The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Jun 17, 2020 at 2:30 PM
    deekyn
    deekyn Well-Known Member
    Dustin
    Yellowstone
    2015 Black Tacoma TRD Off Road
    Just buy some clips off eBay with a foam washer on them. that way you don’t have to worry about fucking up your clips when you pull them or fighting with rubber washers. Also with these, No bondo was needed.
    https://www.ebay.com/itm/264019833291
    And it really is an easy job if you’ve got a dremel. But I’m biased. I love the look.
    EatSleepTacos[OP] and RobP62 like this.
  2. Jun 17, 2020 at 2:31 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I was just messin' Brother. More jelly than anything. My ceiling is only 8'. It's such a PITA and a waste. It should be a law that 9' is minimum.
    If I was going to do this I would 4" screw mount 2x4's or 1x4's to the ceiling, then drill through them into the joists so I could 5" lag bolts. I have 92" to the bottom of the old florescent fixtures and 77" to the top of the cap at the tailgate end of the truck with it mounted. Actually, it might be 76" but I am being safe. So minus the 2x4's and pulleys, I definitely have room for this lift thing. The deal is, once this thing is on, I hope to never have it off again. Also it's not something I could do and let it hang in the garage. It would leave me 62" of space under it. I have a 2 car garage so................
    Slashaar likes this.
  3. Jun 17, 2020 at 2:32 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    That's clean. :thumbsup:
  4. Jun 17, 2020 at 2:36 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I saw on CARID you can buy the fenders without flares and no holes. (at least I saw them for 2nd gens, should be the same deal) They were pretty cheap, but unpainted.
  5. Jun 17, 2020 at 2:40 PM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Already have the clips saved on Amazon! I'm also looking into just doing button head bolts and washers..I'll make a decision someday.
    I was willing to do new fenders, but after painting it for ridiculous. And then what about the bedsides?
    It's neverending, I tell ya!
  6. Jun 17, 2020 at 2:56 PM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    This was my first time buying “bulk” steel as opposed to cut to length. Damn it’s so much cheaper. I paid $55 for a 20’ stick of 2”x.120 square tube. Built a stand for my bender. Just need to get the hydraulic ram on.
  7. Jun 17, 2020 at 3:01 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Shame you didn't have a roof rack to cart it home on.
  8. Jun 17, 2020 at 3:03 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That roof rack is 3’ long and the tube 20’. No way I’m leaving 8.5’ unsupported on both ends lol
  9. Jun 17, 2020 at 3:04 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Oh fuck that gives me an idea though. I have 12’ of leftover tube. I can make a support that’ll stick up out of the hitch and can carry tube on the roof
  10. Jun 17, 2020 at 3:10 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    You would've been fine.
    And you're welcome for the idea.
  11. Jun 17, 2020 at 3:15 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    And it only looked slightly ridicules. Nice job #RandyFab!
    Slashaar and Gunshot-6A like this.
  12. Jun 17, 2020 at 3:17 PM
    My Name is Rahl
    Did you get any funny looks from the metal yard?
    Slashaar, Gunshot-6A and RobP62 like this.
  13. Jun 17, 2020 at 3:18 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
  14. Jun 17, 2020 at 3:20 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Not the guy thought it was brilliant
  15. Jun 17, 2020 at 3:20 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :eek: :lalala:
  16. Jun 17, 2020 at 6:29 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    I got the LCAs from Toyota of Dallas (formerly TRDparts4U if you are a long time 2nd gen owner). They were $266 a side and $30 in shipping for the pair. I have had the Cam hardware since circa 2016 when I originally found out the cams were seized. But I think I got those through one of the parts contacts on here at the time. It was around $70 per side, IIRC.
    This thread has a list of part numbers for the cam hardware.
    https://www.tacomaworld.com/threads...part-numbers-and-bushing-part-numbers.403162/
    EDIT: I have gotten Larry H Miller to match online prices before when I needed a passenger side headlight assembly. If you wanted to try and source them locally.
    And these are the blades I used. They worked great!
    https://www.homedepot.com/p/DIABLO-...5U5AAAKGy-W48DHfpRRoCosMQAvD_BwE&gclsrc=aw.ds
    Slashaar and Gunshot-6A[QUOTED] like this.
  17. Jun 17, 2020 at 11:46 PM
    freddy2923
    freddy2923 Well-Known Member
    Freddy
    Phoenix, Arizona
    2015 Barcelona red Tacoma trd or
    Pretty much stock, just a light bar and a avid off road bumper guard
    Recently took the flares off my second gen and bought some carriage bolts (5/16 I believe) and rubber washer to go behind it so it won’t rub the paint as bad. But my plan is to buy color match paint to paint the heads of the bolts but as of now the holes don’t bother me.
    Before
    Slashaar, RobP62 and crashdb[QUOTED] like this.
  18. Jun 18, 2020 at 2:29 AM
    Sasquatchtaco
    Sasquatchtaco Sasquatch Taco
    Catskills NYS
    09 MGM DCSB 4X4 TRD
    Too many to list.
    See, this is why we don't assume. I just made an ass out of myself
    Slashaar and RobP62 like this.
  19. Jun 18, 2020 at 5:09 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I bought bend-tech software to help me with this, since I'm so new to bending. Man this is cool and will really help me get everything spot on.
    These are just random numbers I plugged in to mess around with it.
    Slashaar, RobP62 and freddy2923 like this.
  20. Jun 18, 2020 at 6:38 AM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    In my day we used eyeballs and abacus'.
