The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Oct 30, 2018 at 11:48 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    D2066D20-C29A-4D19-BAAE-9FFA649682C0.jpg @Jckdnls just because I took this on Sunday
  2. Oct 30, 2018 at 12:29 PM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    Justanotherhemi, Bocsy44 and RobP62 like this.
  3. Oct 30, 2018 at 12:59 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
  4. Oct 30, 2018 at 1:05 PM
    AR15xAR10
    I wanted to ask, it seems like you took the top (long portion off first) is that correct? I feel like this job is going to suck. :oops:
  5. Oct 30, 2018 at 1:34 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I’m not sure to be honest, but it’s not a hard job at all. You’ve got this!
    AR15xAR10[QUOTED] likes this.
  6. Oct 30, 2018 at 1:45 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I'll get in touch with ya'll when I get on the rd. maybe we can hook up somewhere in Va.
  7. Oct 30, 2018 at 2:21 PM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    Kemosabe, Bocsy44 and RobP62 like this.
  8. Oct 30, 2018 at 2:23 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    That looks Light Weight. How much does it weigh Mike?
  9. Oct 30, 2018 at 2:27 PM
    Comatose
    Miguel
    San Diego, CA
    Ehh its somewhere on mobtowns website.
    RobP62[QUOTED] likes this.
  10. Oct 30, 2018 at 2:29 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    • Swing Out Tire Carrier: The swing out tire carrier can carry up to 285/75-16 tire on 4.5″ Backspace Wheel with 6 x 139.7 Bolt Pattern
    • Construction: It is built from 2x3x1/8″ wall steel tubing for the main beam, and the tire carrier is made from 2x2x1/8″ wall steel tubing. The plate that the tire bolts to is 3/8″ thick steel with three stock wheel studs. It is attached to the bumper with our 1/4″ thick steel bracket and uses a 1″ diameter pinion, you are not going to break it! The carrier is held securely to the bumper with a latch. The swing out opens and locks at 90 degrees.
    • Weight: 60 lbs for Swingout w/ Tire Carrier, Jerry Can Basket +25 lbs, Rotopak +10 lbs, Hi Lift Attachment +6 lbs (These weights do not include the actual accessory or tire weights)
    Comatose[QUOTED] likes this.
  11. Oct 30, 2018 at 2:31 PM
    Comatose
    Miguel
    San Diego, CA
    Yup that's it!
  12. Oct 30, 2018 at 2:34 PM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    Randy, if you happen to be at joes sometime soon and see finished bumper bars you mind grabbing them for me?
  13. Oct 30, 2018 at 2:36 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    All that talk about Jerry Can clearance issues last week, seem the RotoPax carriers are the way to go.
  14. Oct 30, 2018 at 2:39 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    :sandwich: nurse with ya :anonymous:
    Comatose[QUOTED] and RobP62 like this.
  15. Oct 30, 2018 at 2:40 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    What are you looking for in a rear bumper?
  16. Oct 30, 2018 at 3:02 PM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    Comatose likes this.
  17. Oct 30, 2018 at 3:10 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I’ll be there tomorrow and will grab you some
    Darkgoatracer[QUOTED] likes this.
  18. Oct 30, 2018 at 3:11 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Or just make room in your bed and carry them in your bed. I don't see the need to carry them all the time unless you are taking a bigger long distance trip. From what I've heard there have been some issues with RotoPax getting damaged and leaking at their attachment point from a lot of josseling around. Also like all plastic tanks they will swell with heat. Just some other aspects to consider.
  19. Oct 30, 2018 at 3:18 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    All good points.
  20. Oct 30, 2018 at 3:23 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Have you noticed I've put a bunch of my patches up for sale :anonymous:
