The (hopefully) million mile thread.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ripewithdecay, Jun 29, 2012.
  1. Nov 3, 2012 at 6:56 PM
    #121
    BradyT88
    BradyT88 Well-Known Member
    Exactly. Diesels typically run for 200,000+ miles easy because they are built a hell of a lot tougher to handle the extra pressure and heat from the diesel. If you built a gasoline engine that tough it would likely last just as long possibly longer.
  2. Nov 3, 2012 at 8:02 PM
    #122
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    That is my point. If the engine is designed for more torque, it can handle it just as well.
    So, other than simply having more parts, I do not see why the V6 will not run as long as the 4-cylinder.
  3. Nov 3, 2012 at 8:27 PM
    #123
    qnyla
    NM
    Actually that would be 100 parts, but your point is valid:D
  4. Nov 3, 2012 at 8:38 PM
    #124
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Does the OP buy new tires every year?
  5. Nov 3, 2012 at 8:41 PM
    #125
    BradyT88
    Yes but i have my doubts that the V6 is built any stronger than the I4... Hell the rear diff we have under these is pretty much the same one they have been using since 1979. There's a reason why 2nd gens have so many rear diff problems. That diff was designed for a ~3500lb Toyota pickup that was pushing 140hp on a good day. Now we have a 236hp motor on a 5000lb vehicle and expect the same setup to hold?... Well it doesn't very well... Ask me and at least 100+ more members on here how we know...:rolleyes:
  6. Nov 3, 2012 at 9:12 PM
    #126
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    I was thinking the same thing. Maybe he has Tire Rack credit for deep discounts or something. :)
  7. Nov 3, 2012 at 11:17 PM
    #127
    Bishop2Queens6
    SoCal
    2009 DCSB SR5 4x4
    I really hope that what ever company the OP works for pays for all maintenance and repairs and fuel.
  8. Nov 4, 2012 at 2:06 AM
    #128
    bash42
    bash42 Well-Known Member
    Eastern PA
    '22 DCLB TRD OR Super White
    Agreed....it as nothing to do with the # of parts. It's just that the 2.7L engines are historically an awesome design that run forever. Just as is the case with the Ford 4.6L (v8), historically an amazing engine that will run forever.
  9. Nov 4, 2012 at 5:31 AM
    #129
    ripewithdecay
    ripewithdecay [OP] Well-Known Member
    Crossville,TN
    06 Tacoma 2.7
    Thanks yo!
    I just take mine to a shop locally. I have yet to change it myself, but I think I may try to next time.
    I'm actually considered self employed, so it's not really a company vehicle. However, when tax time comes around those 70k+ miles equal a pretty great write off. Also I do get new tires once a year at least. I've never used tire rack though, just always local tire shops. I need to get some freaking sponsors. Discounts on tires and oil would be pretty nice. :)
  10. Nov 4, 2012 at 7:44 AM
    #130
    thatguy0o0
    thatguy0o0 trunk monkey
    Rapid City SD
    White '13 TRD Sport.
    Sweet thanks for the advice. How much does it usually cost to have done at a local shop?
  11. Nov 4, 2012 at 7:56 AM
    #131
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    You could call a few and ask, or look up prices of local places that have a website online.
  12. Nov 4, 2012 at 10:09 AM
    #132
    thatguy0o0
    Rapid City SD
    But that would make too much sense!!!! Haha yeah I guess I will do that needs to be changed before I drive home to NC next month.
  13. Nov 4, 2012 at 10:59 AM
    #133
    ripewithdecay
    Crossville,TN
    06 Tacoma 2.7
    It is usually around 120 where I live. I'm not sure if that's a good price or not though. Places like Castrol express or Jiffy won't service mine. Some places may do more or less too. Like one place dropped the pan and put on a new filter and gasket and inspected things for wear. Whereas another place just did the fluid.
  14. Nov 4, 2012 at 11:01 AM
    #134
    ripewithdecay
    Crossville,TN
    06 Tacoma 2.7
    Wow, I think I could've used the word " place " a bit more. o_O
  15. Nov 4, 2012 at 10:43 PM
    #135
    bra
    bra Well-Known Member
    2008 AC 4X4 TRD sport
    Badges off
    What about the RPM of the engine? The v6's auto have very low RPM all the time except in high speed. And the lower is your RPM, the better theengine will last?
  16. Nov 5, 2012 at 4:45 AM
    #136
    jbrenn
    jbrenn Well-Known Member
    allen texas
    10 sr5
    The rpms of 4 cyl auto are also pretty low at 70 its about 2200. at 80 it was 2500.
  17. Nov 5, 2012 at 6:10 AM
    #137
    scaplus
    scaplus Well-Known Member
    This thread already gives me hope about my 4-banger. I plan on keeping my taco until it dies literally. I do a lot of driving so I hope I do get as far as you do ;) I'll be there in about 10 years haha.
    As for the part failure, I believe the 4-banger has been time-tested and the design works. Look back at how many 4-bangers in the past that Toyota has made. Anything that's been around that long will have a mature-design and it will just work mentality.
    As for the high RPM's, as long as you don't drive close to the red line or even red line it, you should be fine, if you take care of the maintenance every so often. If you are pushing your truck for long extended periods of time, then obviously you will see problems and wear but if you do it once and a while you should be fine.
  18. Nov 7, 2012 at 4:51 PM
    #138
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    4
    :thumbsup:
    I'm vicariously living the excitement of your mileage! I'm almost jealous that mine is low now hahah
  19. Nov 8, 2012 at 10:34 PM
    #139
    ripewithdecay
    Crossville,TN
    06 Tacoma 2.7
    haha that's hilarious. It's funny because I've been out of town on vacation a lot lately so I've missed out on quite a bit of mileage. I can't help but thinking, man I'd already be at like 402k. As is I'm at 398055. Should only take another couple weeks tops.
  20. Nov 9, 2012 at 5:05 AM
    #140
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    How funny! (Sure not for you) Can't wait to see a million. I had a 89 4x4 with 320,000 when I sold it. My father and I put them all on it. GREAT trucks can't beat a Yota!
