its place as well.
    I also gave the truck a badly needed wash.
  11. Jul 19, 2018 at 5:33 PM
    #4151
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    And can you link the Crom stuff so we can Crom-atize our stuff?
    Axion, Crom[OP], Bruce988jl and 2 others like this.
  12. Jul 25, 2018 at 12:21 PM
    #4152
    Crom
    Nick
    San Diego, CA
    Millions
    Yes. No picture can explain really, but what I did was I took the three conductors from the three solar panels and soldered them together and used a bit of heat shrink tubing, and used a 2-pole SAE connector to finish it off. Then I routed the power cable through the backside of the roof rack, and through a hole in the PVC mat that the panels rest on. All the wiring is in split wire loom. It's basically waterproof at this point, everything is concealed, and I'll never again have to worry or maintenance it.
    I only spent $2.50 for the 2-pole SAE connector at Oriely, eveyrthing else was in my garage. :D
  13. Jul 25, 2018 at 12:24 PM
    #4153
    Crom
    Nick
    San Diego, CA
    Millions
    How dark is before the dawn!
  14. Jul 25, 2018 at 12:30 PM
    #4154
    Crom
    Nick
    San Diego, CA
    Millions
    I got to spend some time working on the truck this weekend.
    I made the last and final bombproof mount for my ABS pipe.
    • 36" x 1" x 1/8" Alum angle, quantity=2.
    • Custom drilled
    • Acid bath before rinsing & painting.
    • Zinc plated carbon steel u bolts 1/4" for grabbing Yakima bars
    • Custom 5/16-18 threadded rod bent up for holding down ABS pipe.
    • All hex nuts glued in place with thread locker.
    • Bombproof
  15. Jul 25, 2018 at 12:35 PM
    #4155
    Crom
    Nick
    San Diego, CA
    Millions
    I cut about 1" out of the Brute Force Hidden hitch. I cut a little bit more than the photo shows. This was done so I could put my 33" spare tire back under the truck and not have the tire interfere with the diff under compression. This was a success, spare fits now!
    I fucked up with my angle gridner and nipped the air line. No big deal though. I cut out the damaged section, and rerouted out the driver side bumper. Only 10 minutes time to fix. :)
  16. Jul 25, 2018 at 12:44 PM
    #4156
    Crom
    Nick
    San Diego, CA
    Millions
    I bought a cargo box for the roof rack. Inno Ridge Rooftop Cargo Box - 8 cu ft - Gloss Black. I've always wanted to try one. I got the smallest and lightest one, 8 cubic feet @ 20 lbs, made in Japan. Good quality and really perfect for my needs.
    Spare tire moved under truck, mounted Hi-Lift on swing gate. I'll detach spare tire mount from gate and put in garage. In it's place I'm going to make some custom mounts for a couple tables and chairs I think.
    The ubiquitous roof top cargo box adds instant value to any vehicle in form of additional cargo space.
    I bought mine last year and I choose the smallest model of Inno brand box. Made in Japan, very good quality. And complements the truck perfectly.
    It was for the same use case as you described, essentially bedding, pillows, etc. Bottom line is that it saves me time. It's very aerodynamic.
    Only one issue, and to be fair this probably goes for all boxes.
    In my opinion, they all need some reinforcement to hold up to the punishment of off-road travel.
    I got the box and quickly adapted some aluminum angle and u-bolts to make some custom-bomb-proof mounts that are rock solid and are precision fit to the Yakima bars.
    I also drilled the alum angle for tie down points that run the length of the box.
    Custom u-bolt / alum angle installed inside box
    Custom mounts for cargo box, inside view
    I am extremely pleased with it.
  17. Jul 25, 2018 at 1:53 PM
    #4157
    s.e.charles
    s.e.charles Well-Known Member
    I've only gotten a few posts into this thread (very interesting & innovative - bye the bye), and was hoping someone could share what the fold out with the piston is for? I won't consider it a "spoiler alert" if it's explained later in the thread. thanks
  18. Jul 25, 2018 at 3:08 PM
    #4158
    Crom
    Nick
    San Diego, CA
    Millions
    Sure. That mod is called EZ Down tailgate assist (Custom), Oct 2016 The piston makes dropping the tailgate an easy affair
  19. Jul 25, 2018 at 3:14 PM
    #4159
    Crom
    Nick
    San Diego, CA
    Millions
    Yeah, the swing gate is nice, but it can be pain if you have to get back there frequently. Best thing I like about the swing gate is easy access to stuff in the basket and the fold down table. In my case I plan to make a mount for some camp chairs, awning poles and some mini tables. What's really great is that none of it requires permanence. It's all gonna stay modular. So I can always revert to any other configuration based on what the trip entails.
    Yes. Double sheet metal in the corners. I actually have pics in this post: Astro Rivnut tool
    I married my tacoma and DoorDing like this.
  20. Jul 25, 2018 at 3:30 PM
    #4160
    s.e.charles
    thanks you. save to my ever growing list of "links to read".
