The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Apr 30, 2018 at 8:08 AM
    bski22
    bski22 Shaka Zulu \000/
    Rob
    Toyota
    Who...
    @DoubleRGirl
  2. Apr 30, 2018 at 8:21 AM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    My truck is not optimal for wheeling right now.
    I think I’m gonna do a welding day at my place this weekend. Maybe bring stuff that you need welded? You can borrow my welder.
    @HolyHandGrenade - will my 4.5 gallon Porter Cable compressor work with the plasma cutter that you have? If it will, maybe I’ll order one up and hope it gets to my doorstep before the weekend.
  3. Apr 30, 2018 at 8:31 AM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    next weekend? weekend after? Still gonna head up there and scope some stuff out, I can probably swing by to weld some things up, I need to get my rear bumper done :rolleyes:
  4. Apr 30, 2018 at 8:38 AM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
  5. Apr 30, 2018 at 8:40 AM
    Subway4X4
    Lloyd
    NY/NJ
    I’m thinking this weekend because my wife and daughter are gonna be out-of-country for a week. Which means I have a spare car in case my truck is incapacitated.
    I’m gonna weld up my Cam Tab gussets and a couple other small things.
    Lux[QUOTED] likes this.
  6. Apr 30, 2018 at 9:11 AM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    Ugh I gotta go those. My OEM cam tabs are ugly. I did some other things yesterday though. Rear diff fluid change, retorqued my whole rear suspension after last weeks install, put my skids back on, painted the rest of the rear axle and whatever else I could find to paint under there.
    Subway4X4[QUOTED] and bski22 like this.
  7. Apr 30, 2018 at 9:33 AM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I really don’t know. I don’t know what that compressor puts out. I don’t know the plasmas minimum requirements.
    I never cared to look into it because I knew I wouldn’t have to worry about it.
    Take your blow gun, set the regulator to 60 PSI. However long it’ll maintain 60 PSI, is how long you’ll be able to run the plasma in one shot.
    RobP62 and Subway4X4[QUOTED] like this.
  8. Apr 30, 2018 at 9:39 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I might’ve been interested in swinging by, but I’m headed to NH this weekend. Taking the Hobart and the Plasma to do a little project for my Folks.
    bski22 likes this.
  9. Apr 30, 2018 at 9:46 AM
    Subway4X4
    Lloyd
    NY/NJ
    I should just order the plasma no matter what. I think my compressor should be fine.
    Can you link me again to that Plasma cutter please?
  10. Apr 30, 2018 at 10:15 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Lotos LT5000D Plasma Cutter 50Amps Dual Voltage Compact Metal Cutter 110/220V AC 1/2" Clean Cut https://www.amazon.com/dp/B004VFJL14/ref=cm_sw_r_cp_api_i_X805AbCNJ1ST7
    It runs better with extended tips
    bski22 likes this.
  11. Apr 30, 2018 at 10:18 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
  12. Apr 30, 2018 at 11:33 AM
    Subway4X4
    Lloyd
    NY/NJ
  13. Apr 30, 2018 at 11:47 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  14. Apr 30, 2018 at 2:08 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    This 11 lb propane tank is the perfect size! Perfect measurements for a swingout. Next to a regular 20 lb tank for comparison.
    81F833B5-F09F-4F54-9953-7FB5749CB4F8.jpg 4FEE2C25-4D9F-4DB1-A94B-90B48A4DD3A3.jpg
    HCJ, BravesRunner, Lux and 2 others like this.
  15. Apr 30, 2018 at 2:11 PM
    JWROSE4
    JWROSE4 Well-Known Member
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    Where you putting it at on your swingout?
  16. Apr 30, 2018 at 2:12 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I have nothing on there right now, so I’ll put the propane tank and one Jerry can on there.
    RobP62 and JWROSE4[QUOTED] like this.
  17. Apr 30, 2018 at 2:30 PM
    bski22
    Rob
    Toyota
    Dude you’re going to carry that on the swingout?
  18. Apr 30, 2018 at 2:51 PM
    fatfurious2
    David
    Ashburn, VA
    going to make those Maryland drivers scared to drive behind him
  19. Apr 30, 2018 at 3:06 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    Is that legal?
  20. Apr 30, 2018 at 3:08 PM
    fatfurious2
    David
    Ashburn, VA
    @Chux has.. not illegal? o_O
    Lux[QUOTED] and Chux like this.
