The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Jan 24, 2018 at 7:54 PM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    That sounds like a pretty stressful time!
    Kuntrykid and TacomaCody[QUOTED] like this.
  2. Jan 24, 2018 at 8:13 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    Do you Va and Md boys even parallel park?
    Kuntrykid, TacomaCody and Grand dude like this.
  3. Jan 24, 2018 at 8:14 PM
    TacomaCody
    TacomaCody STOAA VIP Platinum Member
    Cody
    Iowa City, Iowa
    2012 Tacoma silver SR5 Off Road 4x4
    Body Armor 4x4 front bumper, running boards, cherry bomb vortex, 2" supreme suspension wheel spacers, Pro comp rock crawler wheels, 2017 off road full suspension, leer camper shell
    Let's just say her mother was uninvited and banned
  4. Jan 24, 2018 at 8:17 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I can do it. @GeneralGadsen has no idea how to
    Grand dude and Redmann[QUOTED] like this.
  5. Jan 24, 2018 at 8:20 PM
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    I had an HR plus put almost 40000 on it in a yr& half been in the burgh & only put lil less the 15000 in just bout 2yrs. Big difference. @ bout 53000 now. It's only a 2015!
    Bocsy44[QUOTED] likes this.
  6. Jan 24, 2018 at 8:23 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    TacomaCody likes this.
  7. Jan 24, 2018 at 8:36 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    "That sum bitch jus as strong as factory rite there" :rofl:
    I just respooled my winch tonight after work. My winch came with the synthetic line. I don't know how you guys with the metal lines do it. If it were me, I would want to change that metal line out for a synth line asap. It's so much easier to handle, safer, and the weight difference.
    Bocsy44 likes this.
  8. Jan 24, 2018 at 8:41 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Literally the only reason I went with steel over synthetic is cost, and nothing else. It was $300 for my winch and IIRC it was around $450 for the same thing with syn. I would like syn and will switch eventually when my steel cable wears out as it's definitely easier to handle and safer. I just watched some videos on it snapping and it just falls to the ground! I will give a win to steel on the maintenance aspect though. Just need to occasionally wipe it down with WD-40 whereas with syn you should be washing it after every muddy wheeling trip to get the grit out from in between the fibers.
  9. Jan 24, 2018 at 8:45 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    for sure. I agree. there's pluses and minuses to everything. I got a decent deal on mine, was $380 out the door for a 9500lb winch. The maintenance is about the only win I see for the metal lines. the cost? well deals can be had at the right times of the year. I also used Ebates and it was a decent percentage cash back on top of the 380$.
    Frankly, it amazes me that a synth winch line is as strong as it is. same with soft shackles.
  10. Jan 24, 2018 at 8:48 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah the strength thing blows me away, and I'm a believer in soft shackles now after using them this last weekend with @bski22. I want to get myself some since they're a bit more versatile than the standard D ring style.
    Kuntrykid and bski22 like this.
  11. Jan 24, 2018 at 8:52 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    Yep. I'm actually looking to put soft shackle mounts on my bumpers now instead of DRing mounts. I want to eliminate any possible steel that I can.
  12. Jan 24, 2018 at 8:54 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Aren't the mounts the same thing? Or would they just be a little more rounded on the inside edges?
  13. Jan 24, 2018 at 9:00 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    Where the Drings mount to is generally a hole drilled in about 3/4" steel. The edges of the holes aren't conducive to a soft shackle. They would more than likely start shearing thru the fibers. If the edges were filed down some, then yeah it would be better. But then you still have the 3/4" hole to thread the soft shackle end through. In my mind, using a 3/4" solid round bar (or tube... whatever is stronger) that has a slight bend in it and welded to a bumper would be a lot better.
  14. Jan 24, 2018 at 9:01 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    Sort of like this, but less obtrusive. I would want the bend in the tube flattened out more.
    https://youtu.be/7Z-1gA95G_s
  15. Jan 24, 2018 at 9:01 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ahhh, that makes sense. What'd be cool is one of each on each side (bent on one side and traditional recovery point on the other), just to be the most versatile you can be and account for more scenarios, even if it looks a little funky. Or just carry a hitch shackle receiver in the off chance you need to use a d ring.
  16. Jan 25, 2018 at 3:57 AM
    ChadsPride
    Sponsored by TacomaWorld.com
  17. Jan 25, 2018 at 4:12 AM
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
  18. Jan 25, 2018 at 6:19 AM
    TacomaCody
    Cody
    Iowa City, Iowa
  19. Jan 25, 2018 at 6:53 AM
    TaKoToy
    TaKoToy Well-Known Member
    Robbie
    Prince George VA
    2013 4x4 OffRoad, 2020 cement DCLB OR
    Mostly stock
    $1900 sound about right for a regear to 4.88 installed? I just got a quote from ECGS.
    ChadsPride likes this.
  20. Jan 25, 2018 at 7:29 AM
    Kemosabe
    Louis
    :notsure:
