The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Feb 26, 2019 at 6:01 PM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    Failed attempt? Got leaks?
    Slashaar likes this.
  2. Feb 26, 2019 at 6:06 PM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah when it rains a whole lot I’ll get a little water dripping off of a couple bolts. Not enough for me to care or do anything to change it though.
    Comatose[QUOTED] likes this.
  3. Feb 26, 2019 at 6:08 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Couldn't throw a little sealant under the edge of the inner tube bits?
    Comatose likes this.
  4. Feb 26, 2019 at 6:09 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I did, I put silicone in the bolt holes as I was bolting the feet on. It’s hardly any water at all, nothing to cause any concern. Just a couple drips
    Comatose and Slashaar[QUOTED] like this.
  5. Feb 26, 2019 at 6:41 PM
    Comatose
    Miguel
    San Diego, CA
  6. Feb 27, 2019 at 10:54 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Got my new hook in. Now to go get stuck!
    cgstclair, Slashaar, irayfz6 and 8 others like this.
  7. Feb 27, 2019 at 10:54 AM
    Comatose
    Miguel
    San Diego, CA
    It dont rattle?
  8. Feb 27, 2019 at 11:01 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It probably will. I’m going to see if I can glue a couple small pieces of rubber to the hook so I can suck it in like the flat link. I don’t like having it hooked to a shackle.
  9. Feb 27, 2019 at 11:03 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Shit I might make the switch
  10. Feb 27, 2019 at 11:04 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    So that thing will lay flat like the factory 55 huh!!! Sweet that makes it even more appealing!
  11. Feb 27, 2019 at 11:05 AM
    Comatose
    Miguel
    San Diego, CA
    :anonymous:
  12. Feb 27, 2019 at 11:07 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Kinda. There’s no rubber in between the fairlead and hook so it’s not ideal. Not sure if it’ll damage the fairlead but I barely pulled it against it. Gonna see if I can diy some rubber in there.
  13. Feb 27, 2019 at 12:02 PM
    Slow Internet
    Slow Internet 56k Modem FTW!
    Slow...
    1992 Dial Up Modem...
    Wiper Blades
    Remember I had mine hooked to a shackle and it shook itself loose at AOAA
    Slashaar and BravesRunner like this.
  14. Feb 27, 2019 at 12:16 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The shackle pin did? Did you have tension on the winch line? Before the factor 55 I had steel line/hook hooked to a shackle and it was snug and the shackle never backed out.
    If I end up needing to clip it to a hook I’ll likely get an extra shackle that I’ll tighten with a wrench so it won’t come loose and I can leave the winch line slack.
    I just don’t like the little bit of syn line exposed to the elements like that 24/7
    Slashaar and geekhouse23 like this.
  15. Feb 27, 2019 at 12:18 PM
    geekhouse23
    Curious to see what product #RandyFab comes up with.
  16. Feb 27, 2019 at 12:20 PM
    la0d0g
    running for the hills
    For crawling not hauling
    2,937 messages since I was last in here. I think that's my record.
    Just saying hi :wave: carry on
  17. Feb 27, 2019 at 12:20 PM
    pabstsmeared
    pabstsmeared Simulated Weight
    Tappahannock, Va
    '13 Super White DCSB TX Baja
    Mud Tars & Shit
    At work, on shackles we want to stay put we will just mar the threads on the shackle bolt so it won't back out.
  18. Feb 27, 2019 at 12:21 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I just had a thought. I wonder how well some sort of silicone would hold up. Just a few large dabs in select locations to act as a rubber pad.
  19. Feb 27, 2019 at 12:22 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I was thinking I would just weld the pin to the shackle, but as I type this I realize that's a bad idea because the heat might compromise the integrity of the shackle. Red loctite would do the trick.
  20. Feb 27, 2019 at 12:22 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Better get to reading!!
