The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Jan 23, 2020 at 12:50 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    About time from the looks of it too.
  2. Jan 23, 2020 at 12:54 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    All the more reason for me to bring you the bumper, help you store or install or paint it, eat some oysters, drink some beers, play with the puppy (setup for you preverts) and maybe spend the night depending on how many beers we had!
    but NOOOOOOOO. :rant:
    I was really looking forward to some good oysters too. :hungry: And playing with the dog.
    HCJ and My Name is Rahl like this.
  3. Jan 23, 2020 at 1:10 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Ok, so I am hooked on this spot for mounting something but now I am thinking what if I ever get a CB or Mobile Ham. Do either of you think it would be possible to mount either the switch or a radio forward of that overhead console, between it and the rearview? Seems like the switch might work there for sure, obviously using the bracket that comes with it. Not so sure about a radio. However, if I do ever get a CB, it will be the one where everything is in the Mic and the head unit is hidden.
    Justanotherhemi and Gunshot-6A like this.
  4. Jan 23, 2020 at 3:11 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Quite a few people mount the head of a ham radio on a bracket over the rearview mirror
    LOL, consider the source. Should have looked on here!
    https://www.tacomaworld.com/threads...dio-and-antenna-installs.207841/#post-4676896
  5. Jan 23, 2020 at 3:12 PM
    Gunshot-6A
    Conner
    Everett, WA
    people have also made a mount using a piece of 2x4 for the radio that slides into the cubby by your left knee.
    Justanotherhemi and RobP62 like this.
  6. Jan 23, 2020 at 3:16 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
  7. Jan 23, 2020 at 3:26 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I think with the right radio I could mount it in the cubby where the Qi charger is and still use the charger.
  8. Jan 23, 2020 at 3:35 PM
    My Name is Rahl
    Do the Qi chargers work better in the new trucks? Mine just heats the phone and drains the battery. My thought was to remove the charging magnet underneath and then trim cut the charging pad to fit my radio...
  9. Jan 23, 2020 at 4:02 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Do you have a pad in there Rahl? Like a non slip pad? Or a case on your phone? either of those will make it heat up more than without. My 17' charged fine, and this one does too. It's not lightening fast but.......I also have a plug in charger always in my console, plugged in. Actually two so we can both charge them.
    I think there is enough room for both in that lower center console cubby though. The radio would have to be tiny though.
  10. Jan 23, 2020 at 4:21 PM
    My Name is Rahl
    I have a phone case, but it doesn't affect my Samsung wireless chargers.
  11. Jan 23, 2020 at 4:27 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    It doesn't get hot at all on those? Mine does. I use a UAG case on my phone and yes, it does get hot in the truck but it also charges. Does it charge like the Qi's from Sammy, no.
    Do I agree they wasted that space with a feature I could have done without for something else I could use there, absofuckinglutely.
    I also don't like the placement of the cup holders in relationship to the 12v accessory outlet. My wife's travel mug gets in the way of the mute button on the plug from my Redline radar detector. I plan on moving that to her side of the knee panel in the foot well over there. When I do that I will most likely add two high speed usb ports there, and a blank drilled out with a mic plug for the all in one CB.
  12. Jan 23, 2020 at 4:30 PM
    My Name is Rahl
    Nope, never gotten hot on my 2 Samsung chargers. My case is a slim Otterbox.
  13. Jan 23, 2020 at 4:32 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Hmmm, even my S3 watch gets warm on my charger.
  14. Jan 23, 2020 at 4:33 PM
    My Name is Rahl
    :notsure:
  15. Jan 23, 2020 at 4:38 PM
    UntamedTaco
    UntamedTaco Formerly: Montauk17
    Jerry
    Myrtle Beach, SC
    2017 Tacoma OR DCSB Barcelona Red
    Armor - Mobtown Offroad Front Bumper - Mobtown Offroad Rear High Clearance Bumper (with swing out) - Mobtown Offroad steel rock sliders - Mobtown Offroad steel IFS skid plate - Mobtown Offroad steel transfer case skid plate - Mobtown Offroad steel transmission skid plate - Mobtown Offroad steel fuel tank skid plate (currently not installed) Winch: - Smittybilt X2O COMP - Waterproof Synthetic Rope Winch - 10,000 lb. Load Wheels/Tires: - Toyota Black TRD Pro SEMA Wheels - Cooper ST Maxx Tune -OV Tune Installed Shocks: - Rear Shocks: Kings Racing with adjusters - Front shocks/coilovers: Kings Racing - UCA's: Dirt King Rear leafs: - Icon RXT Roof Racks: - Martin Offroad cab and cap racks Lighting: - Baja Designs floods - Baja Designs ditch - Baja Designs reverse lights Light controller: - sPOD 8 Switch Snorkel: - Dobinsons Cap: - Leer 100R with Premium Line-X Other Goodies: - On board air compressor with hose and nozzle - On board fresh water pump and water can. - Midland – MXT275VP4-15 Watt GMRS radio - Recovery gear (Shackles, Tree Saver, Snatch Block) - Ratcheting farm jack - Krazy Beaver Shovel - First World Problems Fabrication H-Lift Jack mount - First World Problems Fabrication Universal Mounts (Shovel/Axe) - Hondo Garage Un-holy Dashmount - Hondo Garage radio knobs - Other stuff that I am sure I forgot
    Hmm. Not sure. Did you see where I had my CB mounted on the ride side of the center console?
  16. Jan 23, 2020 at 6:23 PM
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    Can we get more pictures of the sexy sexy shag van under the carport?
    1992 Dodge Van with a 318 v8 & 4 speed automatic?
    Love the racing stripe circling the curves on that bay bay!
    RobP62 and My Name is Rahl like this.
  17. Jan 23, 2020 at 6:29 PM
    Justanotherhemi
    Rick James
    I took a management sensitive course online on Monday. I feel like a new me. With proper utilization of my new found skillset I have managed to reserve judgment on your poor choice of electronic devices. I am a reformed individual. I fully embrace the new me.
    <3 Roberto
  18. Jan 23, 2020 at 6:31 PM
    My Name is Rahl
    I suppose you're an Apple sheep? :rolleyes:
  19. Jan 23, 2020 at 6:33 PM
    Justanotherhemi
    Rick James
    No sir. I am not. I am a manager who cares about those he manages & those who are clients. #NewManagementCourse#Newme
  20. Jan 23, 2020 at 6:41 PM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    iPhone is love. iPhone is life.
