The Insane Asylum DCLB build and XJ insanity
Discussion in '2nd Gen. Builds (2005-2015)' started by ovrlndkull, Sep 27, 2017.
  1. Mar 14, 2018 at 7:01 PM
    #101
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    I use it as a rule of thumb. lets take the Mickey Thompson rims I want they are 17x9 -12mm and are listed as 4.5'' of BS. if u take a 9'' rim and say it has a 4.5 center line then with -12mm offset it should actually have roughly 4'' of BS. if u take 9'' rim and add 1'' of lip as a rule of thumb for both front and back gives you a 5'' centre with -12mm offset ends up being 4.5 which the manufacturer lists.
  2. Mar 14, 2018 at 7:06 PM
    #102
    ovrlndkull
    ovrlndkull [OP] STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I have had it bite me wayyy to many times to assume that take my methods for example there the lip is very minimal like .25" so my wheels are only like 9" lip to lip measurement. Based on his calculations they would be off. I just don't assume anything unless I can get the specs from the manuf. and run the calculations to make sure of that. There are wheels with no lips also. Then bead locks is a whole other realm. That is why I negate the lip when I run my calculations. You get end up much more accurate in the end when running the conversions and don't end up screwing your self.
    Oh no I get it, it can be a rule of thumb I just don't use that. I have seen so many variables with the lip that I just decided to go away from using it in my calculations I get where you got yours now though. Just 2 different methods.
    Bocsy44[QUOTED] likes this.
  3. Mar 14, 2018 at 7:12 PM
    #103
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    yeah fair enough hahaha I think that's why I do the math the way he says and then look at what the manufacturer lists. cuz in theory if they didn't use the 1/2'' rule of thumb then the two should not end up being the same you would think? if the two don't match up, then it would be worth investigating into how come, and try to find the specs on the rim to determine how wide the lip actually is, or find out if they list an outside to outside measurement. just something else I need to take into consideration now hahahaha I haven't been screwed over yet :fingerscrossed: and no one has been mad at me for shity advice yet either :rofl:
  4. Mar 14, 2018 at 7:18 PM
    #104
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    So like when measuring the wheel for balancing we measure at the mounting sueface or where the bead seats. There are some factory steel wheel cars that have like a 3/4" lip there to hold hubcaps on but only on the front side the back lip could be the 1/2" or whatever. I learned to never go based on generalizations in the wheel and tire game. I would much rather get the specs from the manufacturer and go from there. Thankfully now a days most wheel manufacturers are going with offset for their specs and leaving BS out of it. Offset is a definitive because it has to do with the true center of the wheel based on the width not adding any lips or glamrings etc to that width to throw you off.
  5. Mar 14, 2018 at 7:21 PM
    #105
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    Slashaar likes this.
  6. Mar 14, 2018 at 7:21 PM
    #106
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    :rofl:
  7. Mar 14, 2018 at 7:26 PM
    #107
    Justanotherhemi
    Rick James
    Truck is coming along nicely Skip.
    So what isbthe story behind the silver cap that came with the truck? Did you sell it off then bought @EatSleepTacos old cap?
  8. Mar 14, 2018 at 7:27 PM
    #108
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    makes sense and now that you mention it, I have noticed some companies don't list a BS. There has to be some secret to cracking the code, like a cheat sheet or something hahaha if the company does not list a BS on their website then base the BS off the listed width and offset and do not add any extra width for the lips and if they do list the BS u can add a lip? hahahaha I would hate to not buy a rim I like just because I cant find the true outside width measurement online. why cant it just be easy and all companies just use a generic way to determine it? ahahaha
    Justanotherhemi likes this.
  9. Mar 14, 2018 at 7:28 PM
    #109
    Justanotherhemi
    Rick James
    You are like the flu. You are everywhere :D
  10. Mar 14, 2018 at 7:29 PM
    #110
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    just re read this and I will have to ponder on this. so instead of using BS to determine poke and shit, base it off the offset?
  11. Mar 14, 2018 at 7:29 PM
    #111
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    If they don't provide BS don't worry abt it go with the regular width they list bc in reality that lip doesn't mean shit to anything on the rim except maybe BS. It has nothing to do with the bead seat or anything.
  12. Mar 14, 2018 at 7:30 PM
    #112
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    He's becoming the new ChadsPride and scooter aka scottalott.
  13. Mar 14, 2018 at 7:31 PM
    #113
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Yep sold it to a hispanic feller. I didn't like the slope up in the back and this one is flat. Plus the contrasting color to me makes it look less long than a huge blob of silver.
  14. Mar 14, 2018 at 7:32 PM
    #114
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    I just like picking ur brain :oops::pout:
  15. Mar 14, 2018 at 7:36 PM
    #115
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Don't pick it too hard I suffer from CRS and that may increase it even more.
    Some sound advice just take everything you read on the internet with a grain of salt even my BS. Like I helped a fellow member change his starter there was all this BS on here that you had to take the exhaust loose or drop the f driveshaft. All that was nonsense every thread telling guys to do it the long and hard way. The damn thing comes out the DS fender well. Take the bolt loose that holds the hard brake like to the frame gently move it a liitle out of the way and it's out. You can get to all the bolts and everything through the fenderwell.
  16. Mar 14, 2018 at 8:27 PM
    #116
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    I have no idea the specs of my wheels, the previous owner already had them on when I bought my yota. Nor could I provide a link since they have so many different sizes of my same wheel. Ill have to do the old school tape measure way when ever i find time.
  17. Mar 14, 2018 at 8:46 PM
    #117
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    hahahaha yeah man, I usually just use it as a starting point for knowledge. read enough different ways to do something and you can piece it together. but like you said, take it with a grain of salt. being mechanically inclined and having a base knowledge of how things works. oh and common sense helps too hahaha but on the plus side, if I have to change my starter I know who to ask hahaha
  18. Mar 14, 2018 at 8:47 PM
    #118
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    fair enough hahaha well I think between me and skip here I think we could get you set up with some wheels you would be happy with hahaha
  19. Mar 14, 2018 at 8:51 PM
    #119
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    What wheels are they?
  20. Mar 14, 2018 at 8:56 PM
    #120
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    not sure what that means
