The impossible nut
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco302, May 15, 2020.
  1. May 15, 2020 at 8:47 PM
    Taco302
    Taco302 [OP] Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    I can't get the last (top) 1 of 3 nuts that holds my front coilover in place. I have sprayed tons of wd-40, every 14mm socket, wrench, channel locks, vice grips, monkey wrench...its a bit rounded at this point. FUCK!
    Any suggestions?
    TacomaGold16 likes this.
  2. May 15, 2020 at 8:48 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
  3. May 15, 2020 at 8:51 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Propane torch and heat the nut.
    Then twist on it.
  4. May 15, 2020 at 8:56 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    If your replacing strut mounts just cut it off. If your not replacing it I would take a wire brush on a drill and clean up those threads as much as possible, less resistance once it starts moving, and heat up the nut with a torch, heat makes metal expand, you only want the nut to expand so dont heat up thr stud much, it'll happen some but focus on the nut with the torch
  5. May 15, 2020 at 9:12 PM
    tsab916
    tsab916 Well-Known Member
    Sacramento
    02 DC 4x4
  6. May 15, 2020 at 9:12 PM
    Taco302
    Greenbow, Alabama
    If it comes to that and must, I will. Going to Lowes for a propane torch and grip tite socket in the morning. If I must cut, do you think a sawzall will suffice? And if so, can I get the same bolt from the hardware store or do i need to buy one from the dealer?
  7. May 15, 2020 at 9:17 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    I'd replace with Grade8. Available at Home depot, Ace etc.
    Biscuits and robssol like this.
  8. May 15, 2020 at 9:26 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Try a 6 point socket instead of 12. Makes a big difference.
    JJ04TACO, cruisedon66, CS_AR and 11 others like this.
  9. May 15, 2020 at 9:37 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    I tried this position, but my gf was not into it.
    GillyMac, 04taccoo, joeyv141 and 13 others like this.
  10. May 15, 2020 at 10:04 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    My top hat nuts looked a lot like that, I had to cut a lot of hardware when I did my front suspension. I wasn't able to cut those nuts with a recip, it was too big of a tool for a tight spot. I used a dremel with a flexible extension and a cutting wheel to take at least one or two of those off.
    I think you still have a chance of getting that off without cutting though. Hit it with penetrating oil, heat with a torch til it's 200F+, then go to town with a breaker bar and 6 point impact socket.
    Biscuits and cruiserguy like this.
  11. May 15, 2020 at 10:07 PM
    Taco302
    Greenbow, Alabama
    Thanks, cheers.
  12. May 16, 2020 at 12:40 AM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    A tool called a bolt extractor would probably work. Home Depot and Harbor Freight have them. They are sockets that grip rounded off bolt heads.
    $yoda$, Scottyskywalker and Biscuits like this.
  13. May 16, 2020 at 12:45 AM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    Smaller socket. Hammer that shit on and back it off with a break over bar. I’ve done it a ton of times on older cars. Just get ready to buy a new socket
    wilcam47 and Biscuits like this.
  14. May 16, 2020 at 12:55 AM
    Taco505
    Taco505 Well-Known Member
    Alex
    New Mexico
    2011 4cyl 4x4 5 speed
    OME 884's/90021, MD Dakar/Nitrocharger.
    Looks a lot like my old 4Runner when I was installing my lift. I had a nut that would not come off. I took a grinder to cut it off then wire wheeled it clean and spray painted it. I got a new top hat set at autozone and rented the coil compressor and got everything swapped in an afternoon.
    Running Board Man likes this.
  15. May 16, 2020 at 1:51 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    WD-40 is not a penetrating oil. Quit wasting time with that and try PB Blaster or Kroil.
    Oorgle, ELMO67, TacomaGold16 and 7 others like this.
  16. May 16, 2020 at 1:56 AM
    Tom0662
    Tom0662 Well-Known Member
    Tom
    Iowa
    2016 TRDORSB
    I know it is a bit expensive but I bought one to use at work.
    I work on diesel engines in semi's. Got tired of exhaust nuts etc that won't come
    off. Works awesome. Saves a lot of time from not needing to try and extract
    broken studs in heads etc. sometimes it is not feasible to use a torch.
    Random video I grabbed off the 'tube.
    https://www.youtube.com/watch?v=IIavHs2n7ew
  17. May 16, 2020 at 3:40 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    All six of mine broke loose and just spun cut off wheel to the rescue .
    In my case the nuts had little rust .
  18. May 16, 2020 at 4:13 AM
    Running Board Man
    Running Board Man Well-Known Member
    Ive had good luck with harbor freight extractor sockets
    Scottyskywalker and GQ7227 like this.
  19. May 16, 2020 at 4:44 AM
    joeyv141
    New Jersey
    Ohh the snap on guy has those on the truck and they are fucking awesome.
    Tom0662[QUOTED] likes this.
  20. May 16, 2020 at 4:52 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I got one as a gift. It's awesome.
