The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Sep 7, 2019 at 4:39 PM
    Slow Internet
    Slow Internet 56k Modem FTW!
    Slow...
    1992 Dial Up Modem...
    Wiper Blades
    I was gonna say the wipers but I like your answer better
  2. Sep 7, 2019 at 4:45 PM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    This might explain why the engineers at toyota put it where it was with the liners you removed.
  3. Sep 7, 2019 at 4:45 PM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    The whole argument of why this works is because your cabin air draws from the same location too. So if it were to be a potential problem, your feet would be getting soaked all the time, but I guess the cowl area just doesn’t get very wet.
    There’s a bunch of people that have done this mod and only one that I’m aware of had any problem, and he was bombing through a water hole.
  4. Sep 7, 2019 at 4:46 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah with the liners it’s pretty safe, but no way I’d run it open to the world. I was under there looking at it today, and I may have to do a little tubbing in there to fully clear these things.
  5. Sep 7, 2019 at 4:48 PM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    Welcome to that dirty5 life - where your truck goes from useable to garbage
    TaKoToy and RobP62 like this.
  6. Sep 7, 2019 at 4:51 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That’s what separates me from a lot of other people on here. I’ll put in the work to make it fit and never, ever, rub. Then I won’t be like David who can’t back out of a parking space without hitting his cab mount. :devil:
    RobP62 and ovrlndkull like this.
  7. Sep 7, 2019 at 4:52 PM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    Cab mount? Just do the cab mount delete mod and firewall delete mod like i did.
    RobP62 likes this.
  8. Sep 7, 2019 at 4:53 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Even better, I’ll do 33s up front so I don’t rub, and do 37s in the rear for maximum diff clearance. Then gear my differentials accordingly.
  9. Sep 7, 2019 at 5:13 PM
    Taco-Obsessed
    The same top secret anti-water technology that prevents it going into your HVAC system, which also pulls air from the same area.
  10. Sep 7, 2019 at 5:49 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    :facepalm:
    Since no one else was helpful I'll try and be.
    See the lip inside the cowl in Randy's pic that goes to the HVAC it's raised up. Then the cowl is sloped towards the outside edges which there are drains located.
  11. Sep 7, 2019 at 5:52 PM
    Taco-Obsessed
    Now I feel like a dick.
    @Rome604 check out this thread for a good write up: https://www.tacomaworld.com/threads/cowl-induction-snorkel.525314/
  12. Sep 7, 2019 at 6:02 PM
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    Thank you!
    ovrlndkull[QUOTED] likes this.
  13. Sep 7, 2019 at 7:10 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    At this point he could plant ferns in there. :D
    EatSleepTacos[OP] likes this.
  14. Sep 7, 2019 at 7:12 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    You could do that 90, come out of the cowl and add the prefilter cap.
    If I could do that I would.
  15. Sep 7, 2019 at 8:20 PM
    Taco-Obsessed
    What 34s tires and wheels (diameter, backspace) are you running now?
  16. Sep 8, 2019 at 2:04 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    295/70r17 cooper mtp. They’re on 17x7.5 oem tundra/sequoia wheels.
    1.25” spacers in front to clear uca. 2” spacers in rear to clear shock relocate.
    I forget the offset on the wheel, I think it’s +15mm. They’re a little more aggressive than oem wheels which are around 30/35mm
    ovrlndkull and RobP62 like this.
  17. Sep 8, 2019 at 7:35 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    They really aren't that much bigger than a 33 in reality. Don't know if you've looked at tires and sizes a lot but there is a whole lot of variability. There isn't really a standardization for the measurements. Brands can run big or small in a given size or within their same line.
    Even though those MTPs aren't that much bigger than a 285s they do in person look quite a bit larger.
    RobP62 likes this.
  18. Sep 8, 2019 at 7:53 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I agree. The 255/80 Nitto is taller than the same size Cooper for instance. I am constantly looking at different tires and see it all the time.
  19. Sep 8, 2019 at 8:06 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Like you said, depends on the tire. These mtp measure out at 33.46 diameter while most 285s are around 32.6ish. Almost a whole inch bigger than most 285s. I think the very aggressive tread makes them look bigger too.
    RobP62 likes this.
  20. Sep 8, 2019 at 8:17 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Yep
    Definitely. On a tire calculator they are a little over 1% bigger but side by side they looked a lot bigger than my duratracs.
