The Great Bronco Build
Discussion in 'Off-Topic Discussion' started by millertime89, Aug 6, 2015.
  1. Aug 6, 2015 at 9:32 PM
    millertime89
    millertime89 [OP] Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    Just curious if anyone here has or has had any experience with a Ford Bronco and lifting it? I know I can use a bronco forum but I like you folks and am pretty sure someone out there must've owned one.
    My grandpa and grandma has given my brother and I their '86 bronco and our plan is to build it up for the trails. Curious about lifts mainly, I've seen rough country come up a lot and I know their tacoma lifts are junk country. Also, I don't want a 6" lift, more along the lines of 4"'s.
    Feel free to toss in any experience you've had with the rig. I still like my taco better... :D
    Edit: I guess I'm going to keep track of the build in here, it's going to be slow for sure but the end result should be badass.
    Joe D likes this.
  2. Aug 6, 2015 at 10:47 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Sub'd to see the results :cool:
  3. Aug 7, 2015 at 7:44 AM
    millertime89
    Erik
    Saskatchewan
    Yes sir
    You might be here a while :D
  4. Aug 7, 2015 at 7:52 AM
    ZachPrerunner
    Southeast TN
    It's all good. It'll be worth it :rolleyes:
  5. Aug 7, 2015 at 8:09 AM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    I would check out these guys.
    http://www.threatmotorsports.com/TTBPackagedeals.html
    http://www.solomotorsports.com/
    you will be truly disappointed with a drop down kit, like rancho/rough country. do it correct and you will be able to use it as hard as you want.
    if you are not trying to increase the track width, look at the cut and turned beams. they will allow for something like a 2-4" coil, then team that with a good shock and you're dialed.
    Solo is very helpful and can walk you through most of the set up. Threat has really good pricing. They both make really good parts.
  6. Aug 7, 2015 at 8:10 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    subd.
    those old school broncos are nice.
    Joe D likes this.
  7. Aug 7, 2015 at 8:16 AM
    millertime89
    Erik
    Saskatchewan
    Yes sir
    Sweet! Thanks for the links, basically starting from the ground up on what's required for lifting and getting a bronco to perform correctly. I know my brother wants to do it right as well and 2 sources of cash should make it so cost isn't a huge deal haha.
  8. Aug 7, 2015 at 8:17 AM
    millertime89
    Erik
    Saskatchewan
    Yes sir
    My favourite bronco's are the '78-'79's but I mean, a free '86? Hell ya I'll take that and build it up!
  9. Aug 7, 2015 at 8:22 AM
    ramonortiz55
    Ramon
    Texas
    stock
    wait. youre in canada?
  10. Aug 7, 2015 at 8:22 AM
    ramonortiz55
    Ramon
    Texas
    stock
    hold on.
  11. Aug 7, 2015 at 10:32 AM
    Blze001
    Blze001 Breaks things.
    Virginia
    2013 TRD Sport DCSB
    I used to own a 1988 Bronco. Best college truck ever, especially in the midwest: American V8 with a removeable top? Let's just say it was the favorite ride to the lake for quite a few of the girls...
    Anyway, back to the topic at hand:
    #1) If you're gonna play with this truck a lot, the guys over at fullsizebronco are wizards with the machines. There's one guy running a Cummins 6BT, Dana-60 Bronco that is bananas. You wanna do it, they either have done it or know how to.
    #2) I was running a 2.5" Superlift. It went on in a weekend and didn't have a single problem. That said, if you're going over 3" you're gonna want to start looking at the non-cheap options... because the cheap ones get waaay out of their element the higher you go.
    #3) The "Bronco Graveyard" site is a lifesaver for these old trucks, this guy has all kinds of parts and panels available for them.
  12. Aug 7, 2015 at 7:27 PM
    millertime89
    Erik
    Saskatchewan
    Yes sir
    Yep, born and raised on the flat prairies. Dad grew up in Butte MT though. I am both an American and Canadian citizen :canada::oldglory:
  13. Aug 7, 2015 at 7:30 PM
    millertime89
    Erik
    Saskatchewan
    Yes sir
    Thanks man! Like I said, both my brother and myself are building it up, and I think one of my sisters wants in as well so that'd be 3 sources of cash to throw at the beast! :D I'm thinking around a 4" lift, at least 33's but I know I want 35's haha. Fuck it, at least 35's but I know I want 37's...? :D
  14. Aug 7, 2015 at 7:54 PM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Sub'd
    Had a '91 with 302 and E4OD as a DD and first truck.
  15. Aug 9, 2015 at 12:55 AM
    stlaw77
    stlaw77 Well-Known Member
    Alabama
    14 DCSB TRD OFF ROAD
    I had an '89 with a 302 and AOD transmission. I installed a Dick Cepek stage 2 drop down lift with extended radius arms. You could run it at 4" or 6". I had mine set at 4". I also had new leaf packs from Bronco Graveyard for 4" in the rear. The front was a major pain in the ass because all the original bracketry is held together with huge rivots that had to be grinded and punched out. It fit 35's with no rubbing. I regeared to 4.56 and installed a Detroit locker in the rear and Detroit Tru-trac in the front. That thing was a beast offroad. You really need extended arms for the front if your going to do much offroading with the I beam suspension.
    Joe D likes this.
  16. Aug 9, 2015 at 9:34 AM
    millertime89
    Erik
    Saskatchewan
    Yes sir
    Damn that's sick man, I'll check into that as well!
  17. Aug 10, 2015 at 4:32 AM
    Blze001
    Virginia
    2013 TRD Sport DCSB
    Man, you guys have clean trucks.
    My Bronco had a rust hole in the fender you could stick your hand through, the bottom of the tailgate was a giant hole, the hood was a nice solid brown from surface rust and I could store a beer can in the rear door posts... and despite the body literally falling apart from rust, the frame was solid as a rock *looks pointedly at Toyota*.
    Oh, and the 302 + AOD + 8.8" combination has all the frailty of a granite boulder.
  18. Dec 21, 2015 at 7:38 PM
    Jack Wagon
    Jack Wagon Active Member
    Glen Burnie, MD
    2015 SR5 Shortbed
    5100 w/ 2.5 Eibach springs, stock UCA's, Single AAL, ImMrYo mirror relocation, Tonnopro Tri-Fold, 20% Tint
    Fullsizebronco.com was previously mentioned. They are pretty good over there. I had a 96 that started its life with me on 4" lift and 35" BFG Muds. By the time those guys on the bronco forum were done with me I had that sucker on 12" SAS lift and switched between 37" and 42" tires. Damn that thing was bad. Miss it, but maybe I'll have another some day.
  19. Dec 22, 2015 at 1:08 PM
    Larry
    Larry CARL
    CARL
    I'd love a '68-'72 Chevy K5 Blazer in great original shape.
