The joys of towing - 10mpg!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sungod, Sep 19, 2024.
  1. Sep 19, 2024 at 9:01 AM
    Sungod
    Sungod [OP] Well-Known Member
    St Augustine
    Once again towed a car with the U-Haul car carrier and was blessed with 10mpg towing the flats of Florida. The Transmission is absolutely garbage. Constant down shifting and high RPMs just to maintain highway speeds. Ran about 3k rpm most of the way. If I hit any type of incline, it dropped another gear and would scream to 4500 rpm. 67mph was the best I could do to keep the rpms at 2000 which I assume it 8th gear.
  2. Sep 19, 2024 at 9:06 AM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Did you use ECT and S-4 (not D)? Tacoma needs higher revs to get better torque, and gear 5/6 drops revs too much for that torque.
    Vmax540, Old goat1914 and Metalskool like this.
  3. Sep 19, 2024 at 9:07 AM
    NOLAN_3G4R
    NOLAN_3G4R Active Member
    NOLAN
    WNC
    '87 4RUNNER/'97 TACO/'97 4RUNNER
    MOSTLY STOCK
    Tacoma isn't the best for towing, its a midsize truck. If you tow a lot I probably would've bought a Tundra or a real, domestic full-size. Also, Tacomas come with 5/6 speed gearboxes.
    .劉煒 and Chew like this.
  4. Sep 19, 2024 at 9:09 AM
    Metalskool
    Metalskool Adversity Builds Character
    Michael
    2020 TRD 4WD
    what richochet said^
    and a tune makes worlds of difference. I still get crap mileage [KD Max tune] but up/down shifting is over and I just use D4 with no ECT button.
    Stuck in VT likes this.
  5. Sep 19, 2024 at 9:12 AM
    Shellshock
    Iowa
    3rd gen only has 6 gears
    ECT helps
    when I towed with my auto I usually stayed at 65 or less. it really didnt like going faster than that. with the manual transmission once I got to 5th gear, I could go whatever speed I wanted and it didnt care.
    .劉煒, 02Duck and BabyBilly like this.
  6. Sep 19, 2024 at 9:28 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    The 3.5 makes power in the upper RPM range, so it sounds like it was performing as designed. The transmission was doing what it was told by the ECU, based on where the engine makes it's power needed for the demand.
    As mentioned, this is far from a tow vehicle. Yes, it can tow smaller/ lighter loads. But if you are going to moving vehicles, you have the wrong truck.
    U-Haul lists their trailer at 2,210 pounds empty, how much was the vehicle and all the other gear occupants?
  7. Sep 19, 2024 at 9:31 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    F-450 6.7 diesel is what you need, it's probably overkill but any diesel tow truck I drove you barely could feel a car back there. The V8s weren't bad, any HD truck would probably be fine along with most 1/2 tons.
    DavesTaco68 and Steves104x4 like this.
  8. Sep 19, 2024 at 9:38 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    How heavy was this car? I get 14-15 or so mpg pulling 4200 lbs of car + trailer out of my nissan, but that's a 6 speed manual.
  9. Sep 19, 2024 at 9:39 AM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    MT, FTW
    again :D
  10. Sep 19, 2024 at 10:07 AM
    Mtbkrguy
    Mtbkrguy Well-Known Member
    2016 Tacoma TRD Sport 4x4 Double-cab
    Yeah I recently towed a 5x8 uhaul trailer about 900 miles through Florida and Georgia as well and got about 11-12 mpg.
    Sungod[OP] likes this.
  11. Sep 19, 2024 at 10:53 AM
    BOBSTOY 53
    BOBSTOY 53 Well-Known Member
    2023 Tacoma Sport
    none
    If you think your Tacoma is in 8th gear. you probably never read the owners manual. That book would show you are way overweight.
  12. Sep 19, 2024 at 11:00 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Having towed a small camper with the wife's Forester I would have thought my Tacoma would have
    handled it better. It's just fine on flat level roads but inclines were a bit difficult. I run ECT and S4 with
    occasional push-ups into S5 on the downhill slides but also drop-downs to S3 on steep inclines at elevation.
    Thought the V6 would have been better at this. I still love the truck and wouldn't trade it tho.
  13. Sep 19, 2024 at 11:03 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    And then they decided to make the engine even smaller. Big logic.
  14. Sep 19, 2024 at 11:10 AM
    2021SR5V64WD
    You couldn't give me a Gen4 - I don't like that new-fangled-turbo thing they put in it and I don't
    care for the new body styling either.... For what it is the Gen3 is just about perfect...
    Old metals and grogie like this.
  15. Sep 19, 2024 at 11:12 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Don’t think the transmission is the issue the engine is just underpowered.
    Mikeymopar and Bluridge120 like this.
  16. Sep 19, 2024 at 11:49 AM
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    My experience was there is too large a gap between 3rd and 4th. It couldn’t pull in 4th, but 3rd required so little throttle input to maintain speed.
  17. Sep 19, 2024 at 1:01 PM
    Sungod
    St Augustine
    I tried ECT and made no difference.
    I must have been thinking about the IS, but yeah, 6 speed! If you drive around Miami anything under 70 you will get ran over. Well except when you are sitting in miserable traffic with the rudest people on earth.
    3700 lbs IS 350 and the uhaul auto transport which weighs 2200 lbs. I think this was a scenario that I could have been better off with a manual that I could have left in 6th and just dealt with the speed changes without having to down shift. I wasn't expecting great mileage based on other tows, but wasn't exactly thrilled to see 10 mpg.
  18. Sep 19, 2024 at 1:06 PM
    RichochetRabbit
    ECT helps by forcing the gears to hold off changing ... higher revs. But S4 limits the ECU from shifting higher ... you force the transmission from going into a lower rev gear. Also consider speed control ... highway driving with just a few normal things in the truck at 70 was low ... dropping to 65 was more stable, 60 held 20 MPG better.
    Bluridge120 likes this.
  19. Sep 19, 2024 at 1:07 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Size has nothing to do with it. The smaller fourth gen engine blows the 3.5l out of the water in every performance metric.
    Vmax540 likes this.
  20. Sep 19, 2024 at 1:10 PM
    Old goat1914
    Old goat1914 Well-Known Member
    Chicagoland, Indiana
    2016 TRD Sport DCLB 4x4
    Your engine is designed to run fast where it makes the most power. It won't hurt it. You might need earplugs. Google 2016 Tacoma Ike Gauntlet on YouTube.
    Spadi_5 and Chew like this.
