the headlights don't turn off automatically when engine is turned off and the door opened. Any sugge
Discussion in '1st Gen. Tacomas (1995-2004)' started by Parkward, Dec 20, 2016.
  1. Dec 20, 2016 at 11:02 AM
    Parkward
    Parkward [OP] Member
    The headlights don't turn off automatically when the engine is turned off and the door opened. Any suggestions?
  2. Dec 20, 2016 at 11:16 AM
    HSmith_11
    HSmith_11 Tacoma Enthusiast
    Hunter
    Madison, Va
    2001 Ext Cab SR5 4x4 MT
    5100/OME 881s 1.5" Progressive AAL 33x12.50X15 KO2s
    Do you have any more information for us?
  3. Dec 20, 2016 at 11:45 AM
    Parkward
    They shut off automatically when I bought it, but stopped doing that about a year ago. I assumed it was a latching relay that had gone bad, so I replaced the headlamp relay, but that is obviously not the problem. I don't have the wiring diagram, so I'm groping in the dark until the shop manual arrives.
  4. Dec 20, 2016 at 5:12 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I'm not familiar with the different headlamp stalks, but could someone have moved yours from the position that auto shuts off? If that's even a possibility. I have that on my Land Cruisers headlamps but not on my poverty Tacoma.
  5. Dec 21, 2016 at 4:37 AM
    Parkward
    There is no provision for that on the series 1. There must be a latching relay somewhere that is no longer working properly; I jiust don't know where it is. It must be tied into the driver's door switch I assume.
  6. Dec 21, 2016 at 7:28 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    have you switched headlights, specifically halogen to LED?
    check the switch located on the front lower driver's door jam to make sure it is working correctly
    also as a test there is a "time-out" of about 1 minute of shutting off the truck and pulling the key when it will "click" off (you can use power windows up until this point as well). if it doesn't do that there is a relay that handles this but it's not the headlamp relay per se.
  7. Dec 21, 2016 at 8:54 AM
    Parkward
    Haven't switched headlamps. I'll check the lower switch. Don't have power windows. Thanx.
  8. Dec 21, 2016 at 9:54 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    What year Tacoma and what model? Do you have daytime running lamps.
  9. Dec 21, 2016 at 10:08 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    this diagrarm should cover 03-04
  10. Dec 22, 2016 at 5:07 AM
    Parkward
    It's a 2003 SR5. Thanx for the wiring diagram. It doesn't have daytime running lights. I suspect the driver's door switch may be faulty because the dome light doesn't work with the driver's door open. It works with the passenger door switch though.
  11. Dec 22, 2016 at 10:14 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Sounds like its the door switch.
  12. Dec 22, 2016 at 12:39 PM
    Parkward
    I'll let you know. I think you are correct.
  13. Dec 22, 2016 at 3:57 PM
    Parkward
    The wire to the switch had corroded enough to break in the connector. Problem fixed. Thanx for the help.
