The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Nov 23, 2019 at 9:04 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Merci Beaucoup Louis! Your kinds words are greatly appreciated my Brother of The Great White North!
    Hope you and yours celebrate the upcoming holidays with as much joy as possible!
  2. Nov 23, 2019 at 10:21 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    @EatSleepTacos what size breaker do you have on your garage? Looking at my panel before buying a 140 and its a 20amp breaker for the garage/kitchen. Looks like at max amperage, the 140 uses a 23 amp input if I am reading it right.
  3. Nov 23, 2019 at 10:24 AM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    I have a 20. I asked an electrician once and you can’t go higher than that for 120 I guess. I trip it every once in awhile but not often at all.
  4. Nov 23, 2019 at 10:25 AM
    Gunshot-6A
    Conner
    Everett, WA
    Woot! Looks like Im getting into the welder game in 2 weeks.
  5. Nov 23, 2019 at 10:34 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If you can swing it, get their Vulcan helmet too. It’s well worth the price. And their welding cart is a good buy too.
  6. Nov 23, 2019 at 11:18 AM
    TaKoToy
    TaKoToy Well-Known Member
    Robbie
    Prince George VA
    2013 4x4 OffRoad, 2020 cement DCLB OR
    Mostly stock
    You try clear fish tank air line from the furthest brake line to the reservoir? That way you can see the bubbles and your pumping fluid back into the reservoir. Worked for me a few times.
  7. Nov 23, 2019 at 11:20 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yep, did all that. Found a local guy in our toyota group who's a mechanic, and has an expensive scanner. He cycled the abs module and we bled again and no dice. We're gonna met up again monday and pressure bleed my whole system. It's driveable now, but certainly not a firm pedal.
  8. Nov 23, 2019 at 11:24 AM
    TaKoToy
    Robbie
    Prince George VA
    Mostly stock
    Maybe a broken abs sensor wire. I did that on a honda and it made the whole system act goofy.
  9. Nov 23, 2019 at 11:25 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    While I do have a broken abs wire from my last trip out (lol) it's not that. This is like the third time I've torn a wire on this truck.
    I am going to tighten up my rear brakes a bit, and that will help.
  10. Nov 23, 2019 at 2:05 PM
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    I ordered some recovery gear from Treaty Oak and some magnetic armor from GOAT. I'm probably going to buy some new battery trays for a dual battery set up from Off-grid Engineering but I'm waiting because they aren't covered under black Friday. I want to see if there's something else that I can jump on for BF.
  11. Nov 23, 2019 at 2:08 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You can jump on me Dave
  12. Nov 23, 2019 at 2:10 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :eek: oh man David! Are you getting the camouflage for the sides!?
    :goingcrazy: :bowdown:
  13. Nov 23, 2019 at 2:12 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    What's that? BF = Boyfriend?
    I'm down! :yes:
  14. Nov 23, 2019 at 2:15 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Wash the 35’s in hot water, they will shrink, should fit fine.
  15. Nov 23, 2019 at 2:19 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Maybe?
  16. Nov 23, 2019 at 2:25 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I think I like this better.
    It's giving me sensations.
  17. Nov 23, 2019 at 2:32 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :annoyed:
  18. Nov 23, 2019 at 2:38 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    The Rand until Monday
  19. Nov 23, 2019 at 3:58 PM
    Rome604
    Dave
    Alexandria, VA
  20. Nov 23, 2019 at 4:18 PM
    Sasquatchtaco
    Sasquatchtaco Sasquatch Taco
    Catskills NYS
    09 MGM DCSB 4X4 TRD
    Too many to list.
    Good evening all.. Mr. lurker here.
    Are any of you fine gentlemen running falkens wildpeaks ATs?
    I've gotta get some rubber soon and need some input. Currently have grabbers at2s.
