The Insane Asylum DCLB build and XJ insanity
Discussion in '2nd Gen. Builds (2005-2015)' started by ovrlndkull, Sep 27, 2017.
  1. Mar 26, 2019 at 8:07 PM
    #1761
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Uh, that would be a bit of a drive
    Slashaar likes this.
  2. Mar 26, 2019 at 8:14 PM
    #1762
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    Well you were the bored one.. just trying to bring some excitement and enrichment to your life
    :annoyed:
    Slashaar and Casper66[QUOTED] like this.
  3. Mar 26, 2019 at 8:15 PM
    #1763
    Dangerdave
    David
    Wilmington, NC
    20 F150
    Yea I need to buy a welder and learn. That’s one major skill I never was exposed to..
  4. Mar 26, 2019 at 8:15 PM
    #1764
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Maybe I'll just take a nap
  5. Mar 26, 2019 at 8:15 PM
    #1765
    Dangerdave
    David
    Wilmington, NC
    20 F150
    Springs ain’t going anywhere. Let me know if you change your mind :D
  6. Mar 27, 2019 at 6:09 AM
    #1766
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I have a Eastwood MIG 135, but would not trust it to do anything more than 1/8"....3/16" is really pushing the limits of a 120v welder even on a 20amp circuit.
  7. Mar 27, 2019 at 6:23 AM
    #1767
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    You hve to deal with what you have and have access to. The machine in my garage is a little bigger and like I told Randy Saturday I have always stuck with what I was taught " yu can always turn a big machine down but you can't always turn a little machine up." The bennifit to the smaller machine, as we discussed, is it is very transportable and you can easily take it to a buddies to work/play. Not everybody is as stupid as I am and runs a dedicated 50A 220 circuit but I needed to also accomodate the plasma cutter. A 110 machine can do a hell of alot I have used one extensively day in and day out doing sheet metal work building body panels. I prefer a hotter machine for structural work but this is just my prefference. If you are going to do a bunch of 1/4" work with a smaller machine and have to crank it up just do it in sections and give your machine yime to recover most do not have a heavy duty cycle. I made the statement on the "anything welding thread" that I didn't trust a smaller machine for structural stuff and had my ass handed to me by several who said they have done alot with one. I don't doubt them and again this was only my opinion which doesn't amount to much. I can tell you I have turned my machine down and done a bunch of 1/8" and 16ge work then turned it up a little and done 1/4" and 3/8" with no problem. Just like these trucks it's finding what works best for you and your needs not about what somebody else does.
    Slashaar, Wild Crow and pabstsmeared like this.
  8. Mar 27, 2019 at 6:31 AM
    #1768
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I def agree. I've only had to use mine half a dozen times, and thankfully it was for thin body panels on my Dad's old cars. Being so small and portable is why I got it in the first place.
    I wish I could get my hands on more welding projects or some scrap metal, I need to get better at laying down good beads.
  9. Mar 27, 2019 at 6:35 AM
    #1769
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    If you're running big droop 16"+ on a desert truck that jumps, the eyes being perpendicular to the frame allows the axle to swing forward more around the fix eye side of the leaf spring and not bind the shock.
    If you're rock crawling with big articulation left to right. Having the eyelets in parallel with the frame lets the shock swing left to right and not bind the shock.
    Depending on how you mount the lower eyelet you can mitigate either situation.
    Hobart Handler 140 all day for a budget machine. They are fine for anything you will do on a truck
    Then my truck and everyone I know's truck should have killed a bus full of nuns on the highway according your theory. None of my friends or I have anything more than a 120v welder and all are solid axle swapped, caged, trucks that have been driven on the highway or to the trailhead for years.
  10. Mar 27, 2019 at 6:45 AM
    #1770
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Good to know. The bottom eyelet can only really be mounted one way, and that is parallel with the axle.
    I'm assuming for everyday driving and the occasional off roading either mount direction of the top would be perfectly fine. I'm probably not going to run more than a 12 or 14" rear shock anyway.
    I never said it couldn't handle it, but the thick stuff is pushing the upper limits of a 120v welder. Like Chris said, you can turn a big welder down, but you can only turn a little welder up so high. Like you, I got mine to be portable and not take up a lot of room. I've done 3/16" once and it did the job fine, but I tripped the breaker twice. I don't plan on running a dedicated 220v 50A circuit in my garage or shed any time soon, so the little guy is plenty for me.
  11. Mar 27, 2019 at 7:07 AM
    #1771
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Conversely, voltage regulators are happiest running at max voltage. There is quite a bit more strain on a regulator (MOSFET or IGBT) that is regulating power way down than running full song and not having to impede power delivery from the supply.
  12. Mar 27, 2019 at 8:23 AM
    #1772
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Find a machine shop or a metal supply place and see if they have any scrap they will sell you can most likely get pretty cheap
  13. Mar 27, 2019 at 8:30 AM
    #1773
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    This is what I was trying to say find a machine that works for you. Now take your 110 machine and turn it up and burn in 1/2" with .044 on a single pass. Your absolutely correct you found what suits your needs. I've been doing this stuff for just a little bit like 35 years and I like to burn shit in hot plus I like the versatillity of being able to do some heavyier shit with confidence. Again this is just what works for me
  14. Mar 27, 2019 at 8:34 AM
    #1774
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I'll try to snag some from Eddy next time I'm down there. He has plenty I'm sure.
  15. Mar 28, 2019 at 10:57 AM
    #1775
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    This thread sucks. Unsubscribed. Going back to shit posting in the 3rd gen forum.
    :anonymous:
    Slashaar, Casper66 and ovrlndkull[OP] like this.
  16. Mar 28, 2019 at 11:38 AM
    #1776
    ovrlndkull
    ovrlndkull [OP] STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I know right all the excitement is over :rofl:
    Guess I need to go flex this thing out and post some pics!
    Slashaar and Casper66 like this.
  17. Mar 28, 2019 at 11:47 AM
    #1777
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I guess I'll stay then.
    I'll get banned if I start posting in the 3rd gen forum anyway.
  18. Mar 28, 2019 at 12:10 PM
    #1778
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    OK, so, I'm bored...Think I got the 63 swap list figured out, for the most part, that I'm gonna go with soon(ish).
    3+1 springs, no over leaf - junkyard
    BAMF towers
    King 12" w/RR
    Ruffstuff 63 swap kit - 3.25" u-bolts, 5" shackle
    Ruffstuff frame outriggers
    Limiting straps - length TBD
    Poly bushings for springs - TBD if necessary
    Wheeler's SuperBumps - have already
    Bumpstop Extenders - will have to measure and custom make
    Extended Brake Lines - length and manufacturer?
  19. Mar 28, 2019 at 12:13 PM
    #1779
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  20. Mar 28, 2019 at 12:17 PM
    #1780
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
