The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Aug 9, 2018 at 5:58 PM
    twheat40
    twheat40 POOP Custodian
    Tyler
    2017 4Runner SR5 Premium
    I mean you definitely had the best answer.
    Lololol
    Kemosabe likes this.
  2. Aug 9, 2018 at 5:59 PM
    EatSleepTacos
    EatSleepTacos [OP] MOBTOWN OFFROAD AMBASSADOR
    Randy
    Chesapeake, VA
    4x4 2005 SR5 AC 6MT POOP Edition
    He did. Until Jerry whipped out the big guns
    Vvvvvvv
    UntamedTaco and twheat40 like this.
  3. Aug 9, 2018 at 6:09 PM
    FadedComa
    FadedComa Failed Porn Star.........
    09 BSP TRD SPORT......
    Wiper Blades
    It's knitted head wear for cold weather
  4. Aug 9, 2018 at 6:11 PM
    twheat40
    Tyler
    That's what I always thought!
  5. Aug 9, 2018 at 6:11 PM
    FadedComa
    Wiper Blades
    Usually had that goofy ball on top.....lol
    twheat40 likes this.
  6. Aug 9, 2018 at 6:14 PM
    twheat40
    Tyler
    Exactly!!
  7. Aug 9, 2018 at 6:15 PM
    FadedComa
    Wiper Blades
    Justanotherhemi and twheat40 like this.
  8. Aug 9, 2018 at 6:19 PM
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    Should do the trick. Will try to find the same on .ca
    I grease them religiously, but, they may be worn out at 257 000 km
    Bocsy44, UntamedTaco, RobP62 and 2 others like this.
  9. Aug 9, 2018 at 6:20 PM
    EatSleepTacos
    Randy
    Chesapeake, VA
    I’m sure if you search the part number it’ll come up!
  10. Aug 9, 2018 at 6:23 PM
    Kemosabe
    Louis
    x2 because Canada:bananadead:
    Amazon says it wont fit my 2010 Tacoma, is that true ?
    Justanotherhemi likes this.
  11. Aug 9, 2018 at 6:24 PM
    Kemosabe
    Louis
    I may be doing all the ujoints also. Are the 5 the same part #? When I'll get my service Transit I'll do a complete refresh to the truck
  12. Aug 9, 2018 at 6:27 PM
    EatSleepTacos
    Randy
    Chesapeake, VA
    Yes the carrier bearing will fit your truck. Also the u joints are different between front and back. The only difference being where the zerk fittings are. Rear has zerk fittings on the end cap. Front has it in the middle.
    Here’s the u joints for the back three (but would still fit the front)
    Universal Joint DANA 5-1330-1X https://www.amazon.com/dp/B00DP61K78?ref=yo_pop_ma_swf
    RobP62 and Kemosabe like this.
  13. Aug 9, 2018 at 6:31 PM
    ovrlndkull
    ovrlndkull STUKASFK-HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    Bilstein 6112, Deavers, Method Standards, GDYR DuraTracs
    I've always called them tobaggens all my family from up N calls them beenies.
    RobP62, twheat40 and Kemosabe like this.
  14. Aug 9, 2018 at 6:32 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    But there are some aftermarkets you can get for the rear that have the zerk in the middle as well so that it isn't low hanging fruit to be taken off.
  15. Aug 9, 2018 at 6:35 PM
    EatSleepTacos
    Randy
    Chesapeake, VA
    Yeah Spicer makes one with zerk fittings in the middle. Zerk poking out of the cap isn’t even close to low hanging fruit though. No way in hell youre ripping that off haha and if you do, your driveshaft is probably fucked anyways.
  16. Aug 9, 2018 at 6:37 PM
    Kemosabe
    Louis
    Thanks
    Yeah that is what I was meaning, like, they are all the same size. Zerks at the end cap is easier to grease, but imo center zerks would distribute grease more equally through all 4 caps. But that aint no proven facts
  17. Aug 9, 2018 at 6:37 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    I kicked a branch up that took one of mine off. It was like the perfect storm. Thankfully I have a little plano tackle organizer with spares.
    RobP62 and EatSleepTacos [OP] like this.
  18. Aug 9, 2018 at 6:39 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    It actually is with the way they run the grease orifices within the joint. Was curious one day at work and we cut the different designs apart to look. But it is very slight pretty negligible.
  19. Aug 9, 2018 at 6:40 PM
    EatSleepTacos
    Randy
    Chesapeake, VA
    Yeah they’re all the same physical size, and you just choose if you want sealed, or where you want the zerk fitting. I’m now inadvertently running sealed u joints on my back driveshaft.
  20. Aug 9, 2018 at 6:40 PM
    EatSleepTacos
    Randy
    Chesapeake, VA
    Dang that sucks
