The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Feb 16, 2018 at 12:49 PM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    These ones! It may not seem like a lot, but it gives you a surprising amount of room to work underneath.
    RhinoGear 11909ABMI RhinoRamps Vehicle Ramp - Set of 2 (12,000lb. GVW Capacity) https://www.amazon.com/dp/B0117EETEK/ref=cm_sw_r_cp_api_ip0HAb6369CMV
  2. Feb 16, 2018 at 1:00 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    That's a lot of hashbrowns
    08TRDOFFROAD[QUOTED] likes this.
  3. Feb 16, 2018 at 2:52 PM
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    Is it really a necessity to change brake fluid? Before tw I've never heard anyone change it except when bleeding
    Bocsy44, Skell and EatSleepTacos[OP] like this.
  4. Feb 16, 2018 at 4:45 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I think it gets old..
    Kemosabe[QUOTED] likes this.
  5. Feb 16, 2018 at 5:08 PM
    Kemosabe
    Louis
    Ah...
  6. Feb 16, 2018 at 5:17 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    New brake juice should be changed. The older stuff (which isn't sold anymore) not so much.
    Empty the reservoir, fill with new fluid. Don't empty the whole system. If you do, you'll have to bleed. Run it for a week. Then after a week or so, repeat the process and fill with new. Boom. No need to bleed and you've changed the fluid.
    The new brake juice likes water. It will cause your lines to rust. It is water soluble.
    Edit: I asked my boss who is very much into cars and restoring them.
    Bocsy44, BravesRunner and Kemosabe like this.
  7. Feb 16, 2018 at 6:21 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    The way I understand it is the only way to change the fluid in the lines is to bleed them... otherwise when you replace the fluid in the reservior, it just stays put as the brake system is not recirculating the fluid. :notsure:
    Blackout14, Fifthwind and Kemosabe like this.
  8. Feb 16, 2018 at 6:23 PM
    Kemosabe
    Louis
    Those are great advices, but I won't change my fluid lol
    Bocsy44 and Redmann[QUOTED] like this.
  9. Feb 16, 2018 at 6:26 PM
    08TRDOFFROAD
    Dan
    The need to change your brake fluid is due to moisture build up in the old fluid. It reduces the boiling point of the fluid causing braking power to diminish as heat builds in the system during hard stops (not a time I would want my brakes to stop working) and on top of reduced performance, like @Redmann mentioned, the water building up in the system can rust your brake components from the inside out.
  10. Feb 16, 2018 at 6:32 PM
    08TRDOFFROAD
    Dan
    :fingerscrossed:
    I will never understand why they don't use a higher grade metal in the bleeders.
    I have seen several videos on YouTube of different mechanics snapping off bleeder screws while trying to service brake systems. One I can clearly remember (Ericthecarguy) ends up bleeding them at the caliper or drum where the line connects to it after breaking several bleeder screws. But there is still that small fraction of fluid still inside the caliper that doesn't get changed that way.
    On my next vehicle I will service and clean the bleeder screws at each oil change so that the need for a complete flush will never happen because I will rotate the fluid a little each time I crack the bleeder at the service intervals. Then just top off the reservior when finished.
    ovrlndkull and Redmann like this.
  11. Feb 16, 2018 at 6:33 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    I can see what you're saying. It's not like there is a feed and return line for the fluid. It's just a supply.
    From what my boss said, you will notice the new fluid turn darker after that first week of using the new. That's why he says to change it the 2nd time.
    Disclaimer: I never changed my fluid either. I only ever fucked with it when I installed new brake components (other than pads) on a vehicle.
  12. Feb 16, 2018 at 6:34 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    This sounds like the most logical way to me
  13. Feb 16, 2018 at 6:56 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    You are correct brake fld is hydroscopic thus absorbs moisture that may get into the brake system to keep it from sitting somewhere and rusting something out more. There can be a reduced feeling of brakes due to this moisture. But on older vehicles with some mileage on them a lot of that reduced feeling has to do with the master cycl., calipers and/or wheel cycl. being old and getting a little tired. I would recommend changing your brake fluid around the 30k interval. Some of the newer synthetics can go longer. That brings up another point don't ever mix the synthetic brake fld with non, you must completely empty your system first before switching to synthetic.
    I like your idea of bleeding a little out at each oil change. The only issue is most of the water trapped in a brake system is in the reservoir. The cap and seal are where the infiltration of moisture usually occurs.
    This is how we do it in the shop.
    1) suck out all the fld in the reservoir and refill with new. You can use a hand vacuum pump or one that is pneumatic.
    2) fill secondary reservoir that pressurizes and attach to vehicle fill port
    3) open all bleeders then pressurize the fluid tank close all bleeders starting with furthest from the master and working your way to the closest.
    Here is an image of a flush tool that is similar to what I use except instead of a pump I used one that pressurizes from shop air. These are also used as a pressurized bleeding system.
    Redmann and 08TRDOFFROAD[QUOTED] like this.
  14. Feb 16, 2018 at 6:56 PM
    08TRDOFFROAD
    Dan
  15. Feb 16, 2018 at 7:05 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Yeah I have watched ETCG I also like Humble mechanic. Humble mechanic use to work with my buddy at the VW dealership. Both them are actually putting some decent real world information out there and not just keyboard commando shade tree crap that isn't true. As a fellow auto tech I really appreciate those 2.
    08TRDOFFROAD[QUOTED] and Redmann like this.
  16. Feb 16, 2018 at 8:41 PM
    08TRDOFFROAD
    Dan
    Well, my light bar already more than paid for itself....
    Took my oldest for a ride to put him to bed for the night...light bar saved me from what likely would have been a close call with a small group of antelope. I was able to see them headed to cross the road in front me with at least 100 yards to spare. Was able to slow down, hit my hazards, and slowly approach as the group finished crossing the road. I was a bit leary though, as I know the herd is LARGE (75-100 head strong) so I was half expecting the dummy that was potentially lagging behindhe group to Sprint at 60 mph out in front of me...like the Kamakazi deer I hit did!
  17. Feb 16, 2018 at 8:42 PM
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    So I finally pulled the trigger on this puppy. I will be using it to air down when I go to the beach. Ebay had a 20% off coupon for Presidents day so I bought it for $47.xx not that bad of a deal if you ask me
  18. Feb 16, 2018 at 8:43 PM
    Justanotherhemi
    Rick James
    Lit Norris for the win!
  19. Feb 16, 2018 at 8:59 PM
    TacomaCody
    TacomaCody STOAA VIP Platinum Member
    Cody
    Iowa City, Iowa
    2012 Tacoma silver SR5 Off Road 4x4
    Body Armor 4x4 front bumper, running boards, cherry bomb vortex, 2" supreme suspension wheel spacers, Pro comp rock crawler wheels, 2017 off road full suspension, leer camper shell
    There are antelope in Utah??
  20. Feb 16, 2018 at 9:19 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    I was thinking the same thing! :rofl:
