The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Jan 17, 2018 at 7:45 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Think so?​
  2. Jan 17, 2018 at 7:46 AM
    ChadsPride
    This makes sense!!!​
    Just kinda scratching my head playing around with numbers
    Would prefer to only have to buy 'coilovers' once lol
  3. Jan 17, 2018 at 7:46 AM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    yeah, if you want the extra length and same #/in its not bad
    ChadsPride[QUOTED] likes this.
  4. Jan 17, 2018 at 7:47 AM
    ChadsPride
    887s should hold the weight and net me 2"?
  5. Jan 17, 2018 at 7:49 AM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    They'll net you more, around 3" They're the same coil as the 884 and 885 (590 lb coil) but even longer.
    inesshell and ChadsPride[QUOTED] like this.
  6. Jan 17, 2018 at 7:50 AM
    inesshell
    believe so, normally it gives 2.5 with no steel. Depending on what you have up front it should settle. if you think its too much just go for the same #/in but not extended length coil.
  7. Jan 17, 2018 at 7:50 AM
    ChadsPride
    Ok cool...Maybe the 886 then?
    Ive been thinking about this for days
    Finally decided to break down and ask for halp lol
  8. Jan 17, 2018 at 7:51 AM
    inesshell
    ChadsPride likes this.
  9. Jan 17, 2018 at 7:51 AM
    inesshell
    you dont want an 886 unless you running winch and steel lol. Mine never settle and net me over 3"
  10. Jan 17, 2018 at 7:52 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    @ChadsPride another option I forgot about is these eibach coils. They're a 620lb coil and only will net 1.5" lift, and can throw small spacers on top if you want higher.
    http://toyteclifts.3dcartstores.com/112-620--ToytecEibach-front-coil-lift-springs_p_14.html
    For reference, the 883, 884, 885, and 887 are all 590lb coils. The 886 is a 660 lb coil. This is right in the sweet spot.
    Those would be too tall, around 2.75". They're even taller than 885 and way too stiff for your needs.
  11. Jan 17, 2018 at 7:52 AM
    ChadsPride
    Good info!!! 886 are off the board
    So why 887s over 885s?
  12. Jan 17, 2018 at 7:54 AM
    ChadsPride
  13. Jan 17, 2018 at 7:55 AM
    inesshell
    887 is more of a buffer, at first it will give you more than the 2" you want. Its hard to tell what you want to put on and how it will settle.
  14. Jan 17, 2018 at 7:55 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Now that I remembered those, that's honestly the route I'd go. Then just get extended studs on top of the coilover, so if you want to throw in a 1/4" or 1/2" spacer on top you easily can.
  15. Jan 17, 2018 at 8:42 AM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    We are finally slated to get our first major winter storm Friday night through Saturday!
  16. Jan 17, 2018 at 9:05 AM
    inesshell
    yep we getting some white stuff, need to plan a day to go play in it
  17. Jan 17, 2018 at 9:18 AM
    LocoLocal
    LocoLocal Aspiring Polymath
    39.081221472127545, -77.45538862919935
    Large American
    I really might need a new drive shaft though. I haven't greased my u joints in like 50k miles.
  18. Jan 17, 2018 at 9:21 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Couldn't you just replace the U joints?
  19. Jan 17, 2018 at 9:38 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Well do it
  20. Jan 17, 2018 at 9:40 AM
    LocoLocal
    Large American
    Could, yes...
    I am going to Friday night.
    fatfurious2[QUOTED] likes this.
