The Insane Asylum DCLB build and XJ insanity
Discussion in '2nd Gen. Builds (2005-2015)' started by ovrlndkull, Sep 27, 2017.
  1. Mar 1, 2019 at 5:41 PM
    #1261
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    I might take you up on that but not right now hahah I appreciate it! im going to wait a bit tho cuz I need to pay the other half of my front bumper, and I might end up needing to replace my front coils too due to the added weight. I have the 887's right now but im not sure how much this bumper weighs. plus I also need to order my 1'' BL as well hahaha im going to wait to order my HC rear until july or august so I can order the swingout with it and have the cash for it instead of just putting it on my CC. im just putting some money aside every month and I already have some saved up. do u know what metal frame plated people are adding when they install front bumpers? they are like square plates or something
  2. Mar 1, 2019 at 5:54 PM
    #1262
    ovrlndkull
    ovrlndkull [OP] STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    You can either do these, I like them the best because they also bolt to where the sway bar goes on the frame and not just one bolt through the frame. May require some modification to work with your bumper.
    https://www.c4fabrication.com/product/05-15-2nd-gen-tacoma-front-bumper-frame-support-brackets/
    Or this route this replaces the factory 6 bolts with bigger grade 8 ones and turns the chinsy thin metal plate to 3/16" steel wayyyyy beefier.
    http://sosoffroadconcepts.com/weld-on-frame-brace/
    Or if you really want to go crazy do both like @Casper66 did. Although he made both for his truck maybe he can post the pics so you can see. But his bumper isn't going anywhere you'd bend the frame or rip his aluminum before the mounts failed.
    Bocsy44[QUOTED] and Casper66 like this.
  3. Mar 1, 2019 at 6:03 PM
    #1263
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Is this what you are talikng about?
    3/16 plates that tie all the front part of the frame even the cross brace together and I replaced the fatory hardware with grade 8, 1/2" hardware
    or this
    Beefed up frame tie in brackets that take any pull on the bumper back into the frame
    Slashaar, Bocsy44 and geekhouse23 like this.
  4. Mar 1, 2019 at 6:07 PM
    #1264
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    perfect! thanks skip! that's exactly what I was looking for! much appreciated :thumbsup:
  5. Mar 1, 2019 at 6:07 PM
    #1265
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Clean. Gotta get my frame plates done
  6. Mar 1, 2019 at 6:11 PM
    #1266
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    I made mine. When I looked at current designs I figured why not extend them some and tie in more of the frame.
  7. Mar 1, 2019 at 6:15 PM
    #1267
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    SOS Concepts sells them if you don't feel like making them.
    Exactly!!!!
    You're welcome bud :thumbsup:
  8. Mar 1, 2019 at 6:28 PM
    #1268
    geekhouse23
    I got mine from Kore 4x4
  9. Mar 1, 2019 at 6:31 PM
    #1269
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    will ur code save me 10%? ;)
  10. Mar 1, 2019 at 6:34 PM
    #1270
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    What does theirs look like? I noticed after I made these somebody had put out a set that looked just like them.
    Slashaar likes this.
  11. Mar 1, 2019 at 6:35 PM
    #1271
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Yes Skip's code should save you 10% anytime
    Slashaar and Bocsy44[QUOTED] like this.
  12. Mar 1, 2019 at 6:49 PM
    #1272
    geekhouse23
    Slashaar and Casper66[QUOTED] like this.
  13. Mar 1, 2019 at 6:50 PM
    #1273
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Yep on anything on the website. Well except shipping, powdercoat, and line-x. Also doesn't apply to the swag.
  14. Mar 1, 2019 at 6:54 PM
    #1274
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Yep that's very similar. IDK how they figure bolt length. I welded my bolts in place so it's not like I can just change them. When you do them weld the plates up but before you weld the bolts test fit everything and make sure they are long enough. If they're 2" bolts you're good. I used 2" on the next one I did and they came out about perfect. You may be able to get away with 1 3/4 which is why i suggested a test fit with the bumper. Bear in mind i also added the frame tie in brackets which take up space.
  15. Mar 1, 2019 at 7:03 PM
    #1275
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Wanna make me some and add it to the list for the weekend :D:boink:
    Also what do you think should we cut the spring perches off and replace them with correct width ones or just re-use the stock ones on the axle. Just looking for your input on this one.
  16. Mar 1, 2019 at 7:11 PM
    #1276
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    I guess I wont order the bucket of line-x then
    Slashaar, RobP62 and Casper66 like this.
  17. Mar 1, 2019 at 7:14 PM
    #1277
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Either way that is a decision you have to make. Utilizing the existing ones would, of course, be easiest but we aren't going for easy. How much wider are the springs than the perches? perhaps inquire on a thread where they have done this swap? BTW Bill is out with his back again. He should be fine by the time we do this but I can feel his pain
  18. Mar 1, 2019 at 7:15 PM
    #1278
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    From what I understand eddy's LineX guy does really good work
  19. Mar 1, 2019 at 7:17 PM
    #1279
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    yeah that's what the grape vine has been telling me
  20. Mar 1, 2019 at 7:19 PM
    #1280
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Yep! You can believe everything you hear on the internet. I believe this one is true though. @TaKoToy can attest to it first hand.
