The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. May 14, 2018 at 6:35 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    so I can choose between ground tent or RTT
    Comatose and ChadsPride like this.
  2. May 14, 2018 at 6:38 AM
    bski22
    bski22 Shaka Zulu \000/
    Rob
    Toyota
    nope
    Chux, Comatose and EatSleepTacos[OP] like this.
  3. May 14, 2018 at 6:41 AM
    fatfurious2
    David
    Ashburn, VA
    thanks. your opinion will not be considered
  4. May 14, 2018 at 6:44 AM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    At least he’s not going to buy a $230 portable fire ring :boink:
    fatfurious2 likes this.
  5. May 14, 2018 at 6:48 AM
    bski22
    Rob
    Toyota
    I wasn't going to buy it. that was solely an olive branch for you to gain some EAF points :cookiemonster:
  6. May 14, 2018 at 6:49 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Kemosabe and bski22[QUOTED] like this.
  7. May 14, 2018 at 6:51 AM
    bski22
    Rob
    Toyota
  8. May 14, 2018 at 6:53 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You’re crazy :laugh: :crazy:
    bski22[QUOTED] likes this.
  9. May 14, 2018 at 7:02 AM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    ya know what makes a good fire ring? It's cheap, found everywhere, and takes up zero space on your truck. When you're done with fire making activities, simply leave this ring right where it is! That's right folks, its ROCKS! Found everywhere that there is earth. The come in all sizes from small pebbles to large boulders to suit all your fire making needs. They also double as a heater for your tent! Whoa
    Kemosabe, Bocsy44, twheat40 and 3 others like this.
  10. May 14, 2018 at 7:03 AM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    depends on how they're sitting I guess :notsure:
    edit: I don't use my computer much and sigs dont show up on my phone.
    EatSleepTacos[OP] likes this.
  11. May 14, 2018 at 7:09 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    :rofl: That’s basically what I said on the gram. No ring? Just light the fire on the ground. A ring isn’t completely necessary
    Redmann[QUOTED] likes this.
  12. May 14, 2018 at 7:09 AM
    fatfurious2
    David
    Ashburn, VA
    Cant I dig a hole with the shovel that I already have??
  13. May 14, 2018 at 7:11 AM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    Too much work. Not EAF at all.
  14. May 14, 2018 at 7:11 AM
    fatfurious2
    David
    Ashburn, VA
    you dont even know what it is. You stay in hotels
  15. May 14, 2018 at 7:13 AM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    I don't get paid for what I do, I get paid for what I know.
    Kemosabe, Subway4X4 and Bastek like this.
  16. May 14, 2018 at 7:14 AM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Ideally i'd have both. working with a torch inside a panel sucks because the exhaust gas melts other shit.
  17. May 14, 2018 at 7:16 AM
    fatfurious2
    David
    Ashburn, VA
    cool story bro
  18. May 14, 2018 at 7:32 AM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    Had anyone has the traction control light stay on? I think I read somewhere that after an alignment or after going up in tire size ( or sure how that would affect things) or after SOMETHING that the light stays on. I'm having that issue now. I read that the VSC computer needs to be reset. :notsure:
    Although, I should probably fix the broken wheel sensor wires firstly. Eliminate the known problems before digging into something that could be correlated to the bigger issue at hand :anonymous:
  19. May 14, 2018 at 7:42 AM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    https://www.tacomaworld.com/threads...ibrate-your-vsc-computer-the-easy-way.467485/
  20. May 14, 2018 at 7:45 AM
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Yeah, thars the one. ..
    How to reset and calibrate your VSC computer - The Easy way
