The infotainment system is pretty rough...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by btown2, Dec 17, 2019.
  1. Dec 17, 2019 at 12:06 PM
    btown2
    btown2 [OP] New Member
    First time truck owner here and decided to go with a 2020 Tacoma TRD Sport since I use Android Auto so much. The infotainment system leaves a lot to be desired though.
    3YGN1ZLo9ydwsv84qOR8ofy-Pr5rj3_jsAe2uztm_ee2d0c3dc001477230b262a05e0725a8d1aca29f.jpg
    So when trying to select a preset the up and down arrows on the steering wheel don't make sense. If you press up you go down in number and pressing down takes you up in number. So say I am in preset 2 and push the up button. I would expect to be taken to preset 3 instead I am taken to preset 1.
    Is there any way to change this behavior?
    Thanks.
  2. Dec 17, 2019 at 12:55 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I guess tacomas infotainment system will never be good enough:pout:
  3. Dec 17, 2019 at 12:59 PM
    B.Peak
    B.Peak Well-Known Member
    Brian
    SWFL
    '19 Tacoma TRD Sport 4X4
    '19 Tacoma TRD Sport 4X4, Premium and Technology Packages OME-888 Coils w/ OME-90021-P Nitrocharger Sport Shocks- softer valving ToyTec .5" Top Spacer OME-EL095R-P Rear Leaf Pack w/ OME-60091-P Nitrocharger Sport Shocks Eibach 1" Lift Block OME Upper Control Arms OME Driveshaft Carrier Bearing Drop Kit ToyTec 1" Diff Drop ECGS Clamshell Bushing 18X9 Enkei RPT-1, 0 Offset on LT305/65R18 TOYO Open Country M/T 2020 OEM Limited Grill 2020 OEM Limited Fog Light Bezels MESO Stage 1 Total Tail Light Kit All Interior and Exterior lights replaced with Diode Dynamics LEDs TRD Cat Back Exhaust Passenger Door Smart Key Mod
    I ended programming my station presets from highest number to lowest so when I press the up button it goes to the next preset station.
    drayden.d, Skydvrr and King Kermit V like this.
  4. Dec 17, 2019 at 1:05 PM
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    Sorry, but the way it's setup makes sense to me. Think of your presets as a list - the list starts at 1 and ends at 6 (or 12 or whatever). Your up and down buttons are moving up and down your list.
  5. Dec 17, 2019 at 1:07 PM
    Truc577
    Truc577 Well-Known Member
    Curt
    NOMO
    2005 TRD OR 4x MT, 2020 TRD OR 4x AT
    High output valve stem caps 2020: Bilstien 6112/5100 Mobtown sliders RRW RR-5 Bronze wheels 2005: 2018 frame and full suspension 2017 Dark Anthracite wheels ARB front bumper
  6. Dec 17, 2019 at 1:09 PM
    hellfire0480
    hellfire0480 Well-Known Member
    Long Island
    2019 TRD OR Quicksand
    Eibach Pro lift, MR701, 285/70R17 AT3W, SOS Sliders, Sherpa RR
    This is how I would look at it as well. You setup your stations in ranked order. Up button goes up in rank. Down button goes down in rank.
    mlr69[QUOTED] likes this.
  7. Dec 17, 2019 at 1:24 PM
    LaggyEvo
    LaggyEvo Well-Known Member
    Gainesville, FL
    2018 Cavalry Blue TRD PRO MT
    285/75r16 BFG KO2
    Ill trade you my 2018 radio, its way better
    Brostjoe and King Kermit V like this.
  8. Dec 17, 2019 at 1:34 PM
    glenmonte
    glenmonte Well-Known Member
    2020 Tacoma TRD Off Road
    Welcome. Conditioning will change the behavior. You won't even notice in a month.
  9. Dec 17, 2019 at 1:36 PM
    DisneyFan91
    DisneyFan91 Well-Known Member
    Fla., Us
    2018 SR 2.7 DCSB
    It's programmed how you read, like on the back of a CD. You start with track 1 at the top, then down to 2, 3, etc.
    Volume also goes left to right on the screen, so left to right on the D-Pad works well.
  10. Dec 17, 2019 at 1:54 PM
    ryan760
    ryan760 Well-Known Member
  11. Dec 17, 2019 at 1:57 PM
    Truc577
    Curt
    NOMO
    I am waiting for the killers to arrive.
    Superdave1.0 likes this.
  12. Dec 17, 2019 at 2:17 PM
    King Kermit V
    King Kermit V Well-Known Member
    Kermit
    Miami, FL
    2018 Black Tacoma SR5 DCSB
    Taco sauce
    I just bring my boom box in the truck. Blast it.
  13. Dec 17, 2019 at 3:17 PM
    Putzcommander
    Putzcommander Well-Known Member
    2016 Trd Sport Doublecab 5ft Box
    Softopper
    Toyota owns part of panasonic. It was doomed from the get go.
  14. Dec 17, 2019 at 3:20 PM
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    It’s not worth it anymore. Mods will suspend your account for hurting feelings.
  15. Dec 17, 2019 at 3:22 PM
    Truc577
    Curt
    NOMO
    Well what in tarnation!
  16. Dec 17, 2019 at 3:22 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Shoulda got a manual trans :anonymous:
    Junkhead, jeifei72 and Nframe like this.
  17. Dec 17, 2019 at 3:26 PM
    Superdave1.0
    SoCal
    I can relate with the steering wheel controls. I'm completely used to it now, but my previous car (and most cars) have the up/down reserved for the volume.
  18. Dec 17, 2019 at 3:31 PM
    Inverno4
    Inverno4 Well-Known Member
    Baltimore, MD
    2020 DC Off-Road MT
    What makes it more fun is if you push down to get to a preset such as channel 25 on XM and want to go to 26, but don't have it programmed, you have to then push up to scroll ascending through the xm channels.
  19. Dec 17, 2019 at 4:42 PM
    Lake_Trash_1
    Lake_Trash_1 Active Member
    1940 bus
    Can not afford.
    It is what it is.
    Better than the Sync in a F150 I just traded.
    My 2016 Taco was the same way.
    Truc577 likes this.
  20. Dec 17, 2019 at 5:23 PM
    dansflhti
    dansflhti Well-Known Member
    Nova Scotia
    24 TRD Sport +.16 Mustang GT. 14 Street Glide
    I preferred the sync in my 2016 F150 for operation, but the sound in the Tacoma is much better. The Sirius always sounded like they were singing under water in the F150.
