The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Jun 24, 2018 at 9:01 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Are you using the spring compressor to avoid the need for an alignment? I always like to follow your build, so what did I miss as to why or what are you doing to require a compressor?
  2. Jun 24, 2018 at 9:04 AM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    Yes, that's exactly it! I have a new noise coming from up front, so this weekend I took the front tires off and checked everything out and torqued it down. Everything seems alright, except the bushings on my coilovers are shot. I knew this already, so I already have new parts ready to be installed.
    I'll need to disassemble the coilover and usually I just do the method where I loosen the alignment bolts and disassemble it that way. Only downside is an alignment is needed afterwards.
    What I will likely end up doing is just marking where each alignment tab is very precisely, and then just put them back in that spot. That should be good since no other factors will be changed.
  3. Jun 24, 2018 at 9:16 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    So my 22" Amazon lightbar that I bought 6 weeks ago already has moisture from all this crazy ass rain. I hit up amazon because technically the light is advertised as waterproof, and they're gonna let me return it for a full refund. This next light will get sealed up before install!
    Kemosabe likes this.
  4. Jun 24, 2018 at 1:45 PM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
  5. Jun 24, 2018 at 1:46 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Lifts make life so much easier when working under trucks
    RobP62 and Comatose[QUOTED] like this.
  6. Jun 24, 2018 at 1:48 PM
    Comatose
    Miguel
    San Diego, CA
    Now the squeaking is different. Not sure if because new or I'm an idiot. But soon as I got the shaft off the cb was for sure bad.
    RobP62 likes this.
  7. Jun 24, 2018 at 1:50 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    haha I hope you don't have multiple squeaks and you only managed to fix one
    RobP62 likes this.
  8. Jun 24, 2018 at 2:28 PM
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
  9. Jun 24, 2018 at 2:45 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Oh snap, looking good!
    Kemosabe[QUOTED] likes this.
  10. Jun 24, 2018 at 2:57 PM
    Kemosabe
    Louis
    Thanks!
    Thanks! Took so long to decide on when I'll do it haha took around 3 hours, including putting back the tools in the toolbox and also took off my brake pads pins, wire wheeled them and put sone anti seized and put back. Ride nice!
    Now the question is! I now sit 1/4" under what I had before with the spacer lift, do I need an alignment?
  11. Jun 24, 2018 at 2:57 PM
    Comatose
    Miguel
    San Diego, CA
    Well if y'all ever need help with carrier bearings, I know a guy.
  12. Jun 24, 2018 at 2:58 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I definitely would!! Unless you plan on adding a 1/4” spacer, then do that first.
  13. Jun 24, 2018 at 3:22 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Did you check your angles? That bearing needs to be a certain way to achieve the correct angle, or so I've read.
    I actually read that some guys after adding a lift discovered that it was upside down from the factory. When they flipped it, it corrected the angles and the vibrations disappeared.
    Likey just more useless info from the guy that doesn't know squat about lifts. Me.
  14. Jun 24, 2018 at 3:23 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Did you grease your U joints?
    Comatose[QUOTED] likes this.
  15. Jun 24, 2018 at 3:25 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Man I love this thread. So much to learn! Thanks for the detailed explanation Randy. :thumbsup:
  16. Jun 24, 2018 at 4:38 PM
    Comatose
    Miguel
    San Diego, CA
    It's not vibes, it's a terrible squeaking. It's got the cb drop on it now. I'm probably going to remove it tomorrow to see what that does.
    Did that yesterday.
    RobP62[QUOTED] likes this.
  17. Jun 24, 2018 at 4:40 PM
    Comatose
    Miguel
    San Diego, CA
    That yoke was a PITA to remove.
    RobP62 likes this.
  18. Jun 24, 2018 at 4:47 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ooooooo, miiiikkkeeeee you’re not supposed to clamp directly on the driveshaft. Also your shit looks like the Eiffel Tower
    JWROSE4 likes this.
  19. Jun 24, 2018 at 4:49 PM
    Comatose
    Miguel
    San Diego, CA
    It's fineeeeee. That's only a suggestion.
  20. Jun 24, 2018 at 4:51 PM
    Comatose
    Miguel
    San Diego, CA
    It's for sure a bad u-joint though.
    EatSleepTacos[OP] likes this.
