The heat is back!
Discussion in 'Arizona' started by chris4x4, Jun 16, 2012.
  1. Jun 16, 2012 at 5:37 PM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    As I was waiting by my car for the Wifey, I lone spider repelled out of a tree, and twards me. Now, being as they dont repel fast, I wasnt worried. Besides, I was armed. Anyway, I side step the repelling spider assault, and it lands on my car, which was sitting in the sun for about 6 hours. The spider begins to sever itself from its repelling "rope", then it stops moving, twitches, and curls up and dies. I believe it died from burning to death on the hot surface of the car.
  2. Jun 16, 2012 at 5:39 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
  3. Jun 16, 2012 at 5:40 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    So when this happened were you snickering in utter joy with a huge grin on your face?
  4. Jun 16, 2012 at 5:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Indeed. Being as your truck is White, I imagine the spiders will be "hot footing" it on your truck, with a higher chance of survival.
  5. Jun 16, 2012 at 5:41 PM
    nobody4343
    nobody4343 Well-Known Member
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    hid headlights, black spyder jdm headlight housings, black jdm led spyder taillights, full led bulb swap, hid foglights, 3 inch pro comp lift, black out emblems, two 4 inch hid lights mounted behind the satoshi, wade vent visors, black westin nerf bars, black stubby antenna, k and n cold air intake, flowmaster delta 50 dual exhaust custom black tips, color matched satoshi grill with custom emblem
    So you had your handy rolled up newspaper with you in case the spider had beef
  6. Jun 16, 2012 at 5:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I poked it a few times, just to make sure it wasnt trying to lure me into a false sense of security, before attacking. Then I did a happy dance.
  7. Jun 16, 2012 at 5:41 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    lol, i don't doubt it. it's gettin HOT!
  8. Jun 16, 2012 at 5:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I actually took the safety off my Rugar.
  9. Jun 16, 2012 at 5:42 PM
    babytruck
    NorCal
    You actually TOUCHED it??!? :eek:
  10. Jun 16, 2012 at 5:43 PM
    nobody4343
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    Overkill?
  11. Jun 16, 2012 at 5:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I used a stick
    "Overkill" would be if I had my AR....and only a little "over kill" at that.
  12. Jun 16, 2012 at 5:46 PM
    Cypherian
    Cypherian Well-Known Member
    Mid Atlantic Region
    This is a WAG based on reading this board alot .. But I think Chris4X4 has a pathalogical hatred of spiders so umm the safety off the "rugar" (sic) not so unbelievable.. Hey he didn't clear leather though I imagine he was loosening up the hands for a quick draw if need be..
    Cypher
  13. Jun 16, 2012 at 5:47 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Just make sure you hit your target. Hate to see you miss and put a hole in your engine.
  14. Jun 16, 2012 at 5:57 PM
    IndigoTac07
    IndigoTac07 Tortoise*
    AJ
    Houston
    '07 Tacoma
    I noticed its hot. When I walk outside I feeling like curling up and dying. I'm glad you are ok Chris, that spider totally would have attacked you.
  15. Jun 16, 2012 at 6:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It was at the driver side, rear.....so I would have shot the truck.
    pretty much verbatum of what I said,.
    Thank you. it was a heart stopping moment. :(
  16. Jun 16, 2012 at 6:13 PM
    babytruck
    NorCal
    *Ruger ;)
  17. Jun 16, 2012 at 6:15 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    You would think that living in the climate, the spider would be immune to the heat.
    I still think its a trap. Probably laid a small GPD tracker on your car to track you home.
  18. Jun 16, 2012 at 6:15 PM
    IndigoTac07
    AJ
    Houston
    '07 Tacoma
    Did your heart start beating again? You may have to see a doctor if it isn't beating.
  19. Jun 16, 2012 at 6:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It did.
  20. Jun 16, 2012 at 6:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I thought of that. I clodsely searched the car before I drove off. And even after, I drove in circles, and kept an eye open for spider cars that could be tailing me.
