The hood won’t pop up 2014 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taluchei, Dec 3, 2020.
  1. Dec 3, 2020 at 11:47 AM
    Taluchei
    Taluchei [OP] New Member
    Kara
    2014 Blue Tacoma
    The hood won’t pop up after pulling on the hood release in the cab. I have tried trying to get my fingers in to push it up. I have tried pressing down on the hood. The hood release is just free now.
    It’s a catch 22 the battery is dead but I can’t get the hood up to jump start it.
    This happened last winter I thought it was because the mechanism was frozen. It is not that cold today.
    clebner and GQ7227 like this.
  2. Dec 3, 2020 at 11:56 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I would have someone pull the inside lever and have another person push down on the hood at the same time.
    GQ7227 likes this.
  3. Dec 3, 2020 at 12:06 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Once its open, check the adjustable rubber stops on each side. If they can be adjusted up, that will put more tension on the hood and get it to pop up better
    Lester Lugnut and Steves104x4 like this.
  4. Dec 3, 2020 at 12:10 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    my relative has had this problem as well on a 2o11
    whenever you get it unstuck use some NutZ lube all over that, let it soak in and creep, should take care of the issue for awhile, year or two maybe
    unless something else is wonky under there
  5. Dec 3, 2020 at 12:36 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^
    GQ7227 likes this.
  6. Dec 3, 2020 at 1:54 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I’ve learned banging on a hood works sometimes. I had a Nissan Frontier that had this problem, had to hit the hood a few times and it would open.
  7. Dec 3, 2020 at 2:27 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Get it open and adjust the hood bumpers
  8. Dec 3, 2020 at 2:36 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    X2.
    cussing at it helps.
    Heyyo_Friday likes this.
  9. Dec 3, 2020 at 3:37 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Even if it doesnt pop up you can open it if you have pulled the inside lever. You just have to make it pop yourself, wedge your finger inbetween the grill n hood and pop it up the half inch, then push the front hood latch and lift the hood.
  10. Dec 3, 2020 at 3:47 PM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    Pull the latch lever inside then at the same time pull down on the cable.
    Happened to me.
    Welcome to the forum Kara @Taluchei
    tviteritto likes this.
  11. Dec 3, 2020 at 3:52 PM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    My father’s in laws 12 does this I usually just grab the corner of the or hood scoop to lift
  12. Dec 4, 2020 at 12:58 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If the hood release handle is loose and floppy the cable if broken or has come loose from the mechanism either at the hood end or the cab end.
