The 'I'm running out of room to bolt things on' build
Discussion in '2nd Gen. Builds (2005-2015)' started by benbacher, Jun 8, 2012.
  1. Dec 19, 2013 at 10:29 PM
    #541
    benbacher
    benbacher [OP] Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    What are you going to use to fill it? These regulators are crazy expensive at our pressures.
  2. Dec 19, 2013 at 10:44 PM
    #542
    BradyT88
    BradyT88 Well-Known Member
    I'm going to do like JW and not use a regulator.
  3. Dec 19, 2013 at 11:21 PM
    #543
    benbacher
    Anchorage, AK
    After using that kind of pressure, I'm definitely not going to do that lol. Gonna run the resivoirs and see what kind of pressure that yields before I buy anything though.
  4. Dec 20, 2013 at 7:24 AM
    #544
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    i have extended brake lines and they were definitely needed. i need even longer in the rear after seeing them on the lift at CBI...they're TIGHT! the shackle flip definitely pushes them to their limits.
    fronts are fine now which i would prefer..do you really want to stress something as important as your brake lines?
  5. Dec 20, 2013 at 7:28 AM
    #545
    benbacher
    Anchorage, AK
    Nope. Since we have to do the rear anyhow, we're going to
    Go ahead and do the front at the same time.
  6. Dec 20, 2013 at 7:43 AM
    #546
    BradyT88
    I ordered resis a couple weeks ago for the same reason. Not sure how far about they are now but I was quoted like 4 weeks IIRC. I am going to get limit straps as well and flip the top hat. Hopefully I have the rear end done by then and I can just level it out.
    As for the regulator, I just can't justify dropping that kind of money on something I will use like twice a year...
  7. Dec 20, 2013 at 8:00 AM
    #547
    benbacher
    Anchorage, AK
    After seeing that kind of pressure kill someone, I'll figure something out. Turbotorch makes some inexpensive ones iirc.
  8. Dec 20, 2013 at 8:10 AM
    #548
    BradyT88
    :eek: I mean I know it is possible, but seeing... You have quite the job or something...
  9. Dec 20, 2013 at 8:18 AM
    #549
    benbacher
    Anchorage, AK
    Haha no not personally, when I dropped off the regulator I rented they have a box of 'man killers'. Regulators that have all killed people from improper use. The craziest one was an oxygen regulator. Guy had it sitting on his workbench not hooked up but he left it at its previously used setting instead of backing it to zero. Something crawled in the intake and died. When he attached it to his bottle, it was still at that previous pressure so it flooded with oxygen, the carcass of whatever was in there became the fuel, and the friction from the instant flooding of pressure became the heat source and sparked. Instant bomb. Blew the dudes head off.
  10. Dec 20, 2013 at 8:23 AM
    #550
    n0rth
    n0rth Well-Known Member
    J.W.
    New Mexico
    2019 Tundra Platinum
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
  11. Dec 20, 2013 at 8:27 AM
    #551
    BradyT88
    Pretty wild! When you said something had crawled into it, I kept waiting for story to end with someone basically getting shot with an oxygen propelled carcass...
  12. Dec 20, 2013 at 8:37 AM
    #552
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    You Guys will most likely need the same pressure to lift the truck you will just have more volume giving you a better ride.
  13. Dec 20, 2013 at 8:49 AM
    #553
    benbacher
    Anchorage, AK
    Still want them. It has to change the pressure SOME doesnt it? Maybe not all that much but if you're displacing more gas I'd think mathematically you'd need less psi. I disn't make it that far in math though :0
  14. Dec 20, 2013 at 8:52 AM
    #554
    JLee
    Jerry
    Benicia, CA
    I don't think the changes will be much defiantly not enough to get you down to a 600psi regulator. I'm adding them to mine just to make it easier to get to my fill valve.
  15. Dec 20, 2013 at 9:01 AM
    #555
    BradyT88
    I am not familiar enough with the pressure physics. I'm an electrical engineer not mechanical. haha I know a lot of it will be based on the surface area on the shaft which adding resi's isn't going to change. I'm not sure how much the surface area of the rest of the chamber plays in, but adding resi's will increase that. haha
    This is what ORI says about them,
  16. Dec 20, 2013 at 9:24 AM
    #556
    BradyT88
    I'm assuming you can just break the ideal gas law down to P1V1 = P2V2, where P1V1 is volume and pressure at ride height and P2V2 is when the shaft is either compressed or extended from ride height.
    Say for no resi's the ride height volume is 5L and at full stuff it is half that so 2.5L, a 50% change. I'm guess adding in resi's will be say 6L volume at ride height and at full stuff you will how 3.5L volume so only about a 40% drop in volume instead of 50%. I'm thinking that is the key to the change in ride.
    So 700 psi with no resi,
    700*5 = x*2.5 so x = 1400psi at full stuff
    700 psi with resi
    700*6 = x*3.5 so x = 1200 psi at full stuff
    So you are now seeing lower pressures are the suspension stuffs which should result in a smoother ride. I have no idea what the actual numbers are though, but that should at least get the idea across.
  17. Dec 20, 2013 at 10:15 AM
    #557
    benbacher
    Anchorage, AK
    Any word on the mounting jerry?
  18. Dec 20, 2013 at 10:19 AM
    #558
    JLee
    Jerry
    Benicia, CA
    The don't have to be vertical you just have to make sure the pick up tube is on the bottom.
  19. Dec 20, 2013 at 10:25 AM
    #559
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Sweet truck.
    I envy you living in AK... was the best place I visisted
  20. Dec 20, 2013 at 11:04 AM
    #560
    benbacher
    Anchorage, AK
    Saweet.
