The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. May 16, 2019 at 2:23 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Are you drinking again, already?
    Justanotherhemi and Slashaar like this.
  2. May 16, 2019 at 2:35 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Do what!!!!???!!?!??!????? :eek::eek::eek:
    You need to come down to Charleston and go sleep on the USS Yorktown and get a feel for what being in the Navy is. Also the USS North Carolina Battleship in Wilmington you can go on tour. So they have chambers and numbers written above all doorways/hatches so you know where on the ship you are located. Starboard, Port, fore and aft. I think my great uncle just rolled over in his grave hearing this. He would be sorely disappointed knowing that there are "sailors" that don't go on ships today.
    You have baffles in your gastank and a little sump area for the pump but mostly they are used as noise reducers unless you are carrying a shit ton of fluid. Then they are used to slow movement down so that to not make the load shift hard. Think of a tanker and what could happen if the load shifted hard around a turn it could roll.
  3. May 16, 2019 at 2:38 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Nope you just need to ride/watch a truck with a braced and plated frame far less frame flex which is where you get the difference in bed and cab movement.
  4. May 16, 2019 at 2:40 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    I know a guy that mounted a tube above the rear wheel inner fenders as his tank. No one knows it's there. Then he has a little RV pump in one of the bed cubbies and plumbed a line to the tank. It's a pretty sick little set up.
  5. May 16, 2019 at 2:46 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Then you don't get the solar heating of having it on the roof.
    Justanotherhemi likes this.
  6. May 16, 2019 at 2:53 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Wrap it in 12v heat tape problem solved for the cooler/colder months.
  7. May 16, 2019 at 2:54 PM
    twheat40
    twheat40 POOP Custodian
    Tyler
    2017 4Runner SR5 Premium
    I mean I've never been in a rating or position that went on ships. I joined under a special operations contract, got hurt and had surgery before I finished training, and ended up in cyber security. There are only a few CTN billets that go on ships. It's great.
    Justanotherhemi, Slashaar and RobP62 like this.
  8. May 16, 2019 at 3:27 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Did this once. Drove from Myrtle Beach on our Harley's. We stopped at every bar down and back. Worst crab cakes I've ever had were at some restaurant in Charleston, on some river. They had green peppers in them. The Yorktown was cool AF though. The flight deck needed some touch ups here and there but that is the ultimate non-skid surface!
    Right, I know, which is why I brought it up. I plan on mounting mine to my cheap OEM ebay copy roof rack and while I am sure the screws into the roof are sound, I doubt the ability of the cross rails to withstand 83 pounds of water going from XX mph to 0 in an emergency. The whole setup could become a torpedo with wings. :eek:
  9. May 16, 2019 at 3:30 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Ahh. Gotcha! But will it stop it completely? That is the question. :notsure:
  10. May 16, 2019 at 3:32 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    With a little more bracing and some more plating under the cab it should be completely alleviated
  11. May 16, 2019 at 3:35 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    That sounds very cool but if the home made water port on the roof wasn't so easy and cheap I would just buy one of these:
    https://www.amazon.com/Gedun-Outbac...WPF6PF7R159&psc=1&refRID=EP7ZDFDG3WPF6PF7R159
    I suppose with extra water on hand this is not a bad deal for winter camping.
  12. May 16, 2019 at 3:35 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Yeah that would not be good having a water torpedo. But it really won't have issues with hammering until it's below full and enough space to get some momentum. If you are running a constant speed it's still kinda static so it wouldn't get to much of a run or time to gain speed.
  13. May 16, 2019 at 3:35 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
  14. May 16, 2019 at 3:40 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :thumbsup:
  15. May 16, 2019 at 4:06 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Foe sho! I need new tires before fall, but have to be able to get an alignment so I dont scrub a new set of tires due to my poor alignment.
  16. May 16, 2019 at 4:24 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    I think i am gonna get some Dirt King LCAs to finish off the front end. Lets figure out a time this fall
  17. May 16, 2019 at 9:04 PM
    08TRDOFFROAD
    Dan
    Sounds like a plan! I still need to source some LCA's hopefully lightly used from the marketplace so I dont have to fork over 286 a piece for new OEM ones.
  18. May 17, 2019 at 8:13 AM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    I have the older JBA upper control arms, and the ball joints are rusty as hell and one has play in it. I bought the new ones and when I mail back in my old ones, Marlin will refund me all of my money! While I'm at it, I ordered polyurethane bushings for it. Since I'll have them off and taken apart, I'm also going to paint them black. So excited to get rid of that awful red.
    Bocsy44, HCJ, ovrlndkull and 4 others like this.
  19. May 17, 2019 at 8:16 AM
    BravesRunner
    BravesRunner “Exploration is curiosity put into action”
    Adam
    SC
    2021 GMC Sierra 1500 Denali
    Grandpa steps//Tri-fold Tonneau bed cover
    @Comatose
  20. May 17, 2019 at 8:27 AM
    pabstsmeared
    pabstsmeared Simulated Weight
    Tappahannock, Va
    '13 Super White DCSB TX Baja
    Mud Tars & Shit
