The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Nov 9, 2018 at 2:49 PM
    Slow Internet
    Slow Internet 56k Modem FTW!
    Slow...
    1992 Dial Up Modem...
    Wiper Blades
    Yeah, have to be tomorrow once the rain stops. Hoping its just a fuse somewhere not letting the battery power get thru the box or something.
    RobP62 likes this.
  2. Nov 9, 2018 at 2:50 PM
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    To many, but never done
    It's gotta be a fuse....or some mice or chipmunks had a little to much fun on some wires!
    RobP62 likes this.
  3. Nov 9, 2018 at 3:04 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    If you're unsure the battery is completely dead, it's nutty and risky in the rain, but you can't hurt anything putting a set of jumper cables on the battery terminals and quickly touching the other two ends together to see if you get a spark.
    If there is spark then it sounds like a fusible link or the main fuse. Follow the positive and negative wires back to the other ends to see if those are loose. Then try to locate the main fuse and see if it is blown.
    You can try taking each of the spark plug wires off and putting them right back on.
    TaKoToy and Skierrichy like this.
  4. Nov 9, 2018 at 3:15 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    40amp Main fuse
    Skierrichy likes this.
  5. Nov 9, 2018 at 3:16 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    But fuses only blow when there is a more serious issue. Normally while things are working or trying to work.
  6. Nov 9, 2018 at 3:20 PM
    Slow Internet
    Slow...
    Wiper Blades
    Thanks for that Rob, havent driven it since the return from AOAA monday. Dont think anything was left on but will try and jump it tomorrow. If nothing happens then I will start yanking fuses.
    RobP62[QUOTED] likes this.
  7. Nov 9, 2018 at 3:21 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I would check the battery with a multimeter. Last time my bitch wouldn't start, it turned out I was pulling 8v from the battery.
    That might be why it's not clicking, unlocking etc.
    Skierrichy and RobP62 like this.
  8. Nov 9, 2018 at 3:30 PM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    Good luck @FadedComa. I don’t have anything to add that hasn’t already been said.
  9. Nov 9, 2018 at 3:41 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Oh, then yea, it could just be a dead battery. But at least a light or something should come on. If it's weak.
    Now, if the alternator was weak, or on it's last leg or just shut down, and all you were doing is running the engine, and no accessories, like heat or a/c or lights, and drove it home and parked it. You could have literally drove it home and killed the battery and not even known it.
    And I mean dead dead. But it might be able to be recharged. The battery cable thing will tell you if it is dead dead. A tester is much safer. Someone near you has to have one if you don't, or they don't, then Harbor Freight sells them for under 10 bucks.
    Those fusible links can come loose though. A bad ground like Richard said too. I hate electrical.
  10. Nov 9, 2018 at 3:41 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Right :thumbsup:
    geekhouse23[QUOTED] likes this.
  11. Nov 9, 2018 at 4:28 PM
    Slow Internet
    Slow...
    Wiper Blades
    Jumped it with my jumpbox and so far it still running, something apparently was on or a door ajar, etc even tho I didnt find anything. Took the positive cable off and it didnt die so at least the alternator hasnt taken a dump. Fingers crossed it was just a blip in the matrix.
  12. Nov 9, 2018 at 4:40 PM
    UntamedTaco
    UntamedTaco Formerly: Montauk17
    Jerry
    Myrtle Beach, SC
    2017 Tacoma OR DCSB Barcelona Red
    Armor - Mobtown Offroad Front Bumper - Mobtown Offroad Rear High Clearance Bumper (with swing out) - Mobtown Offroad steel rock sliders - Mobtown Offroad steel IFS skid plate - Mobtown Offroad steel transfer case skid plate - Mobtown Offroad steel transmission skid plate - Mobtown Offroad steel fuel tank skid plate (currently not installed) Winch: - Smittybilt X2O COMP - Waterproof Synthetic Rope Winch - 10,000 lb. Load Wheels/Tires: - Toyota Black TRD Pro SEMA Wheels - Cooper ST Maxx Tune -OV Tune Installed Shocks: - Rear Shocks: Kings Racing with adjusters - Front shocks/coilovers: Kings Racing - UCA's: Dirt King Rear leafs: - Icon RXT Roof Racks: - Martin Offroad cab and cap racks Lighting: - Baja Designs floods - Baja Designs ditch - Baja Designs reverse lights Light controller: - sPOD 8 Switch Snorkel: - Dobinsons Cap: - Leer 100R with Premium Line-X Other Goodies: - On board air compressor with hose and nozzle - On board fresh water pump and water can. - Midland – MXT275VP4-15 Watt GMRS radio - Recovery gear (Shackles, Tree Saver, Snatch Block) - Ratcheting farm jack - Krazy Beaver Shovel - First World Problems Fabrication H-Lift Jack mount - First World Problems Fabrication Universal Mounts (Shovel/Axe) - Hondo Garage Un-holy Dashmount - Hondo Garage radio knobs - Other stuff that I am sure I forgot
    Was the winch power left on? I don't think this would drain the battery since it isn't under a load. But, you never know.
  13. Nov 9, 2018 at 4:56 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Like I said..........I hate Electrical!!!!!!!
    Glad you got it going. Take it to a auto parts place and let them test the battery for you for free, when you get a chance.
    If the batt is dying, I will find that coupon from Toyota for the $99 battery deal. 84 months. 2 Year free replacement and 2 year roadside.
    Glad you got it going. PARTY TIME!!!!!!! :cheers:
  14. Nov 9, 2018 at 4:59 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    If you got it running try taking it for a solid 15-20 minute drive at highway speeds to deep cycle the battery.
  15. Nov 9, 2018 at 5:02 PM
    geekhouse23
    This. So much this.
    HATE HATE HATE HATE HATE it!!!!
    RobP62[QUOTED] and Skierrichy like this.
  16. Nov 9, 2018 at 5:03 PM
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    Glad you got it running B
    RobP62 and geekhouse23 like this.
  17. Nov 9, 2018 at 5:05 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I think that's why some guys put those marine disconnects on their main winch power wire.
    RobP62 likes this.
  18. Nov 9, 2018 at 5:07 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
  19. Nov 9, 2018 at 5:08 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Are you talking about that power switch on the side of your winch? That only controls the wireless power. Your winch always has power since it’s hooked straight to the battery :oops:
  20. Nov 9, 2018 at 5:12 PM
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    Yes electrical sucks big-time!!!!
    At least I don't get zapped by the truck when I need to work on it...the house on the other hand :bananadead:
    Kemosabe, geekhouse23 and RobP62 like this.
