The (hopefully) million mile thread.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ripewithdecay, Jun 29, 2012.
  1. Jul 13, 2012 at 2:10 PM
    #41
    ripewithdecay
    ripewithdecay [OP] Well-Known Member
    Crossville,TN
    06 Tacoma 2.7
    Haha amen! I have to say, my Tacoma seat is one of the most comfortable out of all the vehicles I've owned. I drive 4 hours or so to my first job and don't have any back pain or anything. It can be hard to find a comfortable seat when you're 6'6, one more reason to just stick with this truck.
  2. Aug 14, 2012 at 8:45 PM
    #42
    ripewithdecay
    Crossville,TN
    06 Tacoma 2.7
    Well I've hit 385k recently! I think i may need to have some transmission work done soon. Lately when i take off i'm getting some chatter in 1st gear. I'm going to have it checked out by a professional first, but i need a little advice.
    I've found a transmission with 16k miles on it for 600$, which sounds pretty reasonable to me. How much should i be looking at as far as labor cost to switch out transmissions? Also, should i just have my old trans rebuilt instead? For some reason i can't see a rebuild being cheaper than 600$, but maybe I'm wrong.
  3. Aug 14, 2012 at 8:52 PM
    #43
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Not too sure about the trans but Just subscribing. Good luck.
  4. Aug 14, 2012 at 8:54 PM
    #44
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    I love that you are hitting 385k miles and are just now worrying about a transmission... All other vehicles on the planet are typically scrap metal at this point.
    I just recently had a friend with a GMC Acadia have a transmission rebuilt for much more than $600. I have to imagine that will be the better deal. FYI- the Acadia made it until 68k miles before the trans needed to be rebuilt.
    Pulling for you to make your mileage goal:thumbsup:
  5. Aug 14, 2012 at 9:01 PM
    #45
    ripewithdecay
    Crossville,TN
    06 Tacoma 2.7
    Hah i know, this vehicle has been so great. Also the trans has either a 6 or 12 month warranty on it which should be plenty of time to make sure its going to work out. (they also cover labor costs up to 45$ an hr if it has to be replaced)
    And man 68k miles, thats sad. Toyota knows what they're doing.
    Thanks for the support!
  6. Aug 14, 2012 at 9:09 PM
    #46
    Watari06V6
    Watari06V6 Faster than a speeding ticket
    Wounded Knee
    TRD-V6-SR5-06
    youll make it bro..more support here for ya
  7. Aug 14, 2012 at 9:16 PM
    #47
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    I'd probably go for that separate trans, it might end up being cheaper if you need a full rebuild. Then you could keep your old one and use it for parts or sell it.
    Probably want to get quotes and get your transmission diagnosed first. It may be something cheap and a simple fix though.
  8. Aug 14, 2012 at 9:46 PM
    #48
    DefyInertia
    DefyInertia Saratogian
    Nate
    NorCal
    '05 DCLB 4x4 SR5#8 (white)
    Toytec Ultimate: ~3" up front via coil overs, LR UCAs, and SB delete; 2+ out back with AAL and new shocks. Leer cap, padded sleeping platform in bed
    Good luck!
    I must ask, why do you drive so much???
  9. Aug 14, 2012 at 9:53 PM
    #49
    ripewithdecay
    Crossville,TN
    06 Tacoma 2.7
    For sure, I'm going to try to get some quotes tomorrow and ill post back what the diagnosis is.
  10. Aug 14, 2012 at 9:55 PM
    #50
    ripewithdecay
    Crossville,TN
    06 Tacoma 2.7
    Its pretty much 99% for work. I drive to Bristol area twice a week and up in Kentucky once. I have a propane floor burnisher and i service the tile floors in grocery stores.
  11. Aug 14, 2012 at 10:02 PM
    #51
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
  12. Aug 14, 2012 at 10:07 PM
    #52
    badger
    badger Well-Known Member
    07 SR5
    If you have found a good tranny with a true 16K, I would forget the rebuild. Tranny rebuilds are one of the worst rip offs around unless you know the rebuilder very well. Usually you get a couple of bearings and seals, and 50K later it's broken again. The tranny with 16K will have new everything. Just make sure there isn't some bad history with it, like being fished out of a flood. :D
  13. Aug 16, 2012 at 1:59 PM
    #53
    ripewithdecay
    Crossville,TN
    06 Tacoma 2.7
    Great advice! :)
    Update: I took my truck to the transmission shop and let he mechanic drive it around a bit with me. He said he's not so sure it's even a problem with the transmission. I'm dropping it by on Monday for him to check over a few things he thought it could be. I also asked him if the transmission is the problem, if i should rebuild or replace with a used one. He said honestly we see so few Toyota transmissions in our shop I would definitely recommend a used transmission. He was just making the point that on most domestic vehicles it's a huge risk getting a used one since they really can have a short life span, but not so with a Toyota.
  14. Aug 16, 2012 at 2:52 PM
    #54
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Sub'd, hope your tranny is a easy fix
  15. Aug 16, 2012 at 4:24 PM
    #55
    Carper87
    Carper87 Member
    Tony
    Missouri
    2007 DCSB super white sport
    This makes me feel good my 06 only has 58k on it I got a long way to go to catch up
  16. Aug 16, 2012 at 9:44 PM
    #56
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    that more than less than a month between oil changes?!
    great job OP. way to keep it together.
  17. Aug 19, 2012 at 6:43 PM
    #57
    silver taco
    silver taco Well-Known Member
    Los Angeles
    07 4X access cab
    Icon 2.5 ext travel, Camburg 1.25" uca's, All-pro leafs, Icon 2.5" rear shocks, LR jounce front and back, breather mod, KR Fab rear bumper, Kenwood 2m radio, All-Pro sliders, Front bumper by Surfinferno (Dylan), Glassworks fenders, 4:56 gears, gusseted spindles and coil buckets
  18. Aug 19, 2012 at 7:28 PM
    #58
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    Sub'd Damn!
    Brett
  19. Aug 19, 2012 at 7:37 PM
    #59
    wesrunner
    wesrunner Gang Gang
    Wes
    Louisiana
    It's paid for.
    a buncha fuckin toyotas
    Good luck!
    :popcorn:
  20. Aug 19, 2012 at 8:19 PM
    #60
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    Keep us updated!
    Shawn.
