The Getaway...Crom's build and adventures
Discussion in '2nd Gen. Builds (2005-2015)' started by Crom, Feb 11, 2015.
  1. Sep 15, 2019 at 3:51 PM
    #4401
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Truck is back together, finally. I finished cleaning and greasing the LCA bushings and new washers went in. The passenger side Cam was slightly bent, I reused it anyway.
    For this side, I detached the lower shock bolt and disassembled LCA cams and propped the LCA up on some blocks of wood.. It was much easier/faster considering I didn't have to remove the shock like driver side.
    I indexed everything with match marks so when I reassembled, it was near perfect. An hour later had alignment.
    And where's Waldo, I mean my daughter. :D She is in this photo...
    We are ready for the next adventure!!! :)
  2. Sep 24, 2019 at 8:52 AM
    #4402
    Zebinator
    Zebinator Well-Known Member
    Norcal
    06 Tacoma TRD Offroad
    Mr. Crom, I'm gearing up to make my own tire carrier for the bumper i just bought... and am having a hard time finding great latch options. Curious if you could save me a ton of searching and share any marking or other identifying info for the latch on your swingout. Looks like some nice aluminum over-center gizmo. Yes?
    Crom[OP] likes this.
  3. Sep 24, 2019 at 9:06 AM
    #4403
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Crom[OP] and Zebinator like this.
  4. Sep 24, 2019 at 9:07 AM
    #4404
    Zebinator
    Norcal
    You are the best - thank you! I was looking at southco and only being shown the Reid products. Gah.. Anyway that helps a ton.
  5. Sep 24, 2019 at 9:12 AM
    #4405
    Scott B.
    Scott
    Georgia
    You're welcome.
    I have 2 of these latches just waiting to use - I've been planning my dual swing out for a while not. I need to set aside the time to build it.
    cubie and Crom[OP] like this.
  6. Oct 7, 2019 at 8:37 PM
    #4406
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
  7. Oct 16, 2019 at 2:35 AM
    #4407
    DrFunker
    DrFunker Well-Known Member
    Nick, where did you end up getting washers from? Mine need to be replaced for the same reason. Thanks.
    @Unchained 5150 check these posts out. This is where he talks about it.
    Crom[QUOTED][OP] likes this.
  8. Oct 16, 2019 at 4:01 AM
    #4408
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Thank you sir
    Crom[OP] and DrFunker like this.
  9. Oct 19, 2019 at 6:42 AM
    #4409
    Crom
    Nick
    San Diego, CA
    Millions
    White line sold me a packet of replacement washers for $15 delivered. I tried sourcing them on the market, but no luck.
    I took my truck out to desert for light Wheeling with family and truck performed awesome. Glad I did the maintenance. :proposetoast:
  10. Oct 19, 2019 at 6:49 AM
    #4410
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    You have a contact person or part number for them
  11. Oct 19, 2019 at 7:00 AM
    #4411
    Crom
    Nick
    San Diego, CA
    Millions
    No external part number was identified.
    The person I dealt with was:
    Mitchel Yardley
    Technical Sales
    Booth 21539
    1810 South Milliken Ave, Ontario CA 91761
    P:909. 476. 2860
    E:wlusa.sales@redranger.com | www.whitelineperformance.com
    Drainbung likes this.
  12. Oct 19, 2019 at 7:09 AM
    #4412
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Thank you sir, whatever the pictures are they won't load
  13. Oct 21, 2019 at 12:14 PM
    #4413
    Crom
    Nick
    San Diego, CA
    Millions
    OCT 2019 Anza-Borrego
    Rabbit & Villager Peaks
    I recently took my family on a mini trip to Anza-Borrego Desert SP. We enjoyed ourselves immensely, and it was a well deserved break from the daily routine of the fall term. In the picture my two daughters on Clark Lake.
    The photo frames two of my favorite desert peaks, Rabbit and Villager. They look perhaps unassuming in the photo-yet they are extraordinary. Rabbit is 6,000' and Villager 5,000' higher than the lake bed. I have spent years hiking and backpacking them. A round trip to Rabbit from the south ridge is a brutal 23.8 miles and 8,015' of elevation gain. Every drop of water must be carried, the human body tested in the extreme. Much blood, sweat, tears have been shed here, boots destroyed, gear failures. Legends forged...
    The mountains are sacred to the Kumeyaay band of Indians, who are native to the region. I suppose I've felt similar for as long as I can remember.
    It is said that the oldest rocks in the county are located in these mountains. The mountains are the result of a tremendous fault / rupture which results in tilting the earth at 45°. Hiking along the ridge for two days is dramatic to say the least.
    This picture is of the reverse, taken 10-years prior.
    Standing on Villager Peak, looking West and down at the dry Clark Lake, Coyote Mountain, and San Ysidro Mountains
    Words can do no justice to define the experience here.
    The perplexing Salton Sea & Imperial Valley viewed atop Villager, sunrise coming, circa 2009
    Will return.​
  14. Oct 21, 2019 at 1:58 PM
    #4414
    theick
    theick Well-Known Member
    Eric
    Las Vegas
    That's one of the things I love about Death Valley. Standing around Badwater and seeing Telescope peak over 11,000' higher than you.
  15. Oct 21, 2019 at 2:35 PM
    #4415
    Crom
    Nick
    San Diego, CA
    Millions
    100%
    I can't write like I used to, but last year this month after my joint trip with Andy @CVYota ended in Big Pine. :fistbump: my journey had a second leg. After I filled the tank in Big Pine, and headed south on US-395 I took CA-136->CA-190 back into the park. I traveled to the salt flats and journeyed out far where everyone disappeared. Time well spent. What an amazing time to be alive. Exited the park to the south on 31 miles of glorious dirt. Everyday spent trying to get back. :)
    Salt flats of the Earth​
  16. Oct 22, 2019 at 3:13 AM
    #4416
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    So glad you and the family made it out to a piece of a peace in the desert! Hope one day you get enough time back to be able to write about your adventures more...
    jubei, Drainbung and Crom[OP] like this.
  17. Nov 9, 2019 at 7:53 AM
    #4417
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    This is a dated reply, but another option would be to find a 2nd gen Hole Hawg (Milwaukee) in a pawn shop, or rent one. They have a clutch, or use a first gen but use it in 2nd gear, low speed will spin you like a top if it grabs. Also great for mixing paint, Sheetrock mud, or boring big holes through logs.
  18. Nov 27, 2019 at 12:37 PM
    #4418
    EverythingBurns
    EverythingBurns New Member
    Brandon
    4 door Tacoma 4x4
    I just got an RV/Camper 4-5 times that I have driven with it I felt drain on my Tacoma '10 4x4. What do I do Towing is 5,450 lbs., and my camper is 4,500. Can someone help me? What do I do, please...
  19. Nov 27, 2019 at 12:44 PM
    #4419
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    You may want to start a thread about it. Posting here isn’t really going to get you a lot of answers since this is someone’s build thread and your question isn’t exactly relevant here.
    I see you’re kind of new so welcome aboard also.
  20. Nov 27, 2019 at 7:43 PM
    #4420
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
