The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Dec 16, 2019 at 6:54 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    The bugs here on the east coast will fly into an open flame! I have an orange led in the fixture by the back door. Every year I have to open it up and empty the bugs out. All any kind of light here does is allow the bigger bugs and frogs to see and eat the little bugs.
  2. Dec 16, 2019 at 6:58 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    That too. My interior lights are red and it's true. It's definitely better than white light, at least for me. I figure worst case, I'll just get some red acrylic and add it as needed when the time comes.
  3. Dec 16, 2019 at 7:05 PM
    My Name is Rahl
    My patio light is white LED and we never have bugs.
    RobP62[QUOTED] and Slashaar like this.
  4. Dec 17, 2019 at 3:19 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Then I'm moving to Central Ohio! :fistbump:
  5. Dec 17, 2019 at 5:09 AM
    My Name is Rahl
    Fvck no! Don't do that! We charge people for lobster here and have shitty weather!
    Slashaar and RobP62[QUOTED] like this.
  6. Dec 17, 2019 at 8:39 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    But not any bugs apparently. The state bird of Pennsylvania is the mosquito, and I am only 3 miles from the line.
  7. Dec 17, 2019 at 8:48 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Scientifically speaking, Cyan (aka blue-green) is the best color for functional dark adapted vision. I'll spare you the rest of the scientific mumbo-jumbo about rods and cones, rhodopsin, and G-protein coupled receptors. It's enough to get you through a round of Jeopardy!
    Hence the reason Navy CIC's are always blue:
  8. Dec 17, 2019 at 9:03 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    While this might be true now (Military Applications), there is still some controversy over the subject and it wasn't always the case:
    "A red light has been the traditional choice for retaining your night vision since before WWII when the military settled on red as the best choice. Recently, there has been a move to green and blue-green light, precipitated in large part by the military's change to green, which itself has been primarily motivated by the increased use of night vision equipment. As it turns out, green light also offers some advantages over red as a means to retain night vision capability. However, it isn't cut and dried.
    Total brightness, or illumination level, of the light has a potentially more significant effect on night vision retention than does the choice of red or green. Because your eyes are more receptive to green light, we gain better visual acuity at lower light levels than when using red light. Green also allows for differentiation between colors that red does not and the magenta used on aviation charts, for example, is readily readable under green light, not always the case with red.
    Both reasons contribute to the fact that pilots and many others generally seem to prefer green over red, it simply makes it easier to see and read in the dark cockpit. The potential problem is with the actual illumination levels we use, not the color of the light. The brighter the light, the more negative impact on night vision, both in our capacity to see and in how long it takes to gain back optimum night vision. This is true regardless of whether it is red or green.
    Ideally, you want to use only as bright a light, red or green, as is necessary to perform your chores and no more. However, if you have a brighter light than you actually need,
    a brighter green light will generally have a more negative effect than an equally bright red light. Green or blue-green has a greater capacity to adversely effect night vision because the eye is about 100 times more sensitive to these colors, so even moderately too bright light can have a serious deleterious effect.
    Another complication is that individuals' visual acuity at low light levels varies quite a bit, so what would be perfect for one, might be too bright or too dim for another. In other words, without some means to vary intensity, odds are no light will be perfect. Bottom line is that red or green will both perform adequately, but what you really should be more concerned about is to avoid very high illumination levels, of either color, if retaining night vision acuity is your goal."
    Slashaar and My Name is Rahl like this.
  9. Dec 17, 2019 at 9:37 AM
    My Name is Rahl
  10. Dec 17, 2019 at 9:41 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Also it would be embarrassing to some to have a pink submarine.
  11. Dec 17, 2019 at 10:21 AM
    rnish
    Tacoma 2nd gen
    Also did everybody miss the 75th anniversary of the beginning of the Battle of the Bulge?
    Slashaar, RobP62 and My Name is Rahl like this.
  12. Dec 17, 2019 at 10:44 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl:
    Although, I did just attend our department lunch out of house with three highlighter pens in my breast pocket that represent the various stages of QA/QC here. :bananadead:
  13. Dec 17, 2019 at 11:10 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Nope, I recorded it on my Tivo so I can add the middle and end, then watch all 15 hours of it at once.
    :infantry: :fenforcer:
  14. Dec 17, 2019 at 11:26 AM
    My Name is Rahl
    :facepalm: That's not very Lair worthy...
  15. Dec 17, 2019 at 12:39 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    What is these days Rahl? What is..........
  16. Dec 17, 2019 at 12:42 PM
    My Name is Rahl
    I would ask @EatSleepTacos, but he isn't Captain any more, so...:notsure:
  17. Dec 17, 2019 at 12:50 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Exactly! :mad:
    I bet if we chatted him up on Hangouts he would know. o_O
  18. Dec 17, 2019 at 1:23 PM
    My Name is Rahl
    I do use Hangouts quite a bit, but not to talk to Randall.
  19. Dec 17, 2019 at 1:24 PM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    Well I bought something for the truck last night but now I don’t know if I’ll share in here since I smell a mutiny lingering about.
  20. Dec 17, 2019 at 1:25 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    It's truck nuts.
