The infamous passenger side leak.
Discussion in '1st Gen. Tacomas (1995-2004)' started by itslogz, Feb 8, 2016.
  1. Feb 8, 2016 at 2:27 PM
    itslogz
    itslogz [OP] Member
    2000 Tacoma SR5 4X4 2.7
    2000 X-cab SR5
    Alright guys been trolling here awhile but this is my first post because this is driving me crazy. I have new carpet ready to go in the truck so I gotta get this figured out or im riding with just a driver seat for awhile :hattip: And alot of the answers i've read always mention the a/c drain, no its definitely not that.
    Leaks water on the passenger side up behind dash, i can clearly watch it coming in in the far top corner, right above the blower motor but all the way at the top (using a mirror and flashlight)
    Ive removed the fender and sealed everything I could tell might need sealing per the TSB, the windshield was JUST replaced last week (it was leaking before and after so thats not it)
    My last thought would be its coming in from the floor of the main cowl, but on the passenger side of this truck it is a solid piece all the way across, covering everything above the passenger side. Its not like alot of the tacomas i see which its all exposed with the raised area around the cabin filter. so if I wanted to seal something in the floor of it, i have no idea how i would gain access, unless i cut a huge hunk out and had it welded back in or something crazy. Has anyone else dealt with this where it ended up coming from inside the cowl, and if so how did you get up under there to seal it? Where the water is coming in really makes me think thats where it is, but if anyone else has any specific suggestions, or pictures of where they sealed theres to get it straight anything would be helpful. Its a widely talked about topic but hardly anyone following up saying they got it fixed and how. I really would hate to have to pull the dash just to get this cleared up.
    Thanks alot guys :sadviolin:
  2. Feb 8, 2016 at 6:17 PM
    aru
    aru Well-Known Member
    Sarasota Florida
    TRD DC 4x4
    King Coilovers, TC UCA's, OME rear leafs with shocks, Tundra brake upgrade with stainless brake lines, ECGS 4.88 front/Rear ARB&TRD locked, 285/70/17 BFG KO2, TRD 2nd Gen S/C, URD 7th, 2.1 & crank pulley, TRD headers, TRD air filter, PLX gauge built into my rear view mirror with boost, AFR, EGT, Trans Temp and TRD Trans Cooler....love this truck
    Same problem I'm dealing with, frustrating
    wilcam47 likes this.
  3. Feb 8, 2016 at 6:26 PM
    jonvan
    jonvan Well-Known Member
    Jon
    Bath, PA
    21' DCSB, Past- 10' ACLB, 03' RCSB
    Pretty sure the leak comes from the cowl seam area underneath the windshield wiper mounts- where the water drains through when it comes off the windshield if I remember correctly. You need to take off the windshield wipers, pull the arms, then spray the sealant recommended in the TSB with the optional attachable hose down in there to seal up the seam against the cab. Sorry if my descriptions aren't clear- let us know if this works for you.
    Fenwick1993 likes this.
  4. Feb 8, 2016 at 6:37 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    I have a leak but have yet to pull apart everything and look for the source. Good luck with it.
  5. Feb 8, 2016 at 6:38 PM
    HSP
    HSP New Member
    Harrisonburg VA
    2002 Tacoma
    None
    I will try that. It has been awful having wet carpet for so long. Glad to see I am not the only one having this issue.
  6. Feb 9, 2016 at 1:47 PM
    itslogz
    itslogz [OP] Member
    Are you referring to spraying sealant through the wiper motor opening if I was to remove the motor all together? That's the only way I can vision getting the sealant where I would think it needs to be
  7. Feb 9, 2016 at 1:52 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Not sure if been mentioned, but there is a large rubber grommet on the firewall, right where you describe the source of the leak. If the grommet has popped out, is improperly installed, or old/has holes/whatever, you will get a floorboard leak. Ask me how I know.
    Check that.
  8. Feb 9, 2016 at 1:54 PM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    This. Also a common problems on some of the old pickups/4runners. My buddy's 87 4runner has the same leak.
  9. Feb 9, 2016 at 6:49 PM
    mikkydee
    mikkydee My Taco 2007 DCLB 4x4 Man Truck
    Doyle
    Florida
    2007 Silver DCLB Tacoma, 4X4, 4.0 Liter, 6" lift, 20" rims, 34" tires
    6" lift, 20 " inch rims, 34" tires, billet grill, aftermarket fender flares, custom rear bumper, DVd player with backup camera, all LED lights
    Ok newbie on board here. I am having the same leak problems. can you please clarify for me what this means: "the sealant recommended in the TSB"?
    I have no idea what sealant is being referred to or what a TSB is.
    thanks
  10. Feb 9, 2016 at 7:07 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    I'm pretty sure he's referring to this:
    http://www.revbase.com/BBBMotor/TSb/DownloadPdf?id=126899
  11. Feb 9, 2016 at 7:24 PM
    mikkydee
    Doyle
    Florida
  12. Feb 9, 2016 at 7:31 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    No problem.
  13. Feb 10, 2016 at 5:41 PM
    Toyomonkey59
    Toyomonkey59 Well-Known Member
    James
    Hedgesville Wv
    2012 toyota tacoma Trd 4.0 4x4 Doublecab
    I recently had this problem and followed tsb with recommended equipment and it has fixed my leak. I removed wiper linkage and wiper motor. I also removed right front fender. There is a access hole there too. Sprayed sealant in every direction and a ton of it lol. You could also use flex seal but I think the extension is key to getting to all areas.
    NastyTacos likes this.
  14. Feb 12, 2016 at 4:33 PM
    itslogz
    itslogz [OP] Member
    Well i'm gonna take a chance/shot at the cheap stuff. That leak chek from Kent is $42 a can so I picked up this http://www.lowes.com/ProductDisplay...gId=10051&cmRelshp=req&rel=nofollow&cId=PDIO1
    I mainly grabbed this because I couldnt find the flex seal in the store even though they showed a ton in stock, and the reviews for that was better. Im that guy who will leave when they cant find something in store vs asking for it :notsure:
    Im gonna try to do it tomorrow if I can and see what becomes of it. No extension on this tip but I may swap the tip with something with a extension nozzle if it will work, ill update if any progress is made. If its a fail too then i'll order the real stuff I suppose.
    http://www.lawsonproducts.com/Kent/Aerosol-Extension-Wand-Kit/KA14725.lp#
    That is a very interesting looking attachment, i wonder if I could find something like that that would work with my cheap stuff locally instead of ordering
    CS_AR and DustStorm4x4 like this.
  15. Feb 13, 2016 at 2:16 PM
    itslogz
    itslogz [OP] Member
    Wellllllll I got the wiper motor out and took a good of look as i could around at everything and with no extension or SOMETHING theres no hope for getting to it. I really am contemplating making 100% sure its coming from inside the cowl and cutting a spot out near the air intake area and spot welding/seam sealing it back in place. That sounds better than pulling the dash to me.
  16. Feb 16, 2016 at 1:38 PM
    mikkydee
    Doyle
    Florida
    Hey toyomonkey did you purchase the Kent leak chek and the extension? How much were the products and where did you buy from? I have checked out Lawson but it doesn't show prices and it look like they may not sell to retail customers.
  17. Feb 16, 2016 at 2:20 PM
    Toyomonkey59
    James
    Hedgesville Wv
    I purchased from lawson. I set it up on their web page like I had a business and ordered through them. I want to say it was around 40 bucks but I figured that was better than water getting in my cab and stinking the inside up. They mailed it to me without even being payed for. Later they sent a bill in the mail and I made payment over the phone. I really think its the same as flex seal you can buy at lowes. The key is having the long spray tubes to get back into the hard to reach spaces.
  18. Feb 16, 2016 at 3:39 PM
    mikkydee
    Doyle
    Florida
    did you use the 12" extension tube or the longer flexible hose option they offer? I noticed it looks like one 12" plastic extension comes with the leak check product. Is the one plastic extension tube sufficient?
  19. Feb 16, 2016 at 5:55 PM
    Toyomonkey59
    James
    Hedgesville Wv
    I used the 12 inch extensions. You can bend them while spraying to get in hard to reach spaces.
    mikkydee likes this.
  20. Feb 24, 2016 at 8:36 AM
    itslogz
    itslogz [OP] Member
    Guys I stumbled upon a really good alternative that is way cheaper, I ordered it today. Ive got the fender back off and wiper motor out, and a few other things im going to try when this sealant gets here. Ill do a write up if i'm able to 100% fix my leak just so theres pictures to show where I sealed and such.
    http://www.eastwood.com/eastwood-s-flexible-sealer-and-sound-deadener.html
